Old 03-28-2011, 05:36 PM   #1441
macdude's Avatar
Originally Posted by Coar View Post
I am just curious if there is anyway to make the MMP compatible with the Data logger software? This software would be very useful to do some fine tuning in dirt oval racing.
As far as I know the data logging software is for the airplane esc only.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 05-08-2011, 07:33 AM   #1442
I just installed the most recent firmware from Castle (april 2011). When I tested the throttle the engine does nothing and only steering. Checked all the setting in the software, the battery, but no results.
So I installed the older Castle software and also the older firmware for de mamba max, but still no engine.
Do you guys have any idea?
Friit is offline   Reply With Quote
Old 05-08-2011, 10:04 AM   #1443
Trader Rating: 81 (100%+)
Did you try to reprogram the throttle endpoints on the esc? Also make sure your throttle pattern is correct after you updated the esc. One time after updated mine it looked like an EKG strip instead of a linear line.
dpcardoza is offline   Reply With Quote
Old 05-08-2011, 11:07 AM   #1444
YESSSSS thank you it worked!! Thanksthanks!!
Old 05-14-2011, 12:53 AM   #1445
Default On the fence...
Hi everyone, I'm thinking about getting a MMP for a FT SC10, and I've got some electric noob questions (I'm an 8th scale nitro buggy/truggy guy).
Will the MMP play nicely with a Spektrum SR300 receiver that came with my DX3? I've read through the threads and noticed many people have problems with Spektrum stuff.
How about JR 9000 servos? I have both a 9000s and a 9000t, so I could use either.
Thanks in advance!
Mike
MikeB2 is offline   Reply With Quote
Old 06-01-2011, 12:10 AM   #1446
Born2Run's Avatar
Default Bad luck with a new MMP
I pushed the sensor wire too hard on my MMP and broke the harness on Speedo and now i can run it only in sensorless mode.So i bought a new MMP speedo but from the first moment ,with the same motors and settings it runs slower than my old one.I recalibrate the transmitter with the new speedo,i also update it with the v3.40.0 and the latest firmware (so far i was using the 3.251 version with 1.26 firmware) but it still slower enough.I don't think the problem has to do with the software version.I checked the sensor cable,power cables,motor wires,connectors,everything.Something must going wrong with this speedo.I know how the MMP runs so before sending in,is there any idea what could be this problem?
Whatever
Born2Run is offline   Reply With Quote
Old 06-08-2011, 10:03 AM   #1447
shamar's Avatar
Hi guys
My name is shamar and I live in barbados and I need some help tuning my mmp. I'm using a duo2 13.5 motor in a losi jrx s type r. We race in a fairly large car park wit low to med traction and it fast and flowin with a high speed sweaper. Most of the guy are using tekin esc n a few lrp esc. Hey is my setting on the mmp with the duo2 13.5 motor
Car- losi jrx s type r
Bec voltage- 5.5v
Throttle dead band- 0.0500
Start power- high
Cheat mode- 7000k-13200k @ 35%
Motor timing- 1 mark from stock
Forward power- 100%
Punch control- o%
Torque control- 5.5
Brake- 100%
Drag brake- 70%
Fdr- 5.00
Im using the latest software 1.32
I test the car outside my house n it felt great. The power came on gud n it was really smooth. I also change the thottle and brake to a curve and it giving gud brakes. I really love dis esc
shamar is offline   Reply With Quote
Old 06-09-2011, 01:43 PM   #1448
shamar's Avatar
Originally Posted by shamar View Post
Hi guys
Bec voltage- 5.5v
Start power- high
Forward power- 100%
Punch control- o%
Torque control- 5.5
Brake- 100%
Drag brake- 70%
Fdr- 5.00
anyone plz
Old 06-09-2011, 02:12 PM   #1449
Luppi Stefano's Avatar
anyone plz
try this
Start power- medium
Cheat mode- 11.500k-18700k @ 50
Motor timing- stock
Torque control- 0%
Fdr- 7.00
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 06-15-2011, 08:19 PM   #1450
shamar's Avatar
hi guy
i have really learn alot of dis form for the past 2 month. Keep up the gud and im really loving the mmp more. Sunday was the first ting i gotta really test it and i must say it super fast but i my setting was really bad and the car we use had no traction and i could get any power down without wheel spinning all over the place
hey is the settings i was using
Bec voltage- 5.5v
Start power- high
Forward power- 100%
Punch control- o%
Torque control- 5.5
Brake- 100%
Drag brake- 70%
Fdr- 5.00
and hey wat i use and it felt alittle better but wit lag
Bec voltage- 5.5v
Start power- high
Cheat mode- 10000k-15000k @ 35% and 11500k-18700k @50%
Forward power- 100%
Punch control-50%
Torque control- 0%
Brake- 100%
Drag brake- 70%
Fdr- 5.00
Old 06-15-2011, 08:55 PM   #1451
Trader Rating: 19 (100%+)
hi guy
Bec voltage- 5.5v
Start power- high
Forward power- 100%
Punch control- o%
Torque control- 5.5
Brake- 100%
Drag brake- 70%
Fdr- 5.00
Bec voltage- 5.5v
Start power- high
Forward power- 100%
Punch control-50%
Torque control- 0%
Brake- 100%
Drag brake- 70%
Fdr- 5.00
it would help if we knew what turn motor you are running? and what size track as well as what surface it is. Thanks
nevermind, read the previous post, two or three posts above try maybe a 6.6 fdr and do everything else that luppi said above
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 06-16-2011, 09:29 AM   #1452
shamar's Avatar
Hi ice
I'm using a duo 2 13.5 motor wit timing move to 1 mark from stock and the straight is bout 100 too 150 and it low too med traction . I'm wait on my pinon and spur gear dat I order 2 week ago. I live in barbados so tings take up too 3 week ta get too me so I'm stuck use 5.000 or 5.850
Old 06-16-2011, 09:30 AM   #1453
shamar's Avatar
Hi ice
I'm using a duo 2 13.5 motor wit timing move to 1 mark from stock and the straight is bout 100 too 150 car park and it low too med traction . I'm wait on my pinon and spur gear dat I order 2 week ago. I live in barbados so tings take up too 3 week ta get too me so I'm stuck use 5.000 or 5.850
Old 06-16-2011, 10:02 AM   #1454
Hi ice
go with the higher 5.8 ratio then, run your motor timing all the way down, set your start power at low and you could even work with your throttle curve some also to smooth out the feel and you wont spin as much, in this case the best throttle curve is a gradual concave curve. go with 11500 start rpm and whatever the highest end rpm for you cheat mode is, and use 30-40 degrees of cheat timing. Hope this helps, try it and get back. Thanks!
★Randy Banks★
Old 06-16-2011, 10:22 AM   #1455
geeunit1014's Avatar
I would actually run the settings from the first list you posted, but change the torque control to 4.0, and take the punch control off. The reason the 2nd setup feels laggy is because of the punch control, along with the higher rom range. Things like punch control, or curve as suggested above, will only make the trigger feel more mushy, meaning you will just pull the trigger more, but still get the same result of wheelspin, etc. The torque control really does limit bottom end torque, so this is the adjustment you want to play around with to help you get off the line, out of corners etc.
Normally I will leave the curves linear, punch control on 0, and play with the torque control until I find the right feel for the track. You can also try spreading the RPM range out, which will help smooth out the timing as it comes in, say a range of 5-15k or so rpm.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18835 09-11-2017 07:44 AM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
