Old 11-03-2010, 09:01 AM   #1321
rced1's Avatar
Trader Rating: 17 (100%+)
I have the older version of Castle Link for the Mamba Max and just recently got the Pro. Does anyone know how I can get the Castle link adapter that plugs into the rx wire without getting the whole Castle Link again?
Slow is fast.
rced1 is offline   Reply With Quote
Old 11-03-2010, 12:54 PM   #1322
Jochim_18's Avatar
Look at the page back I post some really good setup using 13.5 ballistic especially for a smal track. Sweet spot on ballistic is around 5.6-5.9 FDR it depends he long is the straight.
Originally Posted by 2Quick View Post
Does anyone have a good CHEAT MODE setup for 13.5 Ballistic with MMP on a 75M straight.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 11-03-2010, 01:44 PM   #1323
macdude's Avatar
Default Spec Mode
Just wondering if anyone has been racing in spec mode. I am getting ready for a big race and was wondering what FDR people are running in 17.5 TC spec mode with the mamba. I was getting down into the 3.5 range with the novak kinetic controller. But the mamba always seems to have more rip and I haven't had a chance to do a back to back comparison at the track and was just wondering what others are running.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 11-03-2010, 01:47 PM   #1324
macdude's Avatar
If you bought it new there is a coupon in the box for a free link. The older link that you are talking about is a just a USB cable with a 4 pin connector on one end. Most digital camera's come with this type of cable. The mamba max actually had a USB adapter built into it. The Pro does not, that is why you need the adapter. If you bought it used you can still buy the castle link on the web at any number of hobby shops. But it will come with the usb cable and disc.
Old 11-03-2010, 06:06 PM   #1325
im was running the mmp on spec mode....
tc4
duo 2...timing all the way up on the motor
fdr 4.08
on a 90 x48 carpet track
the speed was good all over the track..& lots of punch in the infield
plus i have power on low
punch disable
no drag brake
hope this helps
starrx is offline   Reply With Quote
Old 11-04-2010, 12:15 PM   #1326
Thanx man
Where did you post the setup's ?
2Quick is offline   Reply With Quote
Old 12-02-2010, 06:24 PM   #1327
macdude's Avatar
tc4
fdr 4.08
punch disable
no drag brake
hope this helps
I ended up running a ballistic motor with the mamba. I started with the Kinetic, but it just seemed to slow. So switched back to the mamba and it was better. I switch from a duo 3 motor back to the ballistic motor and it was better yet. After talking to a bunch of the guy that had faster cars most were running way higher FDR's than I started with. I ended up in the 4.8 -5.0 range of FDR and the car was very good. The guy that won the stock main did it with a FDR of 5.44, this is without ESC timing.
Old 12-02-2010, 09:25 PM   #1328
what size track??
Old 12-03-2010, 04:41 AM   #1329
macdude's Avatar
what size track??
I believe is was 84 x 40.
Old 12-03-2010, 07:06 AM   #1330
jag88's Avatar
Originally Posted by jag88 View Post
That's good news but how long before a new (hopefully smaller) speedo appears ?
LRP's new speedo(s) just came out.
Thanks.
Originally Posted by pdelcast View Post
Beta testing now.
so is this gonna happen ?????
jag88 is offline   Reply With Quote
Old 12-08-2010, 01:14 AM   #1331
Pulse_'s Avatar
hello,
is there any reason to run a mamba max pro rather than a rx8 ESC on a light e-converted 808 (excepted the price)?
https://www.youtube.com/channel/UC1CAwFfuz1K3chBSVpIlSew
Pulse_ is offline   Reply With Quote
Old 01-02-2011, 08:43 AM   #1332
Born2Run's Avatar
Is this thread dying or is already dead?
Whatever
Born2Run is offline   Reply With Quote
Old 01-02-2011, 11:36 AM   #1333
Trader Rating: 46 (94%+)
can any one tell me what the blue tag that says new stock n the recever wire means?
tcb22185 is offline   Reply With Quote
Old 01-02-2011, 01:28 PM   #1334
Jochim_18's Avatar
Mamba needs to update their firmware and a smaller footprint.
Old 01-02-2011, 05:56 PM   #1335
macdude's Avatar
Updated firmware would be nice. However I don't think it needs to be smaller. If they just added solder tabs I would happy. Every other ESC out right now is just as big if not bigger. With the exception of the Tekin. I would like a better case design, but other than that the size is fine. If they could shrink it to the tekin size then I think we would no longer be able to run it in 1/8 scale.
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18801 04-23-2017 03:49 PM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
