Old 08-25-2010, 01:47 PM   #1276
js058515's Avatar
Originally Posted by Leroifittipalde View Post
Just ordered my MMP yesterday. Anyone know if the programing sofware is mac compatable? Im assuming its pc only.
PC and you need to follow a few sequences when installing depending on your OS. Mine runs fine on Win 7 64. Castle's site has the specifics for install I believe.
js058515 is offline   Reply With Quote
Old 08-25-2010, 02:12 PM   #1277
Leroifittipalde's Avatar
Send a message via AIM to Leroifittipalde Send a message via Yahoo to Leroifittipalde
Thanks, my laptop PC recently crashed. Guess itll be going back to dell sooner than later.
-ZIM
TRF 416//TA05 IFS//ABC Genetic//3Racing F1-09//Yokomo MR4 Rallye
Leroifittipalde is offline   Reply With Quote
Old 08-25-2010, 02:19 PM   #1278
js058515's Avatar
Netbook dude, your not a true EP guy without one....j/k. Can you believe a laptop can be cheaper than a cell phone (well Smart Phone w/o a contract).
Old 08-25-2010, 03:45 PM   #1279
Yeah, pretty inespensive. Ive been looking around for one. Maybe castle will make a software version that allows you to program from a smart phone...id try that.
-ZIM
Old 08-29-2010, 01:05 PM   #1280
js058515's Avatar
I am not looking to buy another 1 Cell MMP, but I found this on eBay.
http://cgi.ebay.com/CASTLE-CREATIONS...ht_1431wt_1136
This is a very good deal w/o coupons or codes. So if your in the market for one jump on it! Hope I am able to help a fellow RCTech member.
Old 08-29-2010, 02:40 PM   #1281
phisher's Avatar
Trader Rating: 14 (100%+)
I put a MMP into a Tamiya Evo IV touring car with a Tekin Redline 4.5. I'm looking at using this for a parking lot basher (top speed) and wanted to know how much I can advance the timing. Currently I have it set to 18 degrees at 10K + rpm and the temps are around 120 degrees F. How far can I go? With my current setting I'm shooting in the dark. I know I should be concerned with temperatures. Thoughts? Suggestions? Does anyone have a good set up for top speed?
www.MichiganRC.net
phisher is offline   Reply With Quote
Old 08-29-2010, 04:34 PM   #1282
macdude's Avatar
If you are looking at going fast in a straight line. I would start with a FDR of around 7-8. Then I would slowly increase the timing until you are getting the motor to the 150F mark. If that is still not fast enough try lowering the FDR, but watch your temps. The 4.5 is fast without timing, with timing it should launch you into outer-space.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 08-30-2010, 05:16 AM   #1283
phisher's Avatar
Honestly, the 4.5 seemed fasted without any ESC timing but, maybe it was my perception.
www.MichiganRC.net
Old 08-30-2010, 07:26 AM   #1284
macdude's Avatar
What RPM range are you using. I wouldn't start until 20K-25K based on what the motor is suppose to spin. The other thing to think about is that as you get get close to the 80K-90K RPM you are approaching the physical limit of the rotor. The only rotors rated for more are the motors that come from castle. I have a 9000kv motor from castle and well, I don't use it for anything as it is just too fast to be controllable. I thought about putting in my TC and then running it in a drag, but I can get a 17.5 with timing to do 55 MPH so, I am thinking that going 70-80 MPH or more with a TC well that is just too much. Its fun, but I am sure that it would be short lived as at that speed something is bound to give.
Old 08-30-2010, 07:35 AM   #1285
phisher's Avatar
I think I have it starting at 12K. From what you're saying, that is too low. I will set it higher.
www.MichiganRC.net
Old 08-31-2010, 10:36 AM   #1286
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
for 1/12 scale usage, is it possible to still use the regular MM Pro? I am assuming the man issue was its size.
For 1/10 WGT, should be straight forward as well, no size concern?
And anyone got pics or links to pics to the standard MM Pro mounted in a 1/12 and WGT Car?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 08-31-2010, 11:08 AM   #1287
js058515's Avatar
Ditto! My next 2 projects are a CRC 1/10 and 1/12 with the MMP in the 1/10 and the MMP 1cell in the 1/12. I would love to get some electronics layouts.
Old 09-02-2010, 01:40 AM   #1288
KKKWAN's Avatar
currently, I now using MMP 1 Cell version on my R12L3
found interesting as the battery on one side and the MMP on the other side (T-Bar version 1/12)
so far seem very good.
just feel a bit trouble need to add a booster for my servo / receiver
I really love the MMP smooth performance on 1 cell
KKKWAN is offline   Reply With Quote
Old 09-02-2010, 06:51 AM   #1289
Tech Legend
Cain's Avatar
need to call castle, got a message that the field programmer is backordered, really wish they would have that posted when you order. Now have to see if I can get a castlelink ASAP.
Old 09-03-2010, 05:36 PM   #1290
Luppi Stefano's Avatar
This sunday I want Try LRP X12 10,5 Stock Spec with MMP
track: Fast
which setup use?
motor timing or ?
thanks guys
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18835 09-11-2017 07:44 AM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
