Old 07-25-2010, 11:31 AM   #1201
Jochim_18's Avatar
I don't have any issues with firmware ver. 1.28 with MMP/Novak ballistic combo...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 07-26-2010, 05:30 AM   #1202
Well there is obviously something wrong because I dont have a motor glitching problem with earlier versions of the firmware. Any suggestions.
2Quick is offline   Reply With Quote
Old 07-26-2010, 08:11 AM   #1203
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
It can be many things and the software is just one of the many different things it could be. Bas sensor wire, bad board or board starting to go bad in the motor, battery not up to the task, way over timed are just a few. Try an earlier software again and see if it stops the problem. Then put the newest firmware in and use the same timing settings and power settings as before and see what happens. Might need to try different motors if you have them just to see.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-26-2010, 10:27 AM   #1204
I tried firmware 1.26 and it worked fine. With ver. 1.28 the motor glitches low rev's with the same settings.
Here's my settings :
1. Punch control disabled
2. Torque limit disabled
3. Start power low
4. Cheat timing boost 35 degrees
5. Cheat activation range 8000 - 9200 rpm
with new 13.5 Ballistic
Old 07-26-2010, 11:11 AM   #1205
macdude's Avatar
3. Start power low
I am running both a ballistic 17.5 and the older SS 17.5 from novak. Neither is having a problem.
I would look at your end bell timing. Set it back at N and see if that helps. Or if it is already on N take it to the first hash mark.
Next I would unplug the sensor cable from the speed control and run the motor in sensorless mode. If this runs smooth then plug the cable back in and try again.
If this does not work recalibrate the speed control to the radio.
Turn off timing boost and see what happens.
I would also try increasing your BEC voltage to 6.0 v. The default is 5.5V which I think is too low for most 2.4 systems.
Like others have said I have not seen any glitchiness, with any of my motors on this version.
I find this version of the software to generally be the smoothest I have seen so far. I am currently running it in a TC, SC, Stadium Truck, and an 8th scale buggy. All four upgraded with out a problem.
Hope this helps.
Matt
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 07-26-2010, 02:22 PM   #1206
Send a message via Yahoo to nomaak
Can the mmp run properly even if one of the caps have fallen off?
nomaak is offline   Reply With Quote
Old 07-26-2010, 05:03 PM   #1207
haywood's Avatar
Trader Rating: 48 (100%+)
Default MMP
Can this speedo compete with the Tekin? I am asking because all I run is Tekin however I won a Castle MMP as a door prize and I am wondering if I should try it out or sell it. Thanks
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 07-26-2010, 08:30 PM   #1208
haywood's Avatar
Anyone?
Old 07-26-2010, 11:00 PM   #1209
Anyone?
On small to medium tracks, the MMP can hold its own against the likes of Tekin, HW, SP , but on larger tracks where the straight is 150ft+, then it cant keep up.
MoonTrap is offline   Reply With Quote
Old 07-27-2010, 06:31 AM   #1210
wyd
Tech Legend
wyd's Avatar
Anyone?
It suffers on long straight tracks at this time without having the secondary timing or turbo like many call it but that will be the next update for Castle so it will be competitive on all tracks as soon as the new timing software comes out. Right now on small and medium tracks keeping up isn't a problem at all as what I loose on a straight with the extra punch the Castle has in the infield I have make up the time in that area.
With any speedo you can update the software the companies will always be working on software to make them do more overall and go faster.
Old 07-27-2010, 10:58 AM   #1211
Hope this helps.
Matt
Happy Me
I unplugged the sensor cable from the speed control and ran the motor in sensorless mode. I then plugged the cable back in and tried again. No more glitching.
Thanx a lot Matt...much appreciated.
Old 07-27-2010, 07:15 PM   #1212
macdude's Avatar
Happy Me
Your welcome. Glad to help.
Old 07-28-2010, 12:59 AM   #1213
Hi all,
I am rather new with this great esc and I am trying to understand the CHEAT mode and having to give up a min and max RPM's. I selected 30o and the default RPM settings, but after reading some reactions on this thread, I understand it is betting to change this.
I have a 13.5 turns Graupner motor max 18.200 RPM. Xray T2 and a gear ratio of 7.5. What is de best setting on a medium track for a beginning driver?
tnx
ps sorry for my English (I am dutch)
Friit is offline   Reply With Quote
Old 07-28-2010, 01:24 AM   #1214
KweetNiet's Avatar
Did anybody do the Kv test already? I did and the result I got for my Speed Passion 13.5R Competition V3.0 was 2817 Kv.
Our stock drivers go around with a 3000Kv, a set with the SP stock ECS. Now it looks like they have the better motor
KweetNiet is offline   Reply With Quote
Old 07-28-2010, 01:29 AM   #1215
KweetNiet's Avatar
Originally Posted by cloudy2010 View Post
better motor? are u sure for that??
I'll see if I can get one on to do the test, then we will know.
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18801 04-23-2017 03:49 PM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
