Old 11-30-2009, 09:11 PM   #106
05tuonojoe's Avatar
If you have the castlelink you need to update your firmware. I had the same problem with my DX3s as far as calibration until I updated. Now no problems.
Joe Walllace
Associated RC8B, RC8T
Houston engine service Novarossi +4
05tuonojoe is offline   Reply With Quote
Old 12-01-2009, 06:56 AM   #107
Originally Posted by jkirkwood View Post
Is the 1s version being designed to fit in a 1/12th scale without grinding fins and stuff to clear the body?
I doubt that they've had time to retool the case and/or heatsink for 12th. I was looking at mine last night and it looks like it might actually fit. At least under the new Protoform body. Without the Fan and a little cutting above the caps.
I'm looking at machining a new case up though. The board is actually about the same size as the old Sphere Comp. Just a couple of mm taller with the heatsink. If we didn't have the large case it wouldn't be that big actually. Plus there's no external cap to screw with.
Fred_B is offline   Reply With Quote
Old 12-01-2009, 07:09 AM   #108
ali_g's Avatar
guys can mamba max pro be used for brushed motor?
ali_g is offline   Reply With Quote
Old 12-01-2009, 07:44 AM   #109
cyanyde's Avatar
yes
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 12-01-2009, 10:06 AM   #110
MikeL.'s Avatar
The heatsink will be the same. If we design a new heatsink it would be a long time before you got one. They will however come with no fan and will have solder posts instead of wires for the motor.
MikeL. is offline   Reply With Quote
Old 12-01-2009, 12:36 PM   #111
Solder posts... Excellent.
Anyone that's changed the wires out knows that it's a real pain.
I honestly think that the heatsink will clear. If not, it won't be the first time I've had a speedo mounted in the mill to shorten things up for 12th.
Old 12-01-2009, 12:40 PM   #112
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
HEY!!! Get back to that four letter word known as work FRED!!!
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 12-01-2009, 12:45 PM   #113
have installed the mmp in my 416we car, man its HUGE!! will have to get a low profile servo to be able to get everything in place (dont want to have the receiver on the servo..)
Hatebreed is offline   Reply With Quote
Old 12-01-2009, 12:48 PM   #114
geeunit1014's Avatar
I know there were a few people @ indoor champs over the weekend running MMP's in 1/12ths. Not sure where they ended up however.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 12-01-2009, 12:52 PM   #115
iPearl's Avatar
Trader Rating: 94 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
I have one, been running it, for the price i am very happy.
Few question and thoughts i have about.
Brakes are a tad bit weak with the latest non beta software.
The beta release seems to have a little more brake power.
Does this thing have hybrid drive
(Sonsored on start and sensorless once going)
B/C compared to my SP1.1 it is as smooth but
MMPro has more punch through out the low to mid bandwith
but SP has more punch on the high end.
I was thinking if this hybrid drive makes a difference in it and if MMPro has it.
Overall happy with it.
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 12-01-2009, 12:59 PM   #116
That's the beauty of running so many engine models. I can work and check out the boards.
Old 12-01-2009, 01:07 PM   #117
I think it's sensored only when you use CHEAT mode. I've actually been turning the brakes down on the thing because I'm running dirt at the moment.
If the brakes are weak, try this. Crank even more timing into CHEAT mode and gear down. The more you gear down the more brakes you'll have (until it breaks loose and the tires lock up).
The cave man way of getting more brakes is to run it with reverse enabled. Then adjust the amount of reverse % you have available to keep it from acting all funny. This was my double secret way of getting the Tekin to stop in sedan outdoors...
Almost forgot, you can also change the brake curve to have more brake at the beginning. I don't mess with the whole curve, Just pick one point to give it more brake at the beginning of the curve.
Old 12-03-2009, 11:15 AM   #118
jkirkwood's Avatar
Thanks for the response.
SMC Racing | AKA Products | Serpent America | Android Nitro Runtime Calculator
jkirkwood is offline   Reply With Quote
Old 12-03-2009, 01:26 PM   #119
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
It does offer the hybrid type drive but when you use that setup you can't use the extra timing the cheat mode provides. In the hybrid mode the max timing you can get is 20 degrees plus whatever you motor has.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 12-03-2009, 01:55 PM   #120
RCMits's Avatar
Trader Rating: 23 (100%+)
Originally Posted by robk View Post
Apparently they are using it for 1s in oval racing, but there is some mods. They are removing the voltage regulator, I believe. Supposedly it's very fast, though, so I'm sure the info will be out soon.
special make.. im sure they'll come out with a production one if it flies..
http://www.castlecreations.com/produ...o-onecell.html
RCMits is offline   Reply With Quote
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18797 12-21-2016 05:07 PM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
