Old 07-15-2010, 01:58 PM   #1156
geeunit1014's Avatar
Originally Posted by tudor_47 View Post
THanks!
I'll have a go at your setup on our track. your FDR at 8,6 is that on a touring car?
I am driving a pan car (Xray X10 link) so my FDR will be different..
Oh, How do you set the rpm range? Seem to remember there beeing set values in the program....
Thanks!
/Johnny
Yes, that is with a Touring car. To set the RPM range, there is a "custom" box, you enter your starting RPM, and then select the end RPM. Also, if you are running 1S lipo in your pan car, you may want to lower the RPM ranges, since 1S is slower.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 07-18-2010, 06:18 AM   #1157
hope somebody can help me.......i run a tc4 & i tryed a oneway in it...here the problem...when im @ full throttle & i let off the car spin out...i think its the esc shifting down from the rpm range...... how do i smooth it out....my brake are @ 20% i have no drag brake in it & my rpm range is 7,500 to 15,100...i hope someone understand what im tryna say
starrx is offline   Reply With Quote
Old 07-19-2010, 02:56 PM   #1158
Jochim_18's Avatar
I end up with this setting last race:
MMP profile = CHEAT Mode
Punch control = Disabled
Start power = High
MMP Timing = 50 degree
Throttle = Positive Curve
RPM = Start 7,500 end 13,500
Motor = Novak Ballistic 17.5
Motor Timing = 40 degree
Track size = 100x40 approximate
Chassis = Team magic E4
FDR = 5.6
With this setup I'm as fast as tekins and LRP but for some reason I lost my bottom end.
I'm just looking at at the castle website and they have the CURRENT CASTLE LINK VERSION: 3.254
RELEASE DATE: 07-19-10
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 07-19-2010, 03:21 PM   #1159
pdelcast's Avatar
New software revision today (7-19) includes wheel torque control -- not some wussy "timing delay," but true torque control.
pdelcast is offline   Reply With Quote
Old 07-19-2010, 03:36 PM   #1160
snellemin's Avatar
Trader Rating: 16 (100%+)
Finally!!!!
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
Old 07-19-2010, 03:46 PM   #1161
TryHard's Avatar
Excellent... new software for the national
Any other changes we should be aware of?
Cheers
Ed
Old 07-19-2010, 04:00 PM   #1162
Jochim_18's Avatar
I got mine downloaded guys the more torque the motor produce means more power oh yeah!!!! too bad I can't test it till next weekend. This really suites novak motor since it's a torque motor...
Old 07-19-2010, 04:05 PM   #1163
Jochim_18's Avatar
pdelcast,
couple of question:
1. Will the motor produce more over all power with the new firmware?
2. How do you setup the Torque limiter base on the motor KV mainly on stock motor (17.5)?
Old 07-19-2010, 04:22 PM   #1164
Cool, will try the new firmware update. So far having pretty good luck with my MMP running 17.5 TC class. As others have mentioned I have more off the line punch than other ESCs.
However I do have an issue someone else might have encountered. After a minute or two of running I keep experiencing what feels like brief power drops and inconsistent throttle response. As I'm coming off a straight into a corner I'll tap the brakes and then jump back on the throttle, but there seems to be a short delay before the power comes back on. Sometimes it does it, others it doesn't. It really has been the one glitch that is causing me to lose races as I am just as fast as others I am competing with, but all it takes is a fraction of a second where the car isn't doing what I want it to do and I'm falling behind. Thought it might be my radio as we have had problems with Futaba's bleeding over the Spektrums signals at the track but it did it to me just tooling around the street in front of my house. Anyone else experience this sort of thing?
Ferenczy36 is offline   Reply With Quote
Old 07-19-2010, 05:02 PM   #1165
Originally Posted by Jochim_18 View Post
pdelcast,
couple of question:
This should be really good for the off road guys , as for on road lets wait and see.
Now more timing is it next.
Robitronic Avid / Avid V2
Tekin RS pro / Viper 10.5/MMP/6900
AE B44- MMP/Hacker 10.5/6900 Castle
IP 5000/50 SMC 5200/40/50
Casino Kid is offline   Reply With Quote
Old 07-19-2010, 05:02 PM   #1166
Jochim_18's Avatar
check your sensor wire...
Old 07-19-2010, 07:09 PM   #1167
ok i did the torque test on a 17.5 duo 2..& it came up 2188..can somebody tell me what do that mean..im lost..thanks!!
Old 07-19-2010, 07:58 PM   #1168
Jochim_18's Avatar
that will be the KV of your motor the higher the KV means more power and faster motor... my Ballistic only reach 2048 KV
Old 07-19-2010, 09:20 PM   #1169
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Start power = High
FDR = 5.6
Try running your rpm range at 5000 to 15100 and seen what happens. That is how mine is set right now for a track about the same size as yours. Did you end up faster than before as I know you where looking for a little more speed and it seems with the newer rpm range you getting it.
How hot is your motor getting with this setup? Try my rpm range and see if you see any difference. Maybe try a littler higher gearing like 6.0 or so to get more lowend.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-19-2010, 09:24 PM   #1170
wyd
Tech Legend
wyd's Avatar
The new software is interesting. Can't run for about 2 weeks but will be ineterested in seeing how it changes things. Do like the new print feature to make it easy to keep track of things.
The new power and torque stuff is interesting as well. Will be nice to mess around with them as well.
I would say Castle is heading in the right direction. Very nice updates to cover a wide range of users.
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18817 07-17-2017 07:08 PM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
