Old 07-07-2010, 07:07 AM   #1141
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by Jochim_18 View Post
I will give it a try again next weekend.
Use the old motor just to if you see any difference on how it runs in the infield and straights. I think you will find it runs a little cooler, more punch in the infield and will apply the timing over a broader band on the straight so it should pull hard alot longer for you.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-07-2010, 10:56 AM   #1142
geeunit1014's Avatar
Originally Posted by tudor_47 View Post
I too have a 5,5T motor, what were your settings for this motor?
The track I ran was quite small (only 100ft straight).
Setup:
CHEAT Mode:
4* timing
17,000-39,500 range
Med. start power
20% punch control
10% drag brake
100% brake
Motor was an LRP X12 5.5, timing fully retarded in motor, 8.6 FDR
Motor ran on the warmer side, about 170* after 6mins, was probably overgeared for the smaller track. For a bigger track, I would first add some gear, and a maybe a little more timing, but probably not more than 10* in ESC. You could also choose to go with a slower motor (say a 7.5), and more timing advance, this would give better forward traction (not as brutal bottom end). Overall I was happy, tons of power, but smooth delivery. Just very fast
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 07-13-2010, 03:23 AM   #1143
KweetNiet's Avatar
Originally Posted by pdelcast View Post
Coming soon
Is there any news on the new software? I'm really running way behind now on the tekin and hobywing guys on top speed (260ft straight), running it with the same SP 13.5t as they do. Halfway the straight they just push extra revs out of their system I can not keep up with.
KweetNiet is offline   Reply With Quote
Old 07-13-2010, 06:47 AM   #1144
Jochim_18's Avatar
I'm with you Tekins are killing me on the straight.. But I will try a broader RPM range and see if it helps me to get more top end.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 07-13-2010, 09:14 AM   #1145
Its not just the Tekins, but also the new hobbywing firmware that just blows past onthe straight. Castle has been promising for many months of new software, when i brought this issue up over 2.5 months back pdelcast said "soon" , to me that is not soon, i have a feeling they not going to bring any new faster software to keep up, now with the ROAR no timing thing!. Over 5 months ago pdelcast even said they are working on new timing ramps to keep with the Tekins, but this has also not happend ..
I love my MMP, and have changed my setup on the ESC and am equal with the other ESC's on medium sized tracks
CHEAT : 50
RPM : 4000 - 8600
Motor : SP V3 17.5
I used to run the motor in the middle timing with a 4.9/5.0 FDR , have now changed it to full motor timing with a 5.5/5.6 FDR , and the car is quick, and is equal to the other ESC's on medium tracks with a 150ft straight. I found with less motor timing, the motor isnt as fast as the other ESC's on the straight due to them having a turbo, but with more motor timing i am equal. Motor comes off at 140F.
MoonTrap is offline   Reply With Quote
Old 07-13-2010, 11:03 AM   #1146
wyd
Tech Legend
wyd's Avatar
CHEAT : 50
RPM : 4000 - 8600
Motor : SP V3 17.5
They are working on it along with some other new products as well. It the owner says they are working on new programing then the engineers are working on it.
It took Castle making the MMP with the adjustable RPM range to be the fastest esc when it came out, then all others copied that rpm range timing setup so know when Castle once again comes out with something better (even if we have to wait) I would guess that once again it will be better and all other brands will scramble once again to copy it. Main difference is Castle just don't race and have many other products under development on their plate so it takes a little time.
Old 07-13-2010, 06:03 PM   #1147
RCMADMAN's Avatar
Trader Rating: 23 (100%+)
I have bolted the Tekin back in for now. Need the speed! but I will leave the Mamba in my pitbox and as soon as the new software is out I will bang it back in there!
My Crime----RC10R5----MAMBA----KO----FUTABA----TAMIYA----ARROW XE-28----KT100S
My Defence "Wouldn't you rather me play with my Toys than go out to a pub drinking?"
RCMADMAN is offline   Reply With Quote
Old 07-13-2010, 08:02 PM   #1148
wyd
Tech Legend
wyd's Avatar
I'm waiting to. I know its coming and will be worth the wait. Not a huge deal for me as I still mainly race for fun but as soon as the new stuff is out I will be downloading it.
Old 07-13-2010, 08:17 PM   #1149
Jochim_18's Avatar
Waiting patiently guys... But if nothing happens quick I'm going to get the Novak kinetic that should be out by the end of the month..
Old 07-13-2010, 10:54 PM   #1150
We are all waiting patiently, and have been for over 6 months. I love my MMP, and would hate to have to change.. I think if we had some kind of time line, instead of "soon" , it would put a bit of ease on our minds, that we haven't been forgotten
Old 07-14-2010, 12:11 AM   #1151
tudor_47's Avatar
Setup:
CHEAT Mode:
4* timing
17,000-39,500 range
Med. start power
20% punch control
10% drag brake
100% brake
THanks!
I'll have a go at your setup on our track. your FDR at 8,6 is that on a touring car?
I am driving a pan car (Xray X10 link) so my FDR will be different..
Oh, How do you set the rpm range? Seem to remember there beeing set values in the program....
Thanks!
/Johnny
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 07-14-2010, 04:35 AM   #1152
KweetNiet's Avatar
That I forgot to mention aswell. The other MMP driver on my club now changed his for the HW ESC. Instead of 76 km/h on the straight he now also goes 80+ like the Tekin boys. A lot more guys are now looking at the HW ESC, low price and (for now) good performance.
I also do not want to change, but being overtaken by others with 10+ km/h on the straight does hurt. I can just not keep up.
Old 07-14-2010, 06:46 AM   #1153
Jochim_18's Avatar
It' does sucks when you know you have the car that can compete but don't have the speed. I was a 1.5 second slower and all the tekin guys just blow past by me on the straight.
Old 07-15-2010, 07:25 AM   #1154
macdude's Avatar
How long is your straight. I am still as fast as the tekins where I race. But the straight is only 76ft. inside. I am assuming that the complaint is that you don't continue to accelerate to the end of your straight. The other question that I have is why can't you just gear up a little to make your car have a higher top end. So even though you are getting less revs than a TK or HW you would still be matching the top speed. As I have a MMP I know it has tons of rip, no matter what gearing I use, so in the infield the taller gearing should still work. Obviously you would have to change a little the way you drive as I am sure it would feel different. But I have to think that it is possible to match the top speed of the HW or TK.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 07-15-2010, 11:18 AM   #1155
Born2Run's Avatar
+1 With my MMP on FDR 4.0 with my 17.5 im as fast as the SP & HW on a straight of 65meters.
Whatever
Born2Run is offline   Reply With Quote
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18801 04-23-2017 03:49 PM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
