Old 05-31-2010, 10:25 PM   #1081
RCMADMAN's Avatar
Trader Rating: 23 (100%+)
Is there any advantage to upgrade from Castleink V3.251?
Im running a mamba max pro in 17.5 stock with cheat mode activated. Cheers
My Crime----RC10R5----MAMBA----KO----FUTABA----TAMIYA----ARROW XE-28----KT100S
My Defence "Wouldn't you rather me play with my Toys than go out to a pub drinking?"
RCMADMAN is offline   Reply With Quote
Old 06-01-2010, 12:30 PM   #1082
macdude's Avatar
From the castle site:
3.251 Added Mamba Max Pro 1 Cell controller to Field Link programmer
Bug Fix - HPI Blur controllers incorrectly showed that a new version of software was availabl
e
3.253 :Added firmware V1.26
So no there doesn't really seem to be a reason.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 06-01-2010, 12:41 PM   #1083
Jochim_18's Avatar
This all depends on your track size if it's big and flowing gear it at 5.0 - 5.5 FDR if it's small or medium size track gear your motor at 6.0 - 7.0... Motor runs hotter if it's under geared specially with the use of timing advance. Their is always a sweet spot on every motor and you need to find that.
Seems to be working well. My motor is getting hot quick though have had to bring my FDR closer to 7
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 06-01-2010, 02:32 PM   #1084
geeunit1014's Avatar
Originally Posted by geeunit1014 View Post
I will say for this weekend im starting with a range of 6,000-30,000 for my 13.5. I may stretch it out even further depending on how it goes, as I havent had any experience with 13.5 and this ESC yet.
I ended up with a range of 5900 to 25000 IIRC (this was for 13.5), I just had problems with the cars handling and my transponder missing laps that but me down in the B, although I did salvage a 3rd place finish in the B.
If you dont have a fan on the motor, get one. Its worth about a 20* drop in temps.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 06-01-2010, 02:54 PM   #1085
RCMADMAN's Avatar
Thanks guys. I am very happy with this speed control. Since I am the ONLY one running it at my club it makes it a bit hard to get it right as I have to do all the testing!
Old 06-01-2010, 02:56 PM   #1086
RCMADMAN's Avatar
Also how do you stretch it out further? 5900 to 25000?
My version only allows me to pick start and finish at the moment it is
5000 - 15100
Old 06-01-2010, 03:10 PM   #1087
5000 - 15100
When you go to select the range, hit custom, and then the up and down arrows for the start RPM, and then the drop down box for the end RPM options
Mike Gee
Old 06-02-2010, 11:09 AM   #1088
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
geeunit1014 how was your speed down the straights at Jackson compared to the others? I didn't get to make it but looks like I can run the race at Frederick and Trains and Lanes in the upcoming weeks.
I don't have much time running my MMP so its still a learning process with gearing and all.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-02-2010, 11:37 AM   #1089
It was good, I was slightly down compared to the top guys(2-3 car lengths), but im very sure that was because of car handling, my car was a pile all day, and they ran a sweeper onto the straight, and I kept having to square it up because the car was a pile so I had no drive in the fastest part of the track. It seemed like the track was giving everyone but Haynes fits
Im thinking about going to Frederick's race. I would guess my 17.5 settings with around a 7 FDR should get you going real nice
Mike Gee
Old 06-02-2010, 11:55 AM   #1090
wyd
Tech Legend
wyd's Avatar
Yeah if you have to check up in the middle like that I'm sure it kills you speed at the end.
Right now I'm at I think 6.76 with 42 degrees of cheat and right around 5000 to 15000k for the rpm. I will have to check the that for sure but that is with the DUO in the 2nd timing hole. I have a brand new LRP 17.5 I have yet to even try and I still have a Novak 17.5 Ballistic as well that I have not ran that much.
My TC5 should be better this time at Frederick because I made a rear camberlink change that should really help loosen the car up a tad and get me that steering I was missing last time I went to Frederick.
Old 06-02-2010, 12:51 PM   #1091
Id love to be able to try an LRP crazy fast, and loves high temps
Mike Gee
Old 06-02-2010, 03:12 PM   #1092
RCMADMAN's Avatar
I did some more testing yetaerday my FDr is at 6.2 atm. I am going to have a few more runs today and try to drop FDR to high 5s. I am loving this speed control so far. Hopefuly give some tekins a run for there money this sunday
Old 06-02-2010, 03:40 PM   #1093
Joe Ford's Avatar
Send a message via AIM to Joe Ford
e
v1.26 of the software makes it so when you are not using the CHEAT mode the yellow LED on the Max Pro will flash when the vehicle is in neutral. It will be solid yellow if CHEAT is activated. This is for ROAR rules, and makes it easier to tech. So there IS a reason to upgrade IF you run ROAR rules and your track requires you to have this feature.
Joe Ford
Product Specialist
Castle Creations
Joe Ford is offline   Reply With Quote
Old 06-02-2010, 05:13 PM   #1094
wyd
Tech Legend
wyd's Avatar
Will see what happens. I don't run much so we might not see too much speed from me.
Old 06-02-2010, 07:30 PM   #1095
X12's are whats favored by the whose who around here You can run the snot out of them, 220 is a normal temp for them
Mike Gee
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18835 09-11-2017 07:44 AM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
