Old 11-20-2009, 02:58 AM   #76
cyanyde's Avatar
So any test reports anyone? How does it perform with stock motors? How does it compare to SPX and RS Pro's?
cyanyde is offline   Reply With Quote
Old 11-20-2009, 10:54 AM   #77
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
what 13.5 motor would you guys recommend that will work best with mamba max pro ? i just picked one up today and need your opinion on brushless motor suggestion ..any input is much appreciated.
just to clarify, mamba will work with both sesored and sensorless motors yeh ?
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 11-20-2009, 12:54 PM   #78
sportpak's Avatar
Trader Rating: 26 (100%+)
After all this screwing around, I might have a bad servo. I ran a separate BEC and receiver battery and the problem went away. The Castle people said this speed control has a brute of a BEC, and suggested trying a different servo. BEC is constructed in a way it either works, or it doesn't.
I plugged in an old scab Hitec 5925 servo and tried to stall it out. I used pliers and sawed back and forth on the servo stem and the thing never kicked out. The servo was screaming bloody murder. I plugged the Airtronics back in, one flip of the horn and the Spectrum shut off again.
So today I am going to pick up a new servo and hope it's all better.
I'm a little shocked, that shows how manly the Tekin BEC is. I never had this problem before. I really hope I can be done with it and get back to racing.
Ben
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 11-22-2009, 08:45 AM   #79
ordered one, all those features for just $118 made me throw out my losi esc. just wonder how i should place it in my 416 car, std size servo and std size spektrum reciever.. will probably have to get a low profile servo and one of those spektrum mini recievers..
Hatebreed is offline   Reply With Quote
Old 11-22-2009, 09:43 AM   #80
Ben
It might be the bec circuit is set at 5.5v spektrum does not like to be below 6v you can change that using your castle link. I also installed one of these for extra precaution
Spektrum Voltage Protector
Overview
Spektrum's new Voltage Protector prevents a DSMô receiver's voltage from dropping below the proper operating level in lower voltage applications such as 4-cell 1/12 carpet racers. Installation is as simple as plugging it into an open channel slot on the receiver unit.
Smokinnitro is offline   Reply With Quote
Old 11-23-2009, 05:52 AM   #81
The Rev's Avatar
Test report:
Just used my new mm pro yesterday in 13.5 rubber carpet touring .
Setup: 35 deg. timing in cheat mode. boost at default setting, novak ballistic @ 0 deg. timing.
bottom line: the car was sick fast. i realize now why ROAR went with 13.5 for super stock. The timing advance the new speedos have make these motors scream.
The fan never turned on after 8 minutes. Motor did hit 170 though.
Both MM pros at the track appeared to be the fastest cars on the track out of 12 cars. Both used 35 deg. timing; boost settings were different.
Great job again Castle!
The Rev is offline   Reply With Quote
Old 11-23-2009, 07:09 AM   #82
speeddaddy's Avatar
Originally Posted by The Rev View Post
Test report:
How do you know the fan never turned on after 8 minutes?
If you can't fix it with a hammer, you've got an electrical problem.
RC Sailboat, 3RC planes, SC5m, Yuneec Typhoon Quadcopter
speeddaddy is offline   Reply With Quote
Old 11-23-2009, 09:04 AM   #83
The Rev's Avatar
it was not on at the end of the run. doubt it turned on before then.
Old 11-23-2009, 02:31 PM   #84
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
soooooo sc10 mmp 4600 what kind inturnal setting should i start with
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Old 11-23-2009, 04:10 PM   #85
Where did you find it for that price?
va.racer is offline   Reply With Quote
Old 11-23-2009, 04:15 PM   #86
Trader Rating: 83 (100%+)
On Tower with the codes it is only $113 shipped.
bigbeej is offline   Reply With Quote
Old 11-24-2009, 07:34 AM   #87
Jochim_18's Avatar
I tested my MAMBA MAX PRO with Novak Balistic 13.5 COMBO. Man this ESC is a monster the instant rip off the corner is crazy not to mention I'm only running a 25C Lipo. Two of us on the track with the same combo man it blows the competition away a lot of guys is running Tekin RS and LRP SPX....
And we got ours on mild setup.....
Here's my setup:
ESC profile = Cheat Mode
ESC = Castle Creation Mamba max pro
ESC Timing = @ 35 degree
Punch Control = Disabled (Max Rip)
RPM = 10,000 - 12,000
Motor = Novak Balistic 13.5
Motor Timing = +1 Notch toward positive side (35 degree)
Chassis = Schumacher MI3 with Exotek chassis
FDR = 4.2
ESC/Motor Temp = after 5 minutes race @ 150 - 155 degree F
I can do a lot more but my setup sucks last race so my car is loose, I can't really put the power on the ground, So I kept my ESC/Motor to mild drivable setup. But now I got the power and my car going fast again I can now concentrate on chassis setup.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 11-24-2009, 08:28 AM   #88
So can the fan and cover be removed from the MMP without cutting anything? Temped to try this esc in 17.5/1S 1/12th, but it won't fit under the body with the fan on it.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 11-24-2009, 08:42 AM   #89
sportpak's Avatar
You can unplug the fan, then you pop it off. It looks and feels like your gonna break it, but you won't. I took mine off for VTA, it's on there real good, but it'll come off.
Ben
Old 11-24-2009, 08:47 AM   #90
cyanyde's Avatar
Here's my setup:
FDR = 4.2
Thats awesome. Now when on earth is my Castle Link gonna be shipped to me. More than a week without any news nor reply to my email sent to them. Its time their customer service can 'dynamically' advance their timing too.
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18835 09-11-2017 07:44 AM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
