Castle Creations Mamba Max Pro Sensored ESC
#872
#874
At this point you send it back to Castle.At least you have another one for the stock.I don't have another
#875
Ok I tried the mmp with my x12 5,5t and if you give full throttle from a dead stop it stutters and cogs
But if yoy roll on the throttle its okay. But I'm running it with smart sense 8 deg and using a dx3r I've
Calibrated multiple times and same thing. It being really gay at the moment.
#876
Maybe you should let your girl pull the stick throttle for ya....your being too quick.....lol
#878
#879
Really? I know a couple guys running that combo with no problems. 13.5 and 17.5. I don't know off hand what they are running for end bell timing. But they are fast.
#880
As for running a 5.5 in Cheat mode, it seems the only way to go. I tried smart sense with my SP 5.5 and was very disappointed. My 10.5 in Cheat was faster. The 5.5 with Cheat is increadible. As much power as anyone could use. Now to find a good gearing/setting to be sure I can get 5min with decent temperatures.
#884
so here is the verdict smartsense is gay.. with an x12 that is .. i just took my field card and switch it to sensored only with 0deg cheat so its not adding anything and it cured my issue and also was faster with it in general. but also i was thinking if i figure out the right start rpm and end rpm i can simulate the way it would work in smart sense instead of the timing ramping it will stay at say 10 deg the entire time? i feel once that is figured out it would be real nice. my question is once the end rpm is reached does that timing continue to stay at the value that has been set from that point on ? i hope this is somewhat easy to understand? pretty much i just want maybe 10 deg max added from the esc in sensored only mode. thats what i amtrying to get at haha.
