Old 03-29-2010, 02:33 AM   #841
Originally Posted by Dragonfire View Post
At the end of the day pretty much every speedo's "turbo" system is just throwing more timing at the motor. The MMP has a system built in for this already so while they don't label it as a turbo system it does the same thing. The only thing they lack is the ability to set a starting point for the timing which on some motors should be higher than zero. This can however be done on your motor itself. This would also allow you to have more than 50 degrees total timing. Weather this works better or not will depend on how you use it.
I don't know about cogging issues with throttle curve as all this changes is how much throttle input = how much motor output as certain points.
Anyway I ran a MMP for the 1st time this weekend. 17.5 duo 1 at FDR 6.5 with 4600-13000 50 degrees. I didn't have a fan on the motor which limited things a bit but was able to run with the fastest Tekin in every way on the straight. I didn't see any difference and we had a battle happening for a little while. One big difference though was the launch at the start of the race. This thing MOVES off the line compared to the rest of the field. It was however much bigger which some ppl won't like and I noticed the brakes were weak at high rpm and strong down low. Kinda made it hard to consistently pull up into hairpins.
Anyway quite nice really.
I know most of the Turbo system's are throwing more timing at the motor, but other system's also have different ramps for these "Turbo's" and "Superchargers". What i would like is to be able to have some more cheat timing or a "Turbo" to add just a little more like 10 degrees.
I too like the amount of punch this thing has, it maybe a little big, but with the fan off its a bit easier to mount. At my track the MMP's are really dominating, which is awesome
MoonTrap is offline   Reply With Quote
Old 03-29-2010, 02:59 AM   #842
decibels's Avatar
Originally Posted by Jochim_18 View Post
installed a new MMP for my MOD car since my GTB when up in smoke but I'm having problem calibrating the ESC to my radio Ko Helios with Spek Pro... I haven't had this issues before...
The problem will most likely be that the 2.4ghz takes a while to start up and the speedy will turn on before hand and you need to use full throttle to calibrate the speedy. But when you use castle link you can change the arming time to 3 4 or 5 seconds and your radio will have binded properly by then.
Hope this helps!!
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 03-29-2010, 03:37 PM   #843
If you think you need more then try adding that 10 degrees to the motor and see how it goes.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 03-29-2010, 06:06 PM   #844
Ffejdat's Avatar
Hey all, ran my WGT car this weekend at the Minnesota state onroad champs, I WON WGT with my Mamba max pro, here are the setting I used...
cheat mode rpm from 2500 to 7600, timing max at 34 degrees, motor was an old Novak 13.5 with some timing advance at the endbell, rollout was 64.6 mm, I did not have much time to play with different setting, only one 5 minute practice, a 4 quals, i tried a higher timing advance but the motor faded bad, motor was about 160 on temp most runs, I was close to the fastest all day, one CRC Black diamond sponsered car was a little quicker, but had a rougher main... It was hard to try different settings, I am the only MMP driver around here... My ESC is a regular one modded to one cell...
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 03-29-2010, 07:05 PM   #845
Jochim_18's Avatar
Smile
I run MMP with LRP X12 13.5 this weekend it run very well against LRP and Tekin guys It was a good race racing with some fast guys on my track I have been conservative with my setup on ESC and motor since X12 brushless motor tends to over heat... I did very well even though I did not play with my setup much I still manage to keep up and I stii got the most punch out the corners. Untill the car hesitate on the straight and put my car on the wall...
well anyways I haven't been focusing on stock much lately I'm having a blast running mod.. It's getting bigger at my local track...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 03-29-2010, 07:14 PM   #846
geeunit1014's Avatar
X12 motors like to run hot, pretty much anything under 220*F is good
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 03-29-2010, 07:22 PM   #847
Jochim_18's Avatar
My temp was at 170-180 degree on X12 with 4 dot inserts (-10 degree timing) again I was just being conservative on my setup... Since I was mainly focusing on running MOD this weekend... But eventhough with a conservative setup car was a mesille except for the cogging issue cause of the positive throttle curve I have...
Old 03-29-2010, 10:00 PM   #848
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
I can't wait to run the x12 5,5t I just got in the mail this morning . So far I really like the mmp for mod. I havr been running a tekin redline 5,5t in the mean tme but the x12 should be better.
jeff jenkins is offline   Reply With Quote
Old 03-29-2010, 10:16 PM   #849
Jochim_18's Avatar
MOD is a lot of fun no more messing with ESC trying to find the Motor/esc combo of the week... All you have to is a really good setup and go fast... So far my MI4 is hooked-up I TQ last weekends race almost two laps ahead untill I burn up my GTB the fan went overheat the ESC and smoke it, So now I got a new MMP on my mod car...
Old 03-29-2010, 10:29 PM   #850
Nice... Yeah this summer should be a good outdoor season as it looks like mod is gaining popularity and also glad I don't have to mess with the speedo with laptops. So yea mods going to be awesome this year.
Old 03-30-2010, 03:04 PM   #851
Born2Run's Avatar
I used to run for a couple of years my GM 7T with my mamba max,sensorless of course, without any cogging issue.Now with the same motor and the Mamba Max Pro i have some cogging issue on start up.I tried both, sensored and sensorless mode but cogging is still there.With my 17.5T works great.Do i have to wait for some software update from Castle?
Whatever
Born2Run is offline   Reply With Quote
Old 04-01-2010, 09:36 AM   #852
Born2Run's Avatar
Is there anybody who runs low turn mod.sensored having cogging issues with the MMP or im the only one?
Whatever
Old 04-01-2010, 10:04 AM   #853
Probably your timing is to high.
Lower turn motor's don't like to much timing.
So how lower the turns on the motor, the mower you must set your timing.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 04-01-2010, 11:19 AM   #854
whoopass's Avatar
well i ran the mmp with a 13.5 lrp x.12 practise at our local track today at aldershot, hampshire and the car was a missile. on crap tyres xray 008 was pretty good. i was messing around with the drag brake and the cheat timing advance. initially ran it at 35 degs. went to 50 and felt like i could gear down about 3 teeth on 48dp!
changed back to 35 on the mmp and left the motor as kit timing, 2 dots i think. i did run some 3800 mah lipo and the mmp did not like them a bit. ran at about half speed after 1 minute. i did notice the mmp was pretty thursty on the 5000 40C lipo's. the motor after about 8-9 mins was 40/110 degs. so not hot at all. strange about the batts never had that before?
it did feel like the frag brake was delaying about.2 of a second on lift off, so i increased the drag brake to 110% and that cured it.
the mmp does take a little messing around, i set the cheat rpm initially at 10,000, that was a mistake as it revved out 1/3 down the straight!
on the whole, pretty happy.
ed/tryhard. we shall have to meet up at AMCC soon and swap notes. cheers .rob baxter
whoopass is offline   Reply With Quote
Old 04-01-2010, 11:30 AM   #855
Born2Run's Avatar
Timing on esc has been set on low and on the motor is in the middle position (under B) so i don't think it's to high.
Whatever
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18801 04-23-2017 03:49 PM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
