Old 03-24-2010, 11:35 PM   #826
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Originally Posted by macdude View Post
I think we can call the Tekin RS speedo's but the MMP's would have to be a very big pair of board shorts!
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 03-25-2010, 12:24 AM   #827
tudor_47's Avatar
Originally Posted by wyd View Post
Castle builds their speedo in house and it isn't made in some foreign country. It takes time to get them together. The first batch at 4000 plus units Castle thought would be enough but they sold so fast and the fact they had other speedos for planes to be built and a few other products so it has taken time to get more made.
Are shop currently has 6 MMP speedos in stock. We had 12 last week but sold 1/2 of them.
Thanks!
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 03-25-2010, 01:03 AM   #828
TryHard's Avatar
Just curious what tires are you running in the wet weather?
Always used to run 21mm wide pitshimuzi (sp?) wets, with the standard foam insert.
For our nationals, we have to run the Schumacher pre-glued wet tyre, I have no idea what the part number is mind.. I'll have a look and find out for you
Ed
EDIT - part number is XG-WET, 24mm wide pre-glued wet tyre
Old 03-25-2010, 01:27 AM   #829
TryHard's Avatar
Noticed you are running a radio Cap. Are you experiencing radio glitches with Mamba? It has variable voltage to the BEC circuit. I always set my higher as the radio and servo can hand the over 6V.
No problems with the mamba per se, just had some intermitent issues with my spektrum unit a while ago, so now run one as a matter of course.. More of an insurance policy if you will
HiH
Ed
Old 03-25-2010, 06:48 PM   #830
macdude's Avatar
HiH
Ed
OK, I had some issues when I first went brushless with the FM receivers, but I haven't had any issues with the 2.4 ones.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 03-26-2010, 10:13 AM   #831
HiH
Ed
I have seen the same recently with different winds but more so with low turns. I was running a big event back in january and had throttle control loss as often as 3 times a race! I think mayb I should look to a new receiver as maybe mine is dead. Might try the cap though as it used to be a standard thing for me not all that long ago.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 03-28-2010, 09:58 AM   #832
Born2Run's Avatar
I ran my MMP today for the first time with a 17.5T.I have no words to describe it,only a big smile in my face.Thanks Castle
Whatever
Born2Run is offline   Reply With Quote
Old 03-28-2010, 05:36 PM   #833
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I ran touring car for the first time since testing the MMP before it came out and it was incredable. I might be a tad slower in 17.5 with no turbo boost but in the infield and coming out of every corner my car would just spool up so fast compared to the others it was awesome. The car will benefit even more when I get it setup better thru the corners thats for sure.
Can't wait til I get to run my car again and really get it setup better so I can really benefit more from the MMP. Need to get the right tires but I can see the MMP is fast and has tons of room to grow.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 03-28-2010, 08:51 PM   #834
Jochim_18's Avatar
Man MMP has a bad cogging issue when you put a positive throttle curve.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 03-28-2010, 10:22 PM   #835
Jochim_18's Avatar
installed a new MMP for my MOD car since my GTB when up in smoke but I'm having problem calibrating the ESC to my radio Ko Helios with Spek Pro... I haven't had this issues before...
Old 03-28-2010, 10:35 PM   #836
Born2Run's Avatar
I have positive throttle curve without any cogging issue.Everything was perfect.
Whatever
Old 03-28-2010, 10:54 PM   #837
on the tracks i have raced, the MMP is just as fast on the straight as the Tekin v203. But a turbo feature on the MMP would be awesome, wyd do you know if castle is going to be releasing some new software soon for the MMP with some more grunt??
I run positive throttle curve and have no cogging at all, this is on SP v3, and even when i ran my old SP v2 motors, also no problems
MoonTrap is offline   Reply With Quote
Old 03-28-2010, 11:03 PM   #838
wyd
Tech Legend
wyd's Avatar
I'm not sure but I know they are always working on updates so would think they have something coming in the near future. I will be talking with them I hope next week so I know that is one of things I'm checking on.
To me the only time a Turbo boost is needed is on some of the longer tracks that have long straights but otherwise I don't think it is needed in alot of applications. My rip is awesome and will be even better the more I get my car setup. The more corner speedo I can get the moremy car will benefit from the rip I have.
Old 03-29-2010, 12:51 AM   #839
Robert_K's Avatar
A friend of mine drove the MMP at the LRP TCM this weekend. He got, due some grip issue's, to a 17the place... He said that it looked like he was the only MMP driver with all LRP's arround him. He hasn't seen any Tekins... But his speedo was really good with the LRP X12 13,5T motor. His start RPM was arround 10K.
Sounds pretty good to me. But then again, on really long flowing tracks I think the MMP could use an extra turbo...
Best Regards
Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 03-29-2010, 01:58 AM   #840
At the end of the day pretty much every speedo's "turbo" system is just throwing more timing at the motor. The MMP has a system built in for this already so while they don't label it as a turbo system it does the same thing. The only thing they lack is the ability to set a starting point for the timing which on some motors should be higher than zero. This can however be done on your motor itself. This would also allow you to have more than 50 degrees total timing. Weather this works better or not will depend on how you use it.
I don't know about cogging issues with throttle curve as all this changes is how much throttle input = how much motor output as certain points.
Anyway I ran a MMP for the 1st time this weekend. 17.5 duo 1 at FDR 6.5 with 4600-13000 50 degrees. I didn't have a fan on the motor which limited things a bit but was able to run with the fastest Tekin in every way on the straight. I didn't see any difference and we had a battle happening for a little while. One big difference though was the launch at the start of the race. This thing MOVES off the line compared to the rest of the field. It was however much bigger which some ppl won't like and I noticed the brakes were weak at high rpm and strong down low. Kinda made it hard to consistently pull up into hairpins.
Anyway quite nice really.
Powered by Falco
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18801 04-23-2017 03:49 PM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
