Old 03-11-2010, 05:57 AM   #766
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to HVFracingwilly
Originally Posted by Davin View Post
Thanks for the replies Joe. I think I might have found the problem. The video that I posted was of my 17.5 sedan . I just bought another MMP this weekend to replace the Speed Passion that I had in my 21.5 VTA car and was having the same problem. I think the problem is this, The Novak Ballistic motors are shipped with 30 degrees of mechanical timing. When the endbell is at the neutral mark it is already at 30 degrees. When setting the MMP to 50 degrees in C.H.E.A.T. mode you are in essence trying to pull 80 degrees of timing. Which I assume would cause almost somewhat of a electrical misfire. With that said I backed the motor down to 5 degrees on the endbell But I am still only able to go about 30 degrees on the MMP before this stuttering problem occurs. In a perfect world one would think that 35 degrees of timing would be all you need. But when 4 other guys at your track are running 50 in a spec class it makes it kinda hard to keep up on the straights.
At this point Im thinking the MMP and Ballistic motor are not a good combo. Im going to try putting my old 17.5 ss motor in to see if I have the same issues. I will let you know the results as soon I do. If you have anymore feedback for me it would be much appreciated.
Thanks in advance
Davin
HAHA poor thing cant keep up with my Stock Novak Havock speed control, just wait till i get my tekin in.............
Hobbytown USA Oshkosh
www.revolutionraceway.com
HVFracingwilly is offline   Reply With Quote
Old 03-11-2010, 06:03 AM   #767
Originally Posted by maxg123456 View Post
Great! - Thanks once again. I am going to start with 4000 start rpm with 50 degrees cheat mode, as I don't have a laptop at hand (at the race track). 4000-4500 start seems a good starting point from most people on here.
The only thing i'll hold back a bit on, is the motor timing on my Novak 10.5ss, so I don't detonate it straight away!
Someone on here already has run this combo and it is very fast.
The Speed passion 3.0 I think i'll get for the 13.5 class, as I hear nothing but praise with this motor.
Moontrap, do you run indoors? - Do you run up against Tekin RS, LRP SXX stock etc? - How is it comparing?
I run outdoors, on a small - medium track. I havent run against any SXX SS yet, but i have ran against Tekin v203 and i have found the Mamba to have a tick more bottom end than the Tekin , but they are pretty similar on top end. The Tekin is the only thing that i have seen hang with the Mamba at my track.
MoonTrap is offline   Reply With Quote
Old 03-11-2010, 06:16 AM   #768
Originally Posted by bodymot View Post
Hi Max, Will be at Maritime tonight and carpet wars so if you to need to change setup. Darren has netbook now so you should not have a problem if you need setup changes at Maritime. Join the Mamba Club. At maritime Tuesday night and Vince’s SXX Speedo went up in SMOKE . So I think you might have made the right choice .
Ben
Guess what? - Poxy work wont let me have the time off tonight! - So I cannot go. However, thanks for letting me know about the laptop situation. Appreciated. Tell Vince to stop showing off the power, he probably overdone the capabilities of that esc! If he didn't, then its yet another case of a product that hasn't been designed right from the off!
The SXX stock esc idea has long gone from my mind. The thing has too many faults. I'm buying this Mamba Max Pro for definate. I am already part of the team, if you'll let me in lol!
I will have one at the track next week. I have to be at a funeral on Sunday, so Carpet Wars is out too.
Next week i'm back!
maxg123456 is offline   Reply With Quote
Old 03-11-2010, 06:21 AM   #769
I thought the start rpm range around 4000 would've been too low for outdoors, but you've just proven that its not! - If the Mamba can have even slightly more bottom end than the Tekin it must be brutal!
Old 03-11-2010, 06:28 AM   #770
Jochim_18's Avatar
Start playing with the throttle curve and set it toward positive to gain more bottom end
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 03-11-2010, 06:55 AM   #771
Its not a big outdoor track, laptimes in the 11's for 13.5. I found if i went higher on the start rpm, then timing kicked in much later on the straight, Best is to experiment what works best on your track, and have fun beating the rest
And Jochim is right, that throttle curve is your friend
Old 03-11-2010, 03:04 PM   #772
Davin's Avatar
Trader Rating: 43 (98%+)
Ha Ha . I seem to recall somebody creepin up rather quickly on you in the main last weekend before my ride got stepped on by a corner marshal. Spent quite some time on the phone with Castle and Novak today See you Saturday
Davin is offline   Reply With Quote
Old 03-11-2010, 03:52 PM   #773
haha I have no fear i might just have to go do some practice and put another couple tenths between us.
Old 03-11-2010, 03:56 PM   #774
I dont know when the car stomp happened but still looks like you could use so more "cheat" in your setup
-- S STOCK SEDAN - A Main --
Pos Car Laps time name
1 1 37 5:04.25 WILLY MAGRITZ
2 2 35 5:06.69 MARK KOLLOCK
3 3 35 5:07.04 BRIAN HILDEBRAND
4 4 32 5:01.30 DAVIN FORSBERG
5 5 30 5:05.63 DAVE GAWARESKY
6 6 26 5:00.28 BEN HERHEIM
- S STOCK SEDAN -
Car-> __1__ __2__ __3__ __4__ __5__ __6__ __7__ __8__ __9__ __0__
1 1/ 1.4 2/ 1.7 3/ 2.1 4/ 2.3 5/ 2.9 6/ 3.0
2 1/ 8.6 2/ 9.0 4/ 9.5 3/ 8.9 5/ 9.5 6/10.5
3 1/ 8.1 3/ 9.4 4/ 9.1 2/ 8.5 5/ 9.9 6/
4 1/ 9.1 3/ 8.6 4/ 9.6 2/ 8.4 5/ 9.3 6/
5 1/ 8.2 3/ 8.6 4/ 8.4 2/ 8.5 5/ 9.7 6/29.3
6 1/ 7.9 4/12.2 3/ 8.6 2/ 9.7 5/ 9.9 6/
7 1/ 8.1 3/ 8.3 4/11.0 2/ 8.3 5/ 6/10.8
8 1/ 7.9 3/ 8.4 4/ 8.7 2/ 8.7 5/ 9.5 6/11.5
9 1/ 7.9 3/ 8.4 4/ 2/ 8.7 5/ 9.8 6/ 9.5
10 1/ 8.0 3/ 4/ 8.6 2/ 8.6 5/10.0 6/
11 1/ 8.1 4/10.4 3/ 9.2 2/ 5/ 9.4 6/
12 1/ 8.2 4/ 8.5 3/ 8.7 2/11.7 5/ 9.8 6/19.5
13 1/ 8.1 4/ 8.9 3/ 8.7 2/ 9.5 5/ 6/10.3
14 1/ 9.1 3/ 8.4 4/ 8.9 2/ 8.4 5/16.9 6/10.3
15 1/ 8.1 3/11.9 2/ 8.9 4/13.0 5/ 6/10.1
16 1/ 8.7 3/ 8.4 2/ 8.9 4/ 8.4 5/11.2 6/
17 1/ 8.1 3/ 8.3 2/ 8.8 4/ 5/ 9.5 6/ 9.8
18 1/ 8.1 3/ 8.7 2/ 9.4 4/ 5/12.6 6/ 9.8
19 1/ 8.3 3/ 8.4 2/ 8.6 4/19.3 5/ 6/ 9.4
20 1/ 8.2 3/ 8.4 2/ 8.5 4/ 8.8 5/10.2 6/ 9.7
21 1/ 8.0 3/ 8.7 2/ 9.1 4/10.5 5/10.1 6/10.9
22 1/ 8.0 3/ 8.5 2/ 8.8 4/ 8.3 5/13.4 6/
23 1/ 9.3 2/ 9.3 3/ 9.6 4/ 8.6 5/ 6/10.9
24 1/ 8.2 2/ 8.4 3/ 8.7 4/ 8.4 5/11.2 6/ 9.5
25 1/12.0 2/ 8.5 3/ 8.5 4/11.7 5/10.2 6/13.6
26 1/ 8.5 2/ 8.5 3/ 9.5 4/ 8.6 5/12.0 6/11.4
27 1/ 8.2 2/ 8.3 3/ 8.5 4/ 8.6 5/ 9.3 6/
28 1/ 8.2 2/ 8.8 3/ 9.4 4/ 9.2 5/10.7 6/10.9
29 1/ 8.0 2/ 8.5 3/ 8.6 4/ 9.0 5/ 6/ 9.5
30 1/ 8.0 2/ 8.5 3/ 8.3 4/ 8.7 5/ 9.7 6/ 9.8
31 1/ 8.2 2/10.3 3/ 4/ 5/ 9.4 6/
32 1/ 8.6 2/ 3/ 9.1 4/11.0 5/ 9.3 6/14.3
33 1/ 8.1 2/ 9.4 3/ 9.0 4/ 9.9 5/ 9.3 6/ 9.4
34 1/ 8.3 2/ 8.6 3/ 9.0 4/ 8.3 5/10.1 6/
35 1/ 8.3 2/ 8.9 3/ 8.3 4/10.0 5/ 9.4 6/16.2
36 1/ 8.0 2/ 8.4 3/ 8.6 4/ 9.2 5/ 6/ 9.1
37 1/ 8.1 2/ 8.4 3/ 8.4 4/ 5/10.1 6/
_____ _____ _____ _____ _____ _____ _____ _____ _____ _____
laps 37 35 35 32 30 26
time 304.2 306.6 307.0 301.3 305.6 300.2
Old 03-14-2010, 10:02 PM   #775
Jochim_18's Avatar
Anyone Tried LRP X12 Motor (17.5 or 13.5) with MMP..... From what I'm reading this motor is fast..... One of the guy that run this motor today is pretty fast........
Old 03-15-2010, 12:16 AM   #776
whoopass's Avatar
yes I have an x12 13.5 with the mmp and it is rapid wothout adjusting the timing on the motor yet. get one or the nosram x.12
whoopass is offline   Reply With Quote
Old 03-15-2010, 08:08 AM   #777
Jochim_18's Avatar
So hows the power band on X-12 (17.5 or 13.5) with MMP?
Old 03-15-2010, 09:22 AM   #778
Default touring car set up
I recently purchased a mmp and need help. The car is a tc4, foams, 4.2 final drive, 13.5 motor. The track is oval with 50' straights. Need help on setting the mmp for this track with high traction. Thank You.
ralph wallace is offline   Reply With Quote
Old 03-15-2010, 09:58 AM   #779
whoopass's Avatar
well its hard to know as i ran indoors and i never run indoors.
I will hopefully be running the mmp and x.12 on tarmac in the next couple of weeks so I will let you know. but its quick. the MMP for me is like a switch at the mo, either on or off. so I need to tune the settings to calm it down a bit.
Old 03-15-2010, 11:30 AM   #780
Jochim_18's Avatar
I just ordered LRP X12 13.5 lets see how the motor goes next weekend...
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18817 07-17-2017 07:08 PM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
