Old 02-08-2010, 11:15 AM   #601
black_knight's Avatar
Originally Posted by pdelcast View Post
That's why we give the option to change the timing band -- the timing comes in on a curve at the start RPM, and is at full at the end RPM. The timing change is linear with RPM over the range.
Normally, you would want to run the timing change over a fairly large RPM range, to take advantage of better torque (with lower timing) on the bottom end, and the higher torque of high RPM at the top-end.
Patrick
Hey I just got the MMP can you give an example of the RPM range for small, medium and large track. Just your best guess I know every track is different.
Team Epic
Right Back Pocket Racing
AE all the Way who needs an Xray. LOL
black_knight is offline   Reply With Quote
Old 02-08-2010, 01:37 PM   #602
Jochim_18's Avatar
I use higher timing on 17.5 and 13.5 Mostly at 40 degree of timing to get the advantage of extra horsepower at higher peak RPM (it gives your motor to produce more watts) Watts = horsepower when the timing kicks in. adding Timing only work best on the high speed section of track. Like what pdelcast stated you loose torque with the timing set higher that's where the RPM parameter is use. You set it when you want the timing to kick.
Like in real car advancing the timing gives you extra horsepower at peak RPM.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 02-08-2010, 06:07 PM   #603
KostaG's Avatar
Trader Rating: 48 (100%+)
Guys, do you know if the 1 Cell version come with a fan? I know the Castle Creations website says no, but a lot of people that actually have them did get a fan with it.
Can anyone please confirm?
Thanks.
Current Cars:
- Schumacher SX3 & Cougar SV
- Mugen MRX5 WC, Serpent 966e (4s)& Motonica P81e (6s)
Collector/Vintage Cars:
-Serpent F180 (2x), Serpent Veteq, Losi Jrx2, Tamiya Avante & Associated RC10
KostaG is offline   Reply With Quote
Old 02-08-2010, 06:27 PM   #604
Mr RCTech's Avatar
Thanks.
There taking the two cell Mamba Max Pro ESC and removing the fan and BEC chip (which is just a small voltage regulator chip).
BINGO - its now a one cell ESC.
Also, some are removing the heat sink or cutting the heat sink to save weight.
You can mount the ESC on the side to save space too.
Mr RCTech is offline   Reply With Quote
Old 02-08-2010, 06:38 PM   #605
KostaG's Avatar
I figured the fan is easy to remove, that is not a big deal.
Just want to know if indeed it comes with it. Want to have the versatility of the fan option with having to buy it later.
Current Cars:
Old 02-08-2010, 07:03 PM   #606
Tread1's Avatar
Trader Rating: 18 (100%+)
The first batch out had the fan,the latest batch doesn't.
Tread1 is offline   Reply With Quote
Old 02-09-2010, 06:28 AM   #607
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
I got my MMP last week.
Installed my MMP last night.
I'm still waiting for my adaptor.
Is there a way to remove the reverse?
I was doing some testing in my basement and as soon as I use the brake, it goes in reverse.
thanks
Maxime Beauvais
--- www.rcottawa.com ---
maximebeauvais is offline   Reply With Quote
Old 02-09-2010, 06:57 AM   #608
Jochim_18's Avatar
You need to get the caslte link so you can connect your ESC to your computer via USB to access the program. Then you can adjust it to disable the reverse function.
thanks
Old 02-09-2010, 07:22 AM   #609
pdelcast's Avatar
Originally Posted by seaball View Post
patrick, i fully understand this. what i'm indicating is that most of the profiles the guys are going on about (here) do not function in this manner. i am seeking some insight as to why these guys are slamming the motor with 40-50* of cheat timing at rpm ranges under what the motor will see on the typical road course. that seems somewhat counter intuitive to the c.h.e.a.t. feature itself.
I agree with you 100% -- they would definitely get better torque with less timing at low RPM. However, many setups spool-up so fast, they might not notice any difference...
pdelcast is offline   Reply With Quote
Old 02-09-2010, 07:46 AM   #610
pdelcast's Avatar
thanks
You can program the ESC to "forward only" mode using radio programming -- it's the first setting in the ESC. Programming is outlined/explained in the manual. You don't need the Link to do radio programming.
Thanx!
Patrick
Old 02-09-2010, 11:28 AM   #611
Thanx!
Patrick
I guess I should spend more time reading the manual
Maxime Beauvais
Old 02-10-2010, 09:46 AM   #612
does anybody know, how the castle link graph viewer works?
I can`t load any data in....
florianlaux is offline   Reply With Quote
Old 02-10-2010, 10:30 AM   #613
ABBOTT's Avatar
SmacTrac / STL Dirtburners / Blaze RC
ABBOTT is offline   Reply With Quote
Old 02-10-2010, 11:56 AM   #614
Mr RCTech's Avatar
Works with the Mamba Max Pro.
Load and save profiles easy.
Old 02-10-2010, 12:26 PM   #615
lowcel's Avatar
Trader Rating: 80 (100%+)
What are you talking about?
You can already do much more with the MMP than any LRP controller out there. The only ESC that is on par with the MMP right now is the Tekin. Castle and Tekin are both WAY ahead of the curve vrs. LRP.
That said, with the MMP, you do need to do some experimentation to get a setup that works well with a given motor -- so that you don't overheat it.
LRP isn't doing anything that you can't match and beat with CHEAT timing. Tekin has a slight advantage right now on short tracks because their timing curve is different than the Mamba Pro, but we are working on that.
Also, when the new timing curves are available, you will be able to download the new software on the MMP. You won't have to buy a whole new ESC every time we make an improvement (unlike OTHER manufacturers...)
Patrick
Any ideas on when new software is going to be available for the mmp?
Team Whopperjawed Racing
This hobby is going to $5 me to death.
lowcel is offline   Reply With Quote
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18835 09-11-2017 07:44 AM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
