Old 02-02-2010, 02:54 AM   #571
scrawl's Avatar
Anyone able to recommend a min/max rpm for cheat mode for 17.5 4wd offroad?
Just started experimenting with the variable timing and really not sure about a good starting point for these.
*Edit* Sorry - thought I was in the offroad section (arrived here via search).
stivesrc.org.au
"It's a spending hobby. You race occasionally."
scrawl is offline   Reply With Quote
Old 02-02-2010, 04:11 AM   #572
Born2Run's Avatar
Originally Posted by wyd View Post
You can run mod motors in cheat mode. Sensorless motors won't work in cheat mode because it is for sensored motors only.
Thanks wyd.
Whatever
Born2Run is offline   Reply With Quote
Old 02-02-2010, 07:59 AM   #573
Jochim_18's Avatar
Nope motor run like a champ and it's a rocket temp got up to around 180 degrees or so a little hot but the Novak ballistic rotor can handle the heat at least up to 200 degrees.
I run the setup below on the 13.5 expert class against LRP, Tekin and speedpassion guys I TQ and won running a novak ballistic 17.5 motor
ESC Profile: Cheat Mode
ESC Timing: 50 Degrees Crank that baby up
ESC RPM: 4500-6500 RPM
Punch Control: High
Motor Timing: 40 Degrees
FDR: 4.41
Motor: Novak Balistic
Chassis: Schumacher Mi3 with Exotek Chassis
Originally Posted by tandman View Post
Jochim, how can you run that much timing without something going wrong? 30 on the motor and 40 on the esc? Just going to be using the MMP tuesday for the first time and do not want to blow anything up or run into issues. I am going to try it with Orca fixed timing 17.5, Speedpassion V3 17.5 and LRP X12 17.5. I will let you know what I figure out.
Thanks........Dwayne Flodell
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 02-02-2010, 03:19 PM   #574
pdelcast's Avatar
Originally Posted by jopor View Post
Hi
I own a MMPro and i like it very much, but iīve got a problem with it and that is the size because iīm running TC and itīs really big when we compare it with other ESC from other brands.
I would like to see MMpro to become the same size as others īcause then i could balance my car better, now itīs to big to manage that issue.
So PdelCast thereīs any possibility to give us a smaller esc?
thanks
Joao
In the works. Look for it in about eight to ten weeks.
pdelcast is offline   Reply With Quote
Old 02-02-2010, 03:27 PM   #575
snellemin's Avatar
Trader Rating: 16 (100%+)
Nice. Any beta testing?
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
Old 02-02-2010, 05:37 PM   #576
pdelcast's Avatar
Yep -- we are trying to get the hardware together for a Beta test -- China shuts down in about a week, which might throw a monkey wrench into the timeline if we can't get the parts we need before then...
Old 02-02-2010, 05:47 PM   #577
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
I'm really excited to hear you have one in the works. Single cap? 2s or 3s lipo maximum? and all the Castle quality, that will be great. The MM Pro has made my 17.5 buggy into a rocket! I am moving it into my sedan next.
Kudos to the Castle team for another great speed control.
Jaz406 is offline   Reply With Quote
Old 02-02-2010, 07:56 PM   #578
RodneyRacer's Avatar
Trader Rating: 18 (100%+)
I just bought a MMP for my SC10 running 13.5 and 17.5 whats a good setup for the speedo and I have a 5700 CC motor also to run in mod what setup is good to start with and what should I play with adjustment wise I am new to brushless and have the speedo and motor on the way
RodneyRacer is offline   Reply With Quote
Old 02-02-2010, 08:11 PM   #579
ABBOTT's Avatar
Talking
Read the previous pages, get the speedo, read the instructions, and then ask a question that can be responded to in less than a small book!
SmacTrac / STL Dirtburners / Blaze RC
ABBOTT is offline   Reply With Quote
Old 02-02-2010, 10:38 PM   #580
Default Pro and sensors
I gear my 17.5 in my buggy at 8.64 no timing in the motor. I would run cheat mode with what ever timing you are comfortable with at 3400- 7700 rpm range. Motor was coming off at 106 degrees with 22 degrees of added timing.
Your 5700 will be a great mod motor from a small track to a large outdoor track. Always start gearing conservative the you can hang more teeth/go to a larger pinion or a small spur later after some temp readings. Start in the 9.0 Final drive ratio range. spur gear divided by pinion by transmission gear ratio.
Depending on your equipment ( i.e. batteries and connectors) your setup in the castle link will be different. It's a great tool if you don't have Castle link get it
Old 02-05-2010, 03:46 PM   #581
pdelcast
You have PM
thanks
Joao
jopor is offline   Reply With Quote
Old 02-05-2010, 04:31 PM   #582
bkspeedo's Avatar
pdlcast,
Is there a chance Castle can look at adding more timing advance to cheat mode. After work the MMP and the 203 Tekin, Tekin seems to add more timing with the combination of Boost and Turbo.
I'm having to crank the timing on my 17.5 motors and use max (50deg) in the MMP and it's still not as fast as my Tekin. I'm not sure how much timing a motor can take before it has issues but it seems like as the RPM increases the motor can take more and more advance.
It would also be nice to have more options for end RPM after setting a start RPM. It seems like you get 3-4 options close to the start RPM with the last one being a huge jump that would never be used. I would like to see 10 options separated by 2-3K.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 02-05-2010, 05:41 PM   #583
Put the Tekin in your car
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-05-2010, 05:49 PM   #584
Chris Furman's Avatar
Trader Rating: 112 (100%+)
or wait for a new Castle. I'm sure they'll have something up their sleeve. Remember they were quicker before Tekin figured out v203.
Chris Furman is offline   Reply With Quote
Old 02-05-2010, 06:35 PM   #585
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
I received my mamba max pro today.
I live in Canada and I was going to use the free code for the link adaptor BUT it said on the card that US domestic address will get if free but other country may require to pay shipping ????????
I went to the castle creation web site and it said 20$ for shipping to send it to Canada. I don't want to enter the coupon code just in case that I DO have to pay the shipping.
I have sent an email to castle creation but is there anyone here from Canada that has get the adaptor.....is free of charge for shipping??6
thanks
Maxime Beauvais
--- www.rcottawa.com ---
maximebeauvais is offline   Reply With Quote
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18797 12-21-2016 06:07 PM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 11:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-24-2009 12:33 AM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 08:00 PM
SEO by vBSEO 3.5.0
