Old 01-30-2010, 10:48 AM   #556
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Originally Posted by Randy_Pike View Post
So far I'd say Tekin's doing pretty well....
that's great news, randy. keep up the good work.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 01-30-2010, 01:18 PM   #557
tandman's Avatar
Send a message via Yahoo to tandman
Got it thanks...
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
Old 01-31-2010, 03:21 PM   #558
Hi
I own a MMPro and i like it very much, but iīve got a problem with it and that is the size because iīm running TC and itīs really big when we compare it with other ESC from other brands.
I would like to see MMpro to become the same size as others īcause then i could balance my car better, now itīs to big to manage that issue.
So PdelCast thereīs any possibility to give us a smaller esc?
thanks
Joao
jopor is offline   Reply With Quote
Old 01-31-2010, 06:14 PM   #559
tandman's Avatar
Hey guys, I hope spmeone from the snowbirds race that ran the MMP in 17.5 touring car can post a setup or anyone else have a starting setup. What about adjusting the throttle profile....what should the curve look like for rubber tire 17.5 tc racing? Track size would be 100'x48'
Thanks..........Dwayne Flodell
Dwayne Flodell
Team Mad Scientist
Old 01-31-2010, 07:19 PM   #560
seaball's Avatar
it's actually the same size as a speed passion. everyone else omits the depth of the solder posts sticking out in their width (footprint) dimensions. if the mmp were to leave the edge with all the connections outside of the case, it would spec a reasonably sized footprint. add to that the fact that the caps are all included, and it's really pretty decent. take off the cheap plastic fan and it will look/fit a lot better...
Old 01-31-2010, 07:54 PM   #561
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
ST Racing Concepts (STRC)
Old 01-31-2010, 09:48 PM   #562
bkspeedo's Avatar
For anyone running 17.5 what are your settings?
I did a lot of testing this weekend with a SP v3 17.5, I could not get it to run as fast as my Tekin. I tried gearing from 4.1 to 5.7 and timing from 35 to 50deg, nothing seem to make it rip down the straight. My sons car with a Tekin and same motor is 3 tenths faster and noticeable faster on the straight.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 02-01-2010, 08:00 AM   #563
Jochim_18's Avatar
Here's my current setup on my 17.5 Novak Ballistic:
ESC Profile: Cheat Mode
ESC Timing: 50 Degrees Crank that baby up
ESC RPM: 4500-6500 RPM
Punch Control: High
Motor Timing: 40 Degrees
FDR: 4.41
Motor: Novak Balistic
Chassis: Schumacher Mi3 with Exotek Chassis
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 02-01-2010, 01:59 PM   #564
gixer's Avatar
Hi Guys,
I have been running the MMP for a few months now and it's worked fantastic, i'm really happy with it.
But today my sensored BL motor arrived and i can't get it to operate with the MMP.
I've changed the settings in the software and tried it in both "sensored only" and "Smart sense" modes, but rather than rotate the motor just vibrates violently.
I am running V1.24 if that makes any difference.
Is it something i've done wrong, a bad motor?
I've also tried swapping around the 3 motor wires and i've checked the motor sensor connections and cable, all look good but still the same.
Cheers
Mark
HB Cyclone (WCE Exotek) x 2, Pro3 (Penguin chassis), Pro4, M-04M (Eunos Roadster)
Losi MRC, Axial XR-10
ERevo Erbe, HPI Firestorm (Nitro), Blitz,
gixer is offline   Reply With Quote
Old 02-01-2010, 02:29 PM   #565
MikeL.'s Avatar
Originally Posted by gixer View Post
Hi Guys,
Cheers
Mark
You cant just swap sensored motor wires around. They must go A to A, B to B, and C to C. Make sure they are wired up like that and see if that makes a difference.
Mike
MikeL. is offline   Reply With Quote
Old 02-01-2010, 02:58 PM   #566
gixer's Avatar
Amazing how well it works when it's wired up correctly
I did read through the manual before connecting it, but it had no section on sensored motors, it only said that BL motors are not polarity conscious so it doesn't matter which way round the wires go.
Might be worth adding a section on sensored motors, just for noob dumd asses like meself
Thanks Mike, works a treat now
Cheers
Mark
Old 02-01-2010, 03:55 PM   #567
tandman's Avatar
Jochim, how can you run that much timing without something going wrong? 30 on the motor and 40 on the esc? Just going to be using the MMP tuesday for the first time and do not want to blow anything up or run into issues. I am going to try it with Orca fixed timing 17.5, Speedpassion V3 17.5 and LRP X12 17.5. I will let you know what I figure out.
Thanks........Dwayne Flodell
Dwayne Flodell
Team Mad Scientist
Old 02-01-2010, 03:55 PM   #568
MikeL.'s Avatar
Cheers
Mark
Hmmm.....there should be either an insert about sensored motor wiring or something in there. I know we did up instructions on it. I will check tomorrow and make sure its being put in. Sorry if there was nothing with yours. Glad it works now.
Mike
Old 02-02-2010, 01:19 AM   #569
Born2Run's Avatar
Two more questions:
1)Cheat mode could be used with mod.motors?
2)How performs a sensorless motor on cheat mode?
Whatever
Born2Run is offline   Reply With Quote
Old 02-02-2010, 01:35 AM   #570
wyd
Tech Legend
wyd's Avatar
Originally Posted by Born2Run View Post
Two more questions:
You can run mod motors in cheat mode. Sensorless motors won't work in cheat mode because it is for sensored motors only.
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18835 09-11-2017 07:44 AM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
