Old 01-26-2010, 08:36 PM   #526
Originally Posted by Jochim_18 View Post
We just finish our series and took home first place using my Mamba Max Pro with Ballistic 13.5 in superstock expert class. My car setup was horrible and wrong tire of choice the first 2 heat races and strip a spur gear on 3rd heat so I work on my car went back to the old setup... " Saying says Don't touch your car if ain't broke"... I have to start on back of the field at 9th place on the A main,, But I manage to pull through the last 45 seconds and I blow past my friend on the straight and never look back after that.... It's hard fought battle but if you have confident with your equipment it relaxes you...
Final Setup:
ESC Profile: Cheat Mode
ESC Timing: 40 degree
Motor Timing: 35 Degree
Punch Control: Low
RPM: 4600-1000 RPM
Motor Temp: 150-160 Degrees
Motor: Novak Ballistic 13.5
Battery: TP 4200 40C LIPO
FDR: 4.6
Chassis: MI3 with exotek chassis
How did you set RPM to 4600-1000? Mine wont go below 1900 and above 3900. What am I doing wrong?
Joe Maxey is offline   Reply With Quote
Old 01-26-2010, 08:46 PM   #527
Jochim_18's Avatar
Select the Initial RPM setting then click custom that will give you a drop down list of different RPM range.....
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 01-26-2010, 09:12 PM   #528
When I do that it will only let me select a small difference in rpm range. I click down and it will only go to 1900 and then I click the bottom window and it gives me options and the highest value option is 3800 or 3900. If I type in a value in the bottom window a box opens and tells me error in the value I selected.
Old 01-26-2010, 09:37 PM   #529
Is that 1000 or 10000? I can do 4600 to 10000 but not 1000. I think I have this under control now.
Thanks for the help,
Joe
Old 01-27-2010, 02:55 AM   #530
Born2Run's Avatar
Ok guys Mamba Max Pro did it again today on 4th round of our series...
Final setup:
ESC Timing: 50 Degrees Crank that baby up
ESC RPM: 3400-3600 RPM
Start Power/Punch Conrtrol: Low
Motor Timing: 35 Degrees
FDR: 4.41
Motor: Novak Balistic 17.5
Motor Temp: 165-175 Degrees Fareheit
Batteries: TP 4200 40C Lipo
Chassis: Schumacher Mi3 with Exotek Chassis
Note: Only Try this setup if outdoor temp is around 45-60 Degrees.. If your temp is over to what I stated I would say you will thermal your motor....
I run my car today using 17.5 motor on 13.5 expert class man with this setup my car is a missile, I TQ using 17.5 motor then switch to 13.5 for the main to secure the win... Everyone at my track was really surprise when I told them I was running 17.5 on my heat races Co'z everyone was wondering my car got a lot faster on the main Again I lap the whole field with ease... My friend even use the new tekin firmware.. Not even close with MM PRO amd I'm running 17.5 motor
Could someone please explain how the cheat mode works and what's the meaning of rpm settings (ex. ESC RPM: 3400-3600 RPM) ?
Whatever
Born2Run is offline   Reply With Quote
Old 01-27-2010, 06:46 AM   #531
Jochim_18's Avatar
On the RPM setting you need to sellect a higher start RPM then select custom then you can start lowering it you will notice on the End RPM setting range of RPM will change.
Old 01-27-2010, 06:47 AM   #532
Jochim_18's Avatar
thats 10,000 RPM so you got it bud?
Joe
Old 01-27-2010, 06:49 AM   #533
Jochim_18's Avatar
It gives your motor extra horsepower.... Cheat mode advances your timing Boost and RPM it set your timing boost when to kick in.
Old 01-28-2010, 10:40 AM   #534
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
what is the best BL 13.5 that will be good to get with the Mamba Max Pro.
I'm racing offroad.
thanks
Maxime Beauvais
--- www.rcottawa.com ---
maximebeauvais is offline   Reply With Quote
Old 01-28-2010, 10:50 AM   #535
jeff jenkins's Avatar
Trader Rating: 76 (100%+)
so how are the mambas doing at the birds? any match for the tekin .
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 01-28-2010, 02:14 PM   #536
ABspeed's Avatar
figured out
ABspeed is offline   Reply With Quote
Old 01-29-2010, 07:24 AM   #537
Jochim_18's Avatar
A lot of people think tekin is faster than any other ESC out on the market well they are wrong... You can't have a speedcontrol to go faster just changing the software yes tekin upgraded their software but it's still the same ESC... Circuitry castle use is far superior than tekin try running 6S lipos on tekin ESC see if it can handle it
I'll be going to ROAR nats this year let se what happens..
Old 01-29-2010, 07:27 AM   #538
Jochim_18's Avatar
So Far I have only tried Novak Ballistic.... I'm thinking of getting a DUO 2 or Speedpassion V3 to try out...
I'm racing offroad.
thanks
Old 01-29-2010, 11:27 AM   #539
can anyone give me the part number of the mamba max pro?
Please, can`t find it anywhere..........
florianlaux is offline   Reply With Quote
Old 01-29-2010, 11:49 AM   #540
could it be this:
CSE6600
Maxime Beauvais
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18835 09-11-2017 07:44 AM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
