Old 01-07-2010, 06:32 AM   #421
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
as small as an index card just about. and its just as u saw in the press photo. pretty cool indeed. i didnt have a CCMMP in my offroad car so i didnt get to try it out at the track. but really cool indeed.
R
UltegraSTI is offline   Reply With Quote
Old 01-07-2010, 09:17 AM   #422
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by Chris Furman View Post
oooooohh.. ultra cool. pics??? anyone?
Should be fairly soon. I seen the test version last weekend and got a quick demo on it. It is pretty cool and took no time to change settings. I didn't get one yet but I can say the test one my buddy has works great.
ST Racing Concepts (STRC)
Old 01-07-2010, 09:24 AM   #423
jag88's Avatar
Just wanted to say that I called CC tech line to ask some questions and was blown away with the GREAT conversation I had with these guys. They know their 'stuff' !
jag88 is offline   Reply With Quote
Old 01-08-2010, 09:08 AM   #424
M7King's Avatar
FYI: CastleLink Software Update 3.241 now available.
http://www.castlecreations.com/downloads.html
Hopefully we have even more options to truely dial in this esc.
Chad C.
M7King is offline   Reply With Quote
Old 01-08-2010, 10:34 AM   #425
Trader Rating: 114 (100%+)
Got it a few days ago... same-o.
CASTLE - we are hoping for more CHEAT timing and a 'turbo' function after CHEAT is complete.
Chris Furman is offline   Reply With Quote
Old 01-08-2010, 05:14 PM   #426
Registered User
UltegraSTI's Avatar
nowadays i'm not sold on turbo presence. the tekin guys can actually cross their curves for timing and turbo if folks get too crazy or experimental and that cant be good for a motor. if more timing is needed, select more total timing and broaden the rpm range so its used on the straight where its desired.
R
Old 01-08-2010, 06:42 PM   #427
cyanyde's Avatar
With timing coming in gradually, you can actually advance timing on the motor now without hurting it. Setting it to 0 is just a waste. I run mine a little advanced and actually get better infield rip and alot of top speed. Only thing to remember is let the timing advance start about 3-4k rpm later than you would with 0 motor timing. Try it...
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 01-08-2010, 10:43 PM   #428
Jochim_18's Avatar
I setup on my 13.5 and 17.5 is about the same I just have my punch control set to low on 13.5 to prevent tire spin.
Here's my current setup on my 17.5 Novak Ballistic:
ESC Profile: Cheat Mode
ESC Timing: 50 Degrees Crank that baby up
ESC RPM: 4500-6500 RPM
Punch Control: High
Motor Timing: 40 Degrees
FDR: 4.41
Motor: Novak Balistic
Chassis: Schumacher Mi3 with Exotek Chassis
Note: 17.5 on steroid with this setup, Motor Temp around 140-150 Degrees Farenheit..... Track size 120x50
Originally Posted by M7King View Post
-Jochim
What size track do you have? Seems to have found the sweet spot on my LRP x11. I did notice a huge difference to changing from startup mode to high.
I'm now trying to find the sweet spot on a Duo2 13.5. Anyone experiment with that?
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 01-08-2010, 11:48 PM   #429
Trader Rating: 8 (90%+)
I saw this before I read the thread and thought I would thrw it up there...
http://www.ultimaterc.com/forums/sho...d.php?t=105168
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris [email protected]
Tha Skinny is offline   Reply With Quote
Old 01-09-2010, 01:08 AM   #430
jeff jenkins's Avatar
Trader Rating: 76 (100%+)
Punch Control: High
FDR: 4.41
just curious how you got the rpm range to end at 6500 rpm as i can only go 4500-6400rpm on the castle link? i am going to try this set-up this weekend but since i am on a 80x50 track my fdr will start at around 5.5.
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 01-09-2010, 07:00 AM   #431
Ffejdat's Avatar
Anyone try or look at this new software yet? Anything visibly different? Will it work with BEC removed 1s ESC's? I don't wanna downlaod it yet till I know what it is, as so far it is not good to put any other verions of the software, except the 1 cell version, in a 1 cell non bec ESC...
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 01-09-2010, 08:36 AM   #432
also another quick question. on the test unit programming cards are you able to adjust the rpm range? that would be great if you could adjust everything and wouldnt need the castle link and it could be updated?
Old 01-09-2010, 09:13 AM   #433
Jochim_18's Avatar
jeff jenkins,
I just can't remember the actual RPM on top of my head so I just round it off
Old 01-09-2010, 09:14 AM   #434
Jochim_18's Avatar
I got it downloaded the other day nothing much different that I can tell.
Old 01-09-2010, 11:45 AM   #435
Registered User
UltegraSTI's Avatar
read the version update info, just removin bugs/hiccups error data. no effect.
that much timing, idk bout the novak, but if track grips up, u'll heat up quick. we learned that already. specially at that 4.4:1. try somethin lighter on gear and just a lil bit off on timing (again grain of salt since i really dont know bout the ballistic). see what happens.
R
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18835 09-11-2017 07:44 AM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
