Old 12-27-2009, 06:24 AM   #331
cyanyde's Avatar
Originally Posted by jeff jenkins View Post
whats a good setting for 17.5 sedan on a 50x80 track that is technical and semi tight. i am running a ballistic 17.5
I run my 11.5 @ stock motor timing, 50 deg esc timing, 6500rpm-50,000+rpm. Its ok to use max timing. Just make sure it doesn't come in early. This way, less timing is added when your speed is low, giving more torque and a cooler motor.
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 12-27-2009, 10:50 AM   #332
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Jochim_18 View Post
Here's my setup on 17.5 novak balistic motor:
ESC profile = Cheat Mode
Motor timing = 35 degree (1 notch positive end)
ESC Timing = 40 degree
RPM = 4500-6500
FDR = 4.0
start up mode = High (set this at high for max punch)
Adjust your FDR to about 4.5 since your track is small.
thanks i will give this a shot. what motor temps were you getting ?
posted by cyanyde : I run my 11.5 @ stock motor timing, 50 deg esc timing, 6500rpm-50,000+rpm. Its ok to use max timing. Just make sure it doesn't come in early. This way, less timing is added when your speed is low, giving more torque and a cooler motor.
you mean your 17.5 right. so i just adjust the rpm range in custom and go to 50,000 on the end rpm. what fdr do you run.
jeff jenkins is offline   Reply With Quote
Old 12-27-2009, 11:00 AM   #333
Originally Posted by ultegrasti View Post
to the fella above w/the 17.5 settings. shouldnt u be using no motor timing per suggested by castle?
R
its different on the ballistic 17.5 as the neutral setting is 30 actual degrees . when i talked to novak they said that they tested other manufactuers motors on there timing machine and there 10 degree mark is really 42-45 actual degrees timing so set that motor to 0 degrees and its really 32-35 actual degrees not 0 degrees. if that makes sense. so really the 30-35 degrees on the ballistic is about right.
Old 12-27-2009, 05:01 PM   #334
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
fair enuff, dually noted.
R
UltegraSTI is offline   Reply With Quote
Old 12-27-2009, 05:38 PM   #335
Trader Rating: 114 (100%+)
Anyone run the MMP with a Vector X12 17.5 yet?
Chris Furman is offline   Reply With Quote
Old 12-27-2009, 05:56 PM   #336
cyanyde's Avatar
No. I really meant 11.5T. Its the stock wind here in some parts of asia. As for FDR, I'll go between 6-7.5 depending on track size. I would assume a range of 4.5-6.0 would be more suited to a 17.5T. So far no one is faster than me on the straights and coming out of turns. The only issue for me right now is car setup, tire selection and of course, practice.
/Adrian.
Old 12-27-2009, 06:14 PM   #337
thanks for clarifying
Old 12-28-2009, 06:16 PM   #338
Good news!!! My special edition 1S lipo version of the MMP shipped out to me today! They said 1st week of Jan., so they are ahead of schedule. How often does THAT happen with any company these days? lol. Hope the holidays don't delay it so it gets here in time to get it in my 1/12th for Sunday racing.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 12-28-2009, 06:54 PM   #339
ira
ira's Avatar
Trader Rating: 18 (100%+)
Testing three different brand motors this weekend, two of the motors are made by the same company but sold under two different names.
The two motors had the same stutter problem, and the third motor from a different manufacturer was much better, I only had one little stutter with this motor.
There seems to be somewhat of a software glitch with the ESC, the stutter seems to happen more with a motor that has a weaker magnetic.
Let me know if you have experienced this with your PRO.
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 12-29-2009, 02:43 AM   #340
cyanyde's Avatar
I don't think the magnet strength has anything to do with it. And from your previous posts, you seemed to have everything in correctly and have tested with different sensor cables and motors. I wouldn't discount the fact that your speedo may be faulty. Send it in to Castle and let them have a go at it....
/Adrian.
Old 12-29-2009, 08:37 AM   #341
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
With your setting at 50,000rpm for your top range you are never getting that many rpms so you are never using all that 50 degrees of timing. Thats cool if it works for you but just letting you know.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 12-29-2009, 09:14 AM   #342
i would try re-calibrating your speedo when putting in each motor. and see if that helps. also make sure the sensor cable is good .
Old 12-29-2009, 09:41 AM   #343
Thanks for the interesting info. I have a DUO2 and wondered if anyone know what the "0" mark's actual timing is also...
I want to get another MMP, but it is sort of an unobtanium atm. You can get the combo deals, but I don't need another motor. Most places said late Dec, but now it says "on order" or mid Jan.
redbones is offline   Reply With Quote
Old 12-29-2009, 09:57 AM   #344
Send a message via Skype™ to slotracer577
If the tekin software update is any good, will probably sell my MMP 1cell that should arrive tomorrow. Will know by sunday if I am going to install it or sell it NIB.
Team Epic
slotracer577 is offline   Reply With Quote
Old 12-29-2009, 05:47 PM   #345
Registered User
UltegraSTI's Avatar
pure bliss 2day. thats all i can say. thx joe.
R
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18797 12-21-2016 05:07 PM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
