Old 12-21-2009, 08:50 AM   #256
ira
ira's Avatar
Trader Rating: 18 (100%+)
Originally Posted by wyd View Post
My only experiance with the Losi 17.5 is about 3 runs then it burned up my speedo as the motor toasted. I just got into brushless and my buddy gave me a brand new Losi 17.5 and Speed Passion speedo. Gave me a gearing to start with. Ran the car and the temp was only 140 degrees. Ran another practice and 140. Ran my 1st heat and 140 degrees. Run my 2nd heat and 30 seconds from the end of the race the car slows and stops. Motor 220 and wiped out the speedo.
If you didn't already try it I would try another 17.5 and see if it still is having problems.
Wyd,
I just got off the phone with Bernie at Castle Creations, I hope they don't treat all of there customers the way I was treated. I explained the symptoms I was having with the ESC, he made blame on every thing ( including me ) in the car, servo, rec, batt. ect.
As I was typing this a friend from Chicago called me. This weekend was his first time out with his Pro, he is having the same symptoms as me. He "said"' If he hits a board pretty hard and the car rolls back the ESC will cut off, after a second or two the ESC works fine. He was testing 1/12th 1 cell 13.5, and yes he is using a receiver pack, fully charged.
Any suggestions?
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 12-21-2009, 09:15 AM   #257
bkspeedo's Avatar
Originally Posted by CillieAcc0rd5o4 View Post
What card for what ESC ?
Look on page 16 of this thread.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 12-21-2009, 12:21 PM   #258
Tickle's Avatar
Trader Rating: 32 (100%+)
Thumbs up Mine does the same thing!
My Mamba does the same thing. If I hit anything more than a tap it will shut off for about second or two then work fine again. Doesn't really effect my racing much - already lost too much time hitting the board!
Back in the TC race!
Horsham RC!
Trains and Lanes in Easton, PA
Tickle is offline   Reply With Quote
Old 12-21-2009, 12:36 PM   #259
ira
ira's Avatar
Tickle,
Call Castle Creation @ 913-390-6939 and talk to Bernie. I spoke with him this morning about the same thing. Castle is about 15 minutes from my house, I have a feeling I will be paying them a visit.
I'll keep you posted on the outcome.
Ira
Old 12-21-2009, 12:46 PM   #260
ira
ira's Avatar
To all the racers that are having this problem, please call Castle and let them know. 913-390-6939
Castle dose not seem to know about the ESC shutting down.
Old 12-21-2009, 12:51 PM   #261
I haven't had any problems with mine shutting down.
Fred_B is offline   Reply With Quote
Old 12-21-2009, 01:51 PM   #262
ira
ira's Avatar
There are a few people with this. I'm not bashing the MAMBA MAX PRO, I'm very happy with the ESC. The adjustments are great and the rip is great, arguably on of the better ESC out there. A few of us are have this problem, with mass manufacturing things happen.
Old 12-21-2009, 02:12 PM   #263
Interesting, this is a symptom of the old skool sensorless BL systems. The car rolls backwards, the speedie looses track of the rotor and it has to reset itself. It was bad when running 1 ways, as it was very easy to spin and do a roll back.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 12-21-2009, 02:13 PM   #264
sportpak's Avatar
Trader Rating: 26 (100%+)
Originally Posted by ira View Post
Tickle,
Ira
I did and they blamed the servo. I changed the servo and it was better, but still a stutter here and there. The final straw was the second one I had in my Slash started cutting in and out bad. I put a receiver pack on it and it was fine. Sure, the servo may be getting tired, but other speedos I have tolerate it. The "we've never heard about that problem" is BS.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 12-21-2009, 02:16 PM   #265
Trader Rating: 25 (100%+)
I too recognized this same problem with mine one day. It does not kill power to the speedo, it just kills the throttle feature for a second. My guess is that since the motor rotation is going backwards, the sensored portion of the speed control gets confused and doesn't know what to do until the motor is stopped.
You do not have to hit a board to make this happen either. I was driving mine on a dusty road. The car spun and rolled backwards. That is when I lost my throttle.
I have not tested this yet, but maybe running a receiver pack would help.
I had a problem with the throttle cutting out when using a high torque servo during hard cornering. I was able to reproduce this with other racers cars as well. The receiver pack fixed that problem, maybe it will fix this one as well.
Former RC fanatic just trying to keep up......
BSR Tires / Spektrum RC
Jamie Hanson is offline   Reply With Quote
Old 12-21-2009, 02:19 PM   #266
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
jamie-ur 12 scale or paved oval stuff (1s) or somethin else (2s)?
R
UltegraSTI is offline   Reply With Quote
Old 12-21-2009, 02:22 PM   #267
R
12th and pan car oval is all 1c. When I ran into this problem, I was running 2cell on dirtoval.
Old 12-21-2009, 02:35 PM   #268
ira
ira's Avatar
One of the people I know that has this happen to him is racing 1/12th 1 cell, he is using a receiver pack and still having this problem.
I'm racing 1/10 th Sedan with a 17.5 2 cell , why should I have to add/try a receiver pack ? to solve a software / hardware problem the manufacturer should be responsible for ?
Old 12-21-2009, 03:10 PM   #269
Francis M.'s Avatar
Time to just sell that Speedo and buy a real Speedo... Everyone I know who bought a CC speedo was not satisfied with the performance/ consistency...
This was a few years back and I guess nothing has changed.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 12-21-2009, 03:11 PM   #270
lowcel's Avatar
Trader Rating: 80 (100%+)
Are you running a DSM or a DSM2 receiver? A buddy of mine seems to have narrowed it down to where the problem is just happening with DSM (non DSM2) receivers.
Team Whopperjawed Racing
This hobby is going to $5 me to death.
lowcel is offline   Reply With Quote
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18797 12-21-2016 05:07 PM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
