Old 12-20-2009, 08:54 PM   #241
ira
ira's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Jochim_18 View Post
Things you wanna check first:
1. Update the firmware to the newest version.
2. Check your timing make sure is not set to high.
3. Make sure your battery can handle the amp draw of this ESC.
1. Firmware Updated
2. Timing set at 22, 26, ect. no change, same result.
3. 5000 Mha 40c Thunder Power
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 12-20-2009, 09:31 PM   #242
Jochim_18's Avatar
Have you tried putting capacitor in your reciever?
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 12-20-2009, 09:34 PM   #243
ira
ira's Avatar
Why would I do that ?
Old 12-20-2009, 09:37 PM   #244
M7King's Avatar
Originally Posted by ira View Post
1. Firmware Updated
What motor are you running?
Chad C.
M7King is offline   Reply With Quote
Old 12-20-2009, 09:41 PM   #245
snowbeaverking's Avatar
WOW that field program card is cool I am going to have to get one. I love this site I learn something new every time I am on here
TEAM TERRIBLES
PM me if you would like to be part of the worlds largest R/C Race Team
Home Track: http://www.area52rc.com/
snowbeaverking is offline   Reply With Quote
Old 12-20-2009, 09:54 PM   #246
ira
ira's Avatar
Losi 17.5
Old 12-20-2009, 10:00 PM   #247
What card for what ESC ?
CillieAcc0rd5o4 is offline   Reply With Quote
Old 12-20-2009, 10:02 PM   #248
Jochim_18's Avatar
It prevents voltage from your receiver from dropping.
I'm assuming your car start cogging on hard acceleration. Brushless motor will draw a lot of AMP from your batteries during hard accelaration and sometimes this will cause a voltage drop from your receiver having a capacitor will prevent this and it will give the receiver a constant voltage to operate properly.
With The timing advance we have on the motor and ESC it's a must to have CAPACITOR in your receiver.
Old 12-20-2009, 10:03 PM   #249
Jochim_18's Avatar
Did you check the sensor wire?
Losi 17.5
Old 12-20-2009, 10:23 PM   #250
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Everything was fine till he would tap a flapper at speed. Could it be a static electricity issue like the old spektrums systems had?
Dustin Layne
smoke81 is offline   Reply With Quote
Old 12-20-2009, 10:31 PM   #251
Jochim_18's Avatar
Possible check for loose connection or wiring.
Old 12-21-2009, 01:40 AM   #252
cyanyde's Avatar
Finally raced the MMP in 11.5T stock yesterday and it was AWESOME!!!... I was waaay faster on the straights with tonnes of rip on the infield. However I was not properly prepared for the race and didn't have the right setup. Finished 4th overall. I am so in love with this esc. Beats my Tekin RS Pro and SP GT2 hands down!
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 12-21-2009, 06:13 AM   #253
ira
ira's Avatar
No, this dose not happen during hard acceleration. When entering a corner if I tap the corner the ESC will not pick-up throttle, steering servo works fine. One other thing I noticed is if I hold the back of the car and pull throttle ( easy or hard ) to clean off the tires before my heat race, sometimes, not all the time, the tires barley move.
I checked the sensor wire, it appears to be fine.
Old 12-21-2009, 06:44 AM   #254
ira
ira's Avatar
I was one Castle Creations web site and noticed there building is only 10 to 15 minutes from my house.
Old 12-21-2009, 07:02 AM   #255
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
My only experiance with the Losi 17.5 is about 3 runs then it burned up my speedo as the motor toasted. I just got into brushless and my buddy gave me a brand new Losi 17.5 and Speed Passion speedo. Gave me a gearing to start with. Ran the car and the temp was only 140 degrees. Ran another practice and 140. Ran my 1st heat and 140 degrees. Run my 2nd heat and 30 seconds from the end of the race the car slows and stops. Motor 220 and wiped out the speedo.
If you didn't already try it I would try another 17.5 and see if it still is having problems.
ST Racing Concepts (STRC)
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18835 09-11-2017 07:44 AM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
