Old 04-20-2012, 10:24 AM   #1486
Originally Posted by starrx View Post
i run tc 17.5 blinky & i try the 1.33v & it had a lagging feeling...i went back to the 1.26 & it was very punchy..(the way i like it)..what would be the best firmware for 17.5 & 21.5 thanks!!!
anybody??
starrx is offline   Reply With Quote
Old 04-20-2012, 10:37 AM   #1487
macdude's Avatar
anybody??
If 1.26 feels better to you than 1.32 or 1.33 then I would just stick with that. I have run 1.26 for a long time and it was always really good. I have only recently switched to the newer firmware for offroad, as I really like torque control on loose, low traction tracks. For onroad I don't need this so, 1.26 has been working well.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 04-20-2012, 02:16 PM   #1488
Thanks! I didnt know if 1 of the firmware was better 4 17.5/21.5
Old 05-23-2012, 08:50 AM   #1489
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I just bought a GM 13.5 Pro motor and well its slow as crap. I was thinking of using the timing feature on the MMP to give the motor a little more kick. What are some good settings I could start out with? I dont fully understand the Timing and rpm relationship.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-23-2012, 12:29 PM   #1490
macdude's Avatar
What are you putting it in?
Here is a good starting point. But knowing the car is more helpful as I can also recommend approx. gearing.
Starting RPM is the point at which the ESC starts to apply dynamic timing advance to the motor.
Ending RPM is the point where the total amount of timing is done being applied.
So the smaller the RPM window the faster the timing is applied to the motor. For most situation always pick the largest window using the drop down window.
I would start with 25-30 degrees of timing
start RPM of 5000 - 6000 and end of around 15,000 - 20, 000. These numbers are not exact as I don't have the software in front of me. However you get the idea that there should be about 10 - 15 thousand RPM's between the start and end values. If you want the boost to feel harder then shorten the window, but for long back straights I would keep it wide and gear up a little for the in-field.
Old 05-23-2012, 01:37 PM   #1491
ok, I was playing with a a custom rpm of 3.5-28k with 30%. I will narrow it a little.
Old 05-28-2012, 12:05 PM   #1492
tudor_47's Avatar
Default BAD ESC? Yellow LED flashing
Here's one for all you mamba max pro experts,
The yellow LED is flashing, It calibrates OK, it responds to programming via the castle link, I have updated the firmware. everything seems fine except the yellow LED is flashing, The yellow LED flashing did NOT start when updating firmware
the motor will not run.
So what can i do?
Can it be other than the ESC itself that is bad?
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 05-28-2012, 02:21 PM   #1493
Luppi Stefano's Avatar
So what can i do?
before update FW motor run normally?
mamba bip bip start?
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 05-28-2012, 10:13 PM   #1494
tudor_47's Avatar
no, yellow LED flashing before update
Old 05-29-2012, 03:01 PM   #1495
Trader Rating: 216 (100%+)
Flashing yellow usually means "Blinky" mode. I had one that flashed yellow with solid green while at full throttle and had no motor response and that one had to be sent in.
Andy Koback is offline   Reply With Quote
Old 08-29-2012, 10:57 AM   #1496
Hello,
I hame some problem tuning my MMP.
Wile other guys run down alucinating top speeds I look like a tourist in the straight line. My FDR is like them - 5.7, running 26 degrees advance in ESC and LRP Stock Spec 13.5T with the lowest timing.
The motor is generating too much heat and the car is not fast in the straight.Other guys with similar FDR pass-me by as I was not on throttle.
They have LRP and GM esc's
Settings are:
Xray T3 2011
Pinion 26
Spur 78
Punch 20%
Motor timing (lowest on LRP 13.5T)
Esc timing 26
Cheat activation 10000-12000
For the motor not heat I have to reduce the pinion but i will loose even more straight.
Very disapointed and all the guys tell me to buy a LRP as I am the only one to have Castle, because I like-it.
Please Help?
Nelio is offline   Reply With Quote
Old 08-29-2012, 11:25 AM   #1497
jsinclair's Avatar
What is your start and end rpm of your boost profile
jsinclair is offline   Reply With Quote
Old 08-29-2012, 11:28 AM   #1498
Its 10000 in 12000 out. I also tried 9000 in and 12000 out ant its not faster
Old 08-29-2012, 11:40 AM   #1499
Originally Posted by Nelio View Post
Hello,
Settings are:
Xray T3 2011
Pinion 26
Spur 78
Punch 20%
Esc timing 26
Please Help?
Probably, the problem is FDR...
I Use 10.5T LRP Stock Spec with lowest timing
and this is my setting
Start power: Low(for Asphalt, Medium)
Punch: disabled
Brag Brake: disabled
CHEAT mode: On
Timing: 35
RPM 15.000 - 20.000
Torque Limit: disabled
FDR: 7,5
try it
Lab F1-01
Old 08-30-2012, 06:18 AM   #1500
Punch: disabled
CHEAT mode: On
Timing: 35
RPM 15.000 - 20.000
FDR: 7,5
try it
Hi bro Luppi,
I've tried your setup and my MMP still got Beaten easily by ESC like Hobbywing or dualsky, orca those come with advance timing feature like timing boost and turbo timing.
In fact I've tried ur method earlier with timing as high as 40 but it's still slow and motor gets heat up easily. I have had the Hobbywing ESC v2.1 installed on the same car that was previously equipped with MMP and same FDR same motor it's so much faster and punchy. Does this mean it's the end of our MMP since ESC with supercharged firmware like HW, Dualsky, Orca, speed passion out there are so advance and powerful?
I like castles product and I even use their air ESC too with my plane and Heli and maybe they just too broad with ESC that's why they didn't realized their car ESC is left behind.
Rooks is offline   Reply With Quote
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18835 09-11-2017 07:44 AM
Mamba Max Pro BlueWalker Electric Off-Road 3283 06-20-2016 10:51 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 03:38 PM
the Chopping Block-Crawler Wheels. ESC/Motor Combos-Baja stuff Timmahh R/C Items: For Sale/Trade 9 05-23-2009 11:33 PM
Compatability of brushless ESC's and motors between makes Iceracer Electric On-Road 16 03-21-2007 07:00 PM
