Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-29-2009, 08:22 AM   #1
turbomeyers's Avatar
Default Hpi formula ten setup help
Ok so last night i got to run practice night with my f10(bumpy carpet) and at first it was unmanageable, the back end would constantly slide out regardless of how i was driving so , the scott from the club got me to loosen up the rear diff and it was much better but still so tail spin happy , i would love to get this thing to have less oversteer but i dont know what to do . i have it at hight setting 2 low in rear , i run 50,000wt oil on the friction disk, jack the gripper compound on the tires . i tried to losen off the t bar screw to give more flex and make the rear more grippy . any ideas
turbomeyers is offline   Reply With Quote
Old 10-29-2009, 10:33 AM   #2
swimbikerun's Avatar
Trader Rating: 20 (100%+)
A few general tips but without more details can't really help you,
1. Soften the rear dampening. Check that you have a little bit of sag (ie if you're running 4mm ride height start with .25mm sag and adjust from there to get desired effect).
2. Only sauce 1/3 - 1/2 of the front tires.
3. Check the dual rate on your transmitter. Dial down the dual rate so it's comfortable enough to drive but you have the steering you need.
-XRay T3 (Order Pending)
-AE RC12R5
-Pinarello F4:13
swimbikerun is online now   Reply With Quote
Old 10-29-2009, 11:07 AM   #3
3rd-dan's Avatar
Which tyres did you use?
The Tyres are included in the kit are crap.
Perhaps for using at the parking lot.
Try the Option Tyres Bridgestone M and S.
They work really fine.
And like swimbikerun said, reduce your dual rate.
Cheers Mike
HPI F-10
3rd-dan is offline   Reply With Quote
Old 10-29-2009, 11:20 AM   #4
Yes i am using the dsx2 and i have the rate turned way down . i have no spacers in the spring at all . I did order the bridgstone s tires for it . i will probably run the hpi front and bridgestone rear , the low speed turning is amazing i can tell when i can get the rears to hook it will be an awsome car .
Old 11-06-2009, 10:12 AM   #5
well i backed the t bar screw right off so the back was sloppy and it finally handled , it is a handfull but a welcome challenge . the delay in the acceleration i have programed into it is verry realistic but i cant wait for the new tires . i am starting to love this kit , and its super robust . havent broke anything yet and that impressive . i have a brushless setup coming for it . we will see if the extra speed in the front straight will help with some down force for the long sweeping corner ,
Old 11-06-2009, 11:11 AM   #6
Can you try some different front springs? I'd try stiffer first. Seems as though you have too much front grip
Brevard Electric Auto Racers- Palm Bay, Florida
VTA and RCGT
http://www.bearrc.com
pejota is offline   Reply With Quote
Old 11-06-2009, 11:49 AM   #7
I would but i am not sure what to get (there is not alot of choices out ther for the ften) i am getting it close tho i am sure i can keep changing a few things .i want to add some rear weight to try up the traction , I really like it and hope my local club pics it up as a class to race . i will get a few more guys on it and that should speed it up and get it accepted . it is defiantly more challenging than my touring car to be consistent .
Old 11-06-2009, 09:59 PM   #8
Blueman Austria's Avatar
Forget the Kit tires. With those you will never get the car done.
Whait for the Bridegestones, and you will be satisfied....
Greetz Blueman
_________________________________________________________________
TT01, F201, F103, HPI F10, TB Evo4MS, TB Evo5, TRF415MSXXMRE07, ........
Blueman Austria is offline   Reply With Quote
Forum Jump
Chua Chu Kang Radio Control Modellers Club Superboy Singapore R/C Racers 977 05-16-2007 05:12 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
