Old 10-29-2009, 07:34 AM   #1
Default ezrun tt01 lipo???
hey have just put a EZRUN COMBO 5.5Turn motor (6000kv) with a 60A ESC
just wondering what i should use to power it, i only have the stock fan on the ESC and a small heat sink on the motor
what lipos do you think i can get away with, i was thinking a few of those cheap ebay lipos (2s) has anyone run lipos with this system and how did it go
r32gtst is offline   Reply With Quote
Old 10-29-2009, 08:06 AM   #2
For 6000kv stick to 2s lipo. Be careful with those cheap ebay lipos....also, are you still using the tt01 tub chassis? If so, check your battery size when yu get them. I couldnt get any to fit. Went to the 3racing frp chassis and a maxamps 3s lipo on mine with the losi xcelorin 4800kv motor and esc. Also have an ezrun 4300kv motor, but that has far less torque. Also if yu wanna mess with gearing check out hpi 0.6 pinions. Tamiya only goes up to 25t, but i'm using an hpi 35t pinion + the tamiya 55t spur. Anyways, back on topic. Try to get a lipo with a reputable name and small dimensions. Also, if you want long run times, try to stay around 5000mah. Also, get a decent lip charger.
xed32 is offline   Reply With Quote
eZRUN brushless system 32819toon Electric On-Road 1032 08-05-2013 04:54 AM
4000mah hardcase lipo under $30!!!! Hatebreed Electric On-Road 110 04-01-2009 08:26 PM
SEO by vBSEO 3.5.0
