Xray T1
no1 runs these anymore?
looks to be mega dead
crashed my t1
I run one, but i can't get the setup right. I use the pivot ball suspension, and I'm not happy with the geometry. besides that, I demolished my front drive axle because of radio interference. always nice...
does anybody have a spare one for sale? since there is no factory supply anymore..
how are you guys traying your cells? the only way i can do it is to do 3 at a time as my cable is to short..now the obvious answer is to make it longer but i dont wanto do that.
secondly i am thinking of running the batties down the side for ease of traying and storage does anybody know of what diong this might do to my handeling? im warried about it as my main problem with the car is getting it to handel as it changes all the time for some reason
any info would be greatly appreaciated as ill be going brushless soon and i think ill be needing to tray my cells every time instead of once ina while when i have time lol
If you are keen, refer to this post:
http://www.rctech.net/forum/showpost...5&postcount=40
Hope it helps.
Btw, I had retired my T1 and replaced with a TA05R now in view of the scarcity of parts & support now as the product had been EOL, End Of Life... and Xrays parts are damn Xpensive!!!
Too bad... life goes on...
Likewise I shared that same thoughts as you on the pivot ball suspension. Mine could not hold on to the camber angle well and had to readjusted after every run due to wear & tear... what a waste to a great car!
Pivot Ball hardware
Hey guys. I've got some T1 Pivot Ball hardware, pivot balls, the plastic hold down, hinge pin holders, etc. basically everything BUT the plastic arms (upper and lower)front, and steering blocks. Let me know if you're interested.
pivot ball suspension was only used on the evo series t1's and was never used again for on good reason. it sux
it you can get your hands on some then buy a full c hub set. youll be much happier
parts are no problem for me as ive aquired over the years about 5 full cars worth of parts and all i ever break are the bumper tops
Thanks!
The C hub conversion kit cost a bomb! That is why I retired my T1...
T1R ratios and diff pullys
Hi does anyone know off-hand if the T1 diffs at 2.125 ratio have 34 or 32 teeth pulleys in the diff. It would just save me pulling them out to check.
I am looking for a rubber tire carpet setup for a t1r.
can anyone help????
http://www.teamxray.com/teamxray/pro...AY%20T1%20EVO2
There are a few here.
RedRocket
Still have alot ot parts for the FK cars, both the 04 and the 05 If anybody needs them.
RedRocket
anyone have any t1 parts that want to give them away for free or cheap? Im building a battlebot type oval racer monster.
PM redrocketracing he had a lot of parts from the local track closed.
