Xray T1
" it some tight turns the ass end slides out. can anyone offer some advice?" -
I'd suggest increasing rear toe by 0.5 degree as the easiest way to solve the problem - or drive slower
As to the 04 v 05 debate; I've had both and the 05 is much better at transitioning chicanes and also allows you to get the power on coming out of a corner quicker than the 04...but the 04 is no slouch!
Originally Posted by teamgp
I'd suggest disregarding the lengths and use a setup station to get the wheels straight. Here's a link for building shocks when your ready:
http://www.teamxray.com/xforum/viewtopic.php?t=602
i figured out the servo save problem as well
and ill figure out the wheels and check the link
hey everyone,
i posted a thread on this already but i was wondering if you guys could help me out
i got given an Evo2 rear ultra-tune shock tower and i wanted to fit it to my xray T1(the original w/ pillow ball suspension).
the problem is the shock caps hit the tower if i try and use the top two rows of holes so im limited to the very bottom row, but that makes the ride height too high.
has anyone else fitted it successfully to an original T1???
if so how do i??? or do i need to buy different shocks???
your help will be GREATLY appreciated
thanx
robbie
thanx
robbie
Originally Posted by xray racer
hey everyone,
thanx
robbie
thanx
robbie
will it have any affect on the handling cuz the shock will then slope backwards very slightly???
thanx
robbie
thanx
robbie
Can you adjust the ride height by adjusting the spring collar + downstop screws ? Last resort you must use additional spacer top and bottom.
thanx
robbie
thanx
robbie
How to make XRay T1 FK take corners incredibly fast ? I get low speed at corner entry and mid corner. I can't push it faster because the car make wide radius ( understeer ).
Tell me your magic recipe
Can someone help me and tell me what size set screw I need for a Motor pinion? I have some set screws but the thread pitch is different from the motor pinion set screw. Is there a company which sells them in packs of 10 or 20? Are these set screw metirc or standard sizes? I am using pinions from Xray.
I think robinson racing sells a package of set screws. I remember seeing them at the LHS. The kimborough pinions are smaller, like .05.
x-ray t1r
has anyone ever altered the car's rear roll center by moving the rear arms to both upper holes 3 and 4? if so, How did it feel in race conditions? i don't have much time to try it out myself but curiosity is killing me! please help!
thanks O.R.
thanks O.R.
The faster corner speeds of the 05 are definitely noticeable. The steering input is much less in order to carve up chicanes as well. I had my XRC 04 setup well enough to win a few stock A mains. But after a buddy of mine went from a BMI 04 to a stock 05, it was hard work trying to make up the speed he had gained mid corner. So I quite naturally jumped on the bandwagon and acquired an 05 after selling a rib or two to scrape up enough funds. He was an average B main driver before. But his lap times dropped immediately from 12.5's to 12.1's. The 05 seems to accelerate harder out of the corners as well.
Fk04 chassis
Another ? regerding the 04 chassis, I just bought one and replaced my T1 chassis I need to know what antenna mount should I used or where to mount the antenna.
TNX
TNX
Xenon rims not fitting?
Had a really annoying problem this weekend at Hitec. I glued brand new tires onto Xenon rims, but the rims kept working themselves loose (and then flying off) as hard as I screwed them on. It seems that the Xenon rims don't quite fit the Xray hubs. Anyone?
Do you use the coned washers between the screw and rim?
If you are, maybe you can use some threadlock to keep the screw in place.
