Like Tree3Likes
Xray T1
Old 04-23-2005, 11:13 AM
  #11791
NVisible's Avatar
Anyone have an asphalt setup for the FK?
This is my first time outside (all carpet before) and a starting point would really help
NVisible is offline
Old 04-23-2005, 06:14 PM
  #11792
T1Raycer's Avatar
http://www.mytsn.com/setups/search.asp
there are some asphalt setup over there!!!
Later!!
T1Raycer is offline
Old 04-23-2005, 06:16 PM
  #11793
S-T-R-l-K-E-R's Avatar
NVisible you got pm
S-T-R-l-K-E-R is offline
Old 04-23-2005, 06:39 PM
  #11794
NVisible's Avatar
STRIKER, thanks a lot!
NVisible is offline
Old 04-23-2005, 08:44 PM
  #11795
Deves's Avatar
Anyone have a good gear setup for a Quad mag motor with 2.125 internals on large track?
I never ran one of these motors and I don't want to burn it up.
Deves is offline
Old 04-29-2005, 08:27 AM
  #11796
Trader Rating: 104 (100%+)
I just bought a used evo and wondered if I could put a FK04 chassis on the car? I am thinkin of ordering the BMI chassis but do not know if it is compatible.
It already has the shortened arms and c hub set up on it with the lower ratio pulley.
Here is the pics of the car... Thanks for your help
dan-o is offline
Old 04-29-2005, 09:07 AM
  #11797
NVisible's Avatar
yep, should fit. the evo2 and FK chassis are the same
NVisible is offline
Old 04-30-2005, 12:54 PM
  #11798
alright guys i have t1fk, what should i do to make it better. thinker chassis different shocks etc. give me some input.
zinger77 is offline
Old 04-30-2005, 03:46 PM
  #11799
Deves's Avatar
Where do you race? carpet or asphalt?
Deves is offline
Old 04-30-2005, 03:49 PM
  #11800
high bit carpet
zinger77 is offline
Old 04-30-2005, 03:55 PM
  #11801
Deves's Avatar
you need a carpet setup I'm sure someone on here can help you.
I race outdoor on asphalt.
Deves is offline
Old 04-30-2005, 04:20 PM
  #11802
thanks deves
zinger77 is offline
Old 04-30-2005, 04:41 PM
  #11803
NVisible's Avatar
if you want another chassis you can get the XRC chassis or go the BMI route and get either the split or the .350
as for setup, theres some at www.teamxray.com you just have to search for Factory Kit and then the downloads section
NVisible is offline
Old 05-05-2005, 11:03 PM
  #11804
asw7576's Avatar
Guys.... I need your advice :
My T1FK is very slow during mid corner entry. Even tamiya TT-01 with silver can is able to match the entry cornering speed
If I enter corner too fast, the car have tendency to go wide losing my racing line.
If I immediately push the gas ( don't let the car behind me to pass ) the car could easily spin.
I need more speed at every corner entrance.
What necessary tips should I consider ? Just give me the tips and I'll check the possibilities of each tips. Thanks guys.
asw7576 is offline
  #11805
asw7576's Avatar
sorry, double post.
asw7576 is offline
