Xray T1
Re: Help...
Originally posted by Robz
I really want to take peoples opinion on the weight distribution on the car. Me and a friend have been working on a solution to making it more even. If you start staggering the cells you get different handling when turning left to right. I wanted to try and move both sets 1 cell forward or maybe even moving right set forward 1 space and left set 2 spaces. Only one stagger shouldnt give it wedge! To move the right set you need to do somthing with the servo, what you guys think. Anybody tried anything like this or at least thought about rear bias to weight distribution.
Re: Mods Continued...
I hate wires running all over the chassis so i found somewhere to put personal transponder
That is a pretty cool idea, but have you run it that way yet? I would be somewhat concerned about the transponder wires may move around upon crashing and then may start rubbing on the belts.
Mike
Originally posted by chach
From what I can tell, and why I purchased the XRC chassis, Xray mills out the servo mounting area and a few other key places, where as it looks like BMI just removes material where the bulkheads go.
Mike
Hey michal
Yeah ive run it with transponder there. It works fine. The wire is colied tightly and doesnt move very easily. Seems to work great
Still cheaper than anything out there.
Have you guys ever heard of "Jwerks Racing Concepts?" They make what appeard to be a nice titanium screw kit for the FK.
indeed!
Originally posted by kaizen
Hey racenut,
Have been a little consumed since the Regional, but I am going to make it out again soon. Can't wait to run with you guys again..and you! An Xray even! Nice! What chassis are you running?
See ya soon!
Hey racenut,
See ya soon!
The only problem I was told about the Jwerks Racing Concepts screw kit, is it doesnt come with the 2.5mm screws to hold the wheels on!. Where can I get some for the wheels, since I think the chrom on the black washer would look HOTTT!
The RCScrewz stainless screw kit is awesome. It comes with all the screws on the car and I had just under half the box left when I was done replacing all the screws. You get more that $22 worth of screws. Great way add weight to your FK to bring it up to weight.
where to get BMI chassis ??
Are you sure the graphite used in BMI chassis is better quality than in XRC ? could you describe it ?
Look in my sig or go to BMI thread. Jason is a great guy to deal with. The easiest and fastest way to have your questions answered is to call them directly.
But if i remember correctly, stainless screw is made out of mild steel.
I happen to use stainless screw before on my EVO2, and it is easily stripped if it happens to be very tight. You would have problems removing it.
Originally posted by AdR|aN
Correct me if im wrong.
