Xray T1
#9483
Carpet setup
Anyone got a good carpet setup for the FK..
Running rubber tires, sorex 28/24 or takeoff 27/22
19turn...5 mm ride height...
dont know the layout yet but just looking for a general setup..
#9484
Originally posted by N4S
Customs has released the containers !!!!!! They say it will take a few days to log it all in , but they should start shipping by the end of the week
#9485
Re: Re: FK Glitching
Originally posted by Besercoe
War11x - look for the most obvious tings first. look for damaged/loose wires, try different crystals, different motors even borrow a mod motor they are less likely to exhibit glitching, solder the capacitor points on the end of the epic motors. etc
Also get someone else at the track to take a look, it can sometimes be something obvious that you cant see.
Well my Issues with Gitching have been resolved
when i changed electrics from one car to the other i installed DEANS plugs on the motor to allow quick motor changes after having a think about it all ( i calmed down from my Hissy Fit ) this was the only change made from car to car ( However it did not clitch in my Evo 2 )
i removed the DEANS and Presto !!! no issues ,car was perfect
Cheers To All for your words & advice
#9486
I also run deans between the motor and speedo for the same reason, had some gliching problems but can't say it was the cause. Now I have a little jewel called the noise stopper by Yokomo plugged in between the speedo and receiver and have no problems anymore.
#9487
#9488
Re: Re: Re: FK Glitching
#9489
FINALLY
also where did you read/find this info
#9490
Re: Re: Re: Re: FK Glitching
Originally posted by Neil Rabara
It's hard to believe it's the Deans plugs that caused the glitching.
i was in the same frame of mind , however removing them confirmed this was the cause of my issues
even now i still cant belive it
see we learn somthing new every day
CYA
#9491
Hi guys..... I'm thinking to buy another RC cars for serious race, and here is my shopping choices:
Tamiya TB Evo4 x 2 unit ( 1 for test / play, and 1 for race only )
Tamiya TRF 415 x 2 unit
XRay T1 Factory x 2 unit
Yokomo MR4TC SD
From your race experience everywhere around the world, which car is born to be the champion ? And I'm also considering the strength / quality of material use. I don't like spending time fixing broken parts. Thanks guys......
Yokomo MR4TC SD
#9492
Yokomo MR4TC SD
Yokomo MR4TC SD
their all great TC's
#9493
Yokomo MR4TC SD
Yokomo MR4TC SD
BTW: Get the Xray you will have less headaches at the end of the day. I decided to try an other car and I'm starting to regret it.
#9494
Originally posted by pucho
If you get two cars do it because you run two classes. You should always race what you practice with and practice what you race with. All cars will have slight differences even if set up the same.
I have the X-ray and I'm very happy with it.
The only thing I don't like are the Alu screws that come stock with the kit.
They are very soft, and strip easely.
Bye Thomas
#9495
pucho, any chance you're referring to the Yokomo... I'm about to try their CGM... Currently running the original T1 (although it's slowly turning to an evo2)... I'd like to try shaft again...
