Xray T1
#77
Regional Moderator
Manitcore: But without the motor opposite the battery, wouldn't it take quite a bit of weight to offset the battery? That would also make the car quite heavy wouldn't it?
O'well I guess Xray has accounted for all of this already, I don't see how though. I still like the usual battery layout for the T1 and Corally C4.1.
#78
Maybe Xray are thinking about breaking into the "Oval" market!
#80
Originally posted by safaridog
Is it just me or does the 24 tooth pinion they supply in the kit very under geared? I pretty much find useless with the 90 tooth spur that came with the kit. I ended gearing it 31/90 with a 11x2 just to keep up. What's everone else geared at?
#81
Originally posted by dtm
Woo.... 90/31 for a 11x2, thats a total gearing of 6.169 you must run on a very large track or have a very "hot" motor at the end of the pack. I run 125/35 total 7.589 with an 11x2 on a tight technical track. At 125/36 my brushes will start to discolour!
#82
Originally posted by Manticore
xray has some nicely made lead weight for the purpose of balancing the chassis.
Have you seen these in Mong Kok yet Manticore?
#83
you're not running 7T single?
11x2 is my favourite motor for PYC!
#84
No lah.... thats reserved for my micro!
#85
I wonder if you can stack 10 of them together and make an antenna!
never seen it in MK.
#86
we run on a above average track size , it measures 160' x 80'
check it out
http://members.home.net/rccar/
we just held the Canadain nationals last weekend.
check it out
#88
[QUOTE]Originally posted by 29TC
Is there anymore X-Ray T1 Kits with Hudy-set Up combo out there?
I am assuming, the above quote that the T1 kit came with the Hudy set. [/QUOTE
There's a T1 kit at my lhs has one with the Hudy-set up, They only have one in the store. It's in Daly City Ca.
Damo: I'm intrested in the wrenches only, let me know how much you want them for it, if over 40 don't bother, i could get it for 50 from a friend.
#90
check it out
check it out
