Xray T1
#7786
Originally posted by TraceRacing
I've heard the rumors as well, from my LHS...
Methinks CML/Helger are hot contenders for the biz....
#7787
Originally posted by MR JOLLY
Neil
Can`t tell you it`s a secret
Neil
#7788
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Neil
Just messing about,joking & all that
There is a romour that the distribution for x-ray in the uk might change from centre point to ------------- who knows?
And in my defence i did`nt metion it first, rick did!
#7789
You're right, Rick did. Sorry about that.
#7790
LOL @ Jolly....uh huh blame it on him...
#7791
Anyway it`s boring now, lets get back to basics
The kit x-ray oil(30wt)?
I have used yokomo 30wt could this be the reason it feels springy on the back.
if i put the two bottles together vertically then turn them horizontally x-ray oil takes longer to settle flat?
To get the two to match i have to go to 45wt (yoko) to be the same settling speed, does this sound right(x-ray oil similier to yoko 45wt)
#7792
I know the secret
MIRAGE HPI in the uk now have distribution rights.
There the secrets out
#7794
dr_hfuhuhurr,
Are you going to be at Road Rage 4? I see you are in the area, and I think I'm gonna come down with the Michigan boys!
-Kevin
-Kevin
#7795
Spring Steel Hex Hubs
I have read a few posts about the Aluminum hex hubs expanding on the FT car. For those of you who have experienced this, are you replacing all four hubs? Just fronts? Or rears?
Thanks.
Thanks.
#7796
Just the fronts, not the rear.
#7797
Cheers.
#7799
Location: Built By The Racers For The Racers. Corona CA
Originally posted by dr_hfuhuhurr
Yes, I believe you're correct. The XRay oil is about 10 - 15 heavier than it's peers.
I also know that Losi oil is heavier than Associated Oil. I just learned this and have since swapped out all my oils for the same brand.
Blake
Blake
#7800
Originally posted by Brian McGreevy
Neil, about how heavy are the spring steel hubs in comparison to the regular alum and the FK alum hubs.
