Xray T1
#7771
Originally posted by Neil Rabara
If you think the Evo2 FOC is a beast, you should run the FT.
#7772
Things are gonna change for Xray in the UK soon from what i hear on the grapevine. Rick
#7773
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Andrew
Roll centre on bulkhead is top row out of three
Springs are the kit ones(white)
Shock mountings are
Shock tower kit(3rd hole in)
Wishbone inside,kit is(outside), if i use the outside hole i can`t use 26mm rims(t27mounting)they rub a bit(do i have to dremel) either ball joint on end of shock or the rim?
Shock mountings are
#7774
Rick
I have heard the rumor aswell?
Where did you hear your`s from?
#7775
Originally posted by MR JOLLY
Rick
Rick
#7776
Rick
My romour is`nt so reliable as your`s?
You must know some usefull friends
Up north i heard
Up north i heard
#7777
Rick
Up north i heard
Rick
Up north i heard
#7778
Registered User
Centre Point aren't going to have much left at this point!!!
Interesting situation for there team drivers
Ben
Ben
#7779
jolly- run outside and either shave the rim a touch or shave the shock end
with foams its hard not to have anything rub
so run outside and shave the shock end and i would also suggest going to the middle roll center holes
#7780
I do feel sorry(a little anyway) for gavin & co(if it is true)
Centre point could of made it work bigtime for them, it is such a good car & they are expanding (x-ray), touring,rallycross & that silly little 1/18 thingy
Any clues who might have it?
If this was on rcracechat we would be banned by know,spreading gossip & all that fitzgerald would be having kittens
#7781
Andrew: is it possible you could post some pics of your car...showing how much material is removed on the arm for the outter shock hole to be used and how much you remove on the shock bottom.
Thanks!
Jolly!!! Whats up man? You get the back end of the car figured out yet?
Thanks!
#7782
Promatchrcr
I`m just in the process of sending you my pics of the car actually i put it on here also
#7783
I've heard the rumors as well, from my LHS...
Methinks CML/Helger are hot contenders for the biz....
#7784
#7785
Neil
Can`t tell you it`s a secret
