Xray T1
#7711
The low ratio pulleys were designed for the locked or solid layshaft. You will need to get that and replace the pulleys with the low ratio pulleys.
#7714
hi guys,
just checking does the T1 EVO2 have the same belts as the Factory kit?
#7715
Originally posted by Hixsy
hi guys,
hi guys,
-etzkev
#7716
they are the same as the evo 2 yer same size ect..
#7719
Regional Moderator
Originally posted by xxxkat
Has anyone put the short arms on their T1R ? And if you have, is it worth it.I do know you have to do a "little work" to get the mounts to fit(in the rear)So I was wondering if the performance is enough to make the change...I already have everything else on this car..
#7720
#7721
-Kevin
#7723
One way or Diff what is the best for asphault, smooth, good Bite?
#7725
Location: Built By The Racers For The Racers. Corona CA
Re: ?
Cya bright and early bro, are you running stock and 19T tomorrow?
John G.
