Xray T1
#6961
Yup-on carpet. I am buying a $30 car tonight to run 4wd sedan outdoors. I am like RB-I cannot see myself running this beautiful and $$$$ car and scratching it up and gettng dust in the bearings......... Of course-if I lived in CA or FL where they race outdoorsd 24/7, but you know how it is here in oHIo.
Ray
Ray
#6962
Gearing
I just got a T1FK and I need some starting points for gearing a 10x1, 19t, and a stock motor. Any help would be greatly appreciated.
#6963
Originally posted by rayhuang
Bsydor "D"-since your runnin-one-ways-that means you must have an extra 1.77 Diff laying arounf right? PLease sell me one or two of them. I have two problem diffs on my car.
and I use diffs when I go out of town to a bigger track. But I do have a extra one. I also have a extra FK too. Send them to me and my semi-world class pitbiatch will fix them.
Talked to Jason today about 27t Quad motors- he wants to borrow one of mine for this weekend
p.s. Call me-youve got the number!!
"D"
#6965
Front camber link?
I have a T1FK, how will the car react if I put the front camber link in the shorter, front bulkhead holes? Do I need to add spacers to raise the ball up level with the shock tower holes? Will this increase steering going into a turn or out of the turn?
Thanks,
Paul
Thanks,
Paul
#6966
Hey guys, i order the evo 2 four weeks ago and it was on back order. but i got a call from my dealer and it is on it's way
any quick tips
thanks wap
any quick tips
thanks wap
#6967
Re: Front camber link?
Thanks,
Paul
Thanks,
Paul
#6968
any quick tips
thanks wap
any quick tips
thanks wap
Throw the kit to the Hudy Set Up station.
Set up the car at stock set up.
And enjoy ~~~~~~~~
#6969
Thanks,
Paul
Thanks,
Paul
Alternatively, changing the camber gain also impacts the roll center of that end. Generally, the shorter, more angled camber links will reduce the mid corner grip. It will also impact the rate of roll into and out of the corner.
So a shorter link may reduce the amount of middle corner grip by changing the roll center; unless you expose the softer inside donut - then you get more grip. Untill you get so much camber change you reduce the contact patch substantially. Got it?
Oh, dampers, springs, weight distribution, caster, ackermann also impact this.
So - Not only is this a driving style thing, but also a tire, and other setting thing.
Your car is a system, you need to learn how changing one setting will impact the performance. You might make it better in one area of the track, but worse in another. Ultimatly setup is a compromise to maximize grip and balance, and minimize drag and unpredictable behavior.
Best advice - get lots of practice and ask for input from other drivers at your track. I've yet to meet anyone who is not willing to help.
#6970
Sands-ran the BMI Xray last night-one lousy pack is all I had time for. Cars got mad potential and given that I hadnt driven an XRay for months and even then it was one or two packs and a completely new set-up (I usually make one change at a time) I went faster than with my other car and felt very comfy driving it.
ON-power push though. I ran something close to Josh's Nats set-up, but had 3mm rear uptravel (droop), Blue springs in back and the fornt camber link in #2 not #3 on shock tower.
I am guessing and hopefully with your input that going to 2mm droop, #3 front camber link and violet springs should bring about a lot more rotation and square the car up on exit?
Thanks,
Ray
Thanks,
Ray
#6971
Originally posted by AdR|aN
Built the kit as per instructions.
And enjoy ~~~~~~~~
And enjoy ~~~~~~~~
will the evo 2 fit on the hudy without modification
with the 710 i had to extent the holes
#6972
thanks i will
thanks i will
#6973
Speedmind spur gear
Do they fit Xray?
#6974
Thanks true
expecting x-ray on saturday
#6975
expecting mines tommorrow...
