Xray T1
#5866
Pucho:
Hi,
I was going to change the Alumium rear hub carriers to plastic but I need a longer dog bone/axle(?). also can you buy shock springs in pairs instead of a complete box. (like 50 bucks up here). Jason says Hi,..........he's going through the same thing you are only for karting. he is about 20 pounds over the weight for his class. so I'm starving him......( feeding him all the good things)...... he really bulked up for football and that hurts too.
also I have a fine tuning front shock tower. it that the same as the carpet one????????? sorry about all the Q's but i'm just getting used to the Xray after the TC3.
and tell Alex to be a kid as long as possible....it suks getting old.
Hi,
#5867
wannaba (kevin) is getting another xray chassis? I just bought the one he had a couple months ago.
#5869
Originally posted by TimXLB
Pucho:
Hi,
Pucho:
Hi,
Luis
#5871
Blake
#5872
I sure do like my xray from Kevin, we run an unlimited mod class here in Austin so I put a brushless setup with some new double purple foams and the car is a rocket on wheels.
#5873
Hey just got back From Fullthrottlespeedway(Kissimmee Fl) And 2nd time driving my EvoII.... Speechless. Cant Complain, the first 3 quailifiers consistant with 19 laps (tq-21 laps) then Main I Came Back With a Better Battery and Hit 20 laps and was 1st place for about 2 min. then someone accidently Moved in the way and hit but it was all good cause my pit memeber Tony Was 1st and i was 2nd. 2nd Time Driving car And was Best main i have ever ran. Seems Like I knew what setup to put to how i like it, and it worked. With others car i never really Made big changes like this. I wasnt the fastest but i stayed consistent. Thanks to Alex Lopez Giving me a Setup but i changed it a little Bit because not everyone drives like alex lopez So Soften it up a little bit and Was dialed. The Most amazing thing was i normally race Stock. and i was racing against like expert class people since there was like 10 of us and i held up. Cant Wait for SNOWBIRD!!
-Ariel Vittini
-Ariel Vittini
#5874
Does anyone know if serpent or hudy will replace bent axles? I have about 4 that are bent. I know lunsford will replace bent turnbuckles, but I doubt serpent will.
Where are you guys kart racing at? I race in the Championship Enduro Series here in the Midwest. Race 100cc Situp Sprint.
Also what are some things I can do to get more on power steering? I went back to the 6 degree like Alex suggested, but then the rear was out to lunch, so I put 3 degrees of toe into it now it is fine. But I still could use a touch more on power.
#5875
Dunno either, but I do know that Titanium doesn't bent much.... just break... maybe thats why say that the can replace the bent ones, ask them if they'd replace the broken ones...
#5876
Scrad:
Hi,
We race Karts in MI at the East Lansing Kart Track (www.karttrack.com) Jr Supercan/KT 100 sprint class
Pucho:
Hi,
Jason played both this year. Thanks for the info on the front shock tower. all I have is the kit one. and the pillow ball one.
yeah it's all about the motor and suspensions as far as I'm concerned. Jason wants to do a import as soon as he can.....(I'll get really old fast then ) and I thought karting was enough to keep him happy.
Hi,
Pucho:
Hi,
#5877
Hi all
I am just about to order an X-ray. Here is what I plan on ordering.
X-ray FOC kit
Alu. Shock bodies
Spring Kit
Roll Centre Bridge
One-way
Alu Layshaft
My question is, with the alu. layshaft, do you HAVE to get the low ratio pulley set?
John
X-ray FOC kit
Alu. Shock bodies
Spring Kit
Roll Centre Bridge
One-way
Alu Layshaft
John
#5878
Originally posted by PorscheSuperCup
51mm drive shafts are meant to fit into a c-hub kit or just the rear pivot balls....this is def a Evo or something newer
One thing I find odd is how quiet the new parts section is...
#5879
Re: Hi all
X-ray FOC kit
Alu. Shock bodies
Spring Kit
Roll Centre Bridge
One-way
Alu Layshaft
John
X-ray FOC kit
Alu. Shock bodies
Spring Kit
Roll Centre Bridge
One-way
Alu Layshaft
John
