Xray T1
#5656
Originally posted by RCCadet
Under the screw for the front hubs and under the hub with the rear.
Thanks for the response. So under the screw for the front, and for the rear just under the hub or the part where the set screw goes in? Also what is a good droop setting for front and rear when running 57mm tires?
Thanks again,
#5658
Front Anti-Dive
Hey guys, I have a question for ya:
When I set the front Anti-dive to 3 degrees the front of my car raises way up. I can't get it to go under 6mm ride height. I'm also using the front Carpet shock tower and my tires are 57mm.
Help very appreciated......
thanks again,
thanks again,
#5660
Originally posted by dr_hfuhuhurr
Read 6 posts up from yours. The answer is there.
THANKS!
#5661
Re: Arm stiffness?
Where would you want to use the Soft, Medium, and Hard arms respectively? Also, should you use them consistently from front to back?
These are for fine tuning, i.e. you have a good working setup already, but you still want to slightly alter the cornering balance of the car. Changing an angle (camber, toe, shocks, etc.) or springs/damping might offer too much of a change and/or have a negative side effect, so these are just yet another tuning option.
#5663
Re: Arm stiffness?
#5664
Originally posted by JCB
Ok, thanks again. I just need clarification for the rear, do i measure from the hub or where the set screw goes in? Also what's a good droop setting for front and rear? I'm using carpet shock tower with 57 mm tires.
THANKS!
THANKS!
#5665
Originally posted by Trinityracinnut
I have noticed that on my left front shock, it has developed a leak at the bottom. What can I do to fix this?
#5667
Short Arms
Called ashfordhobby.com yesterday and have 2 sets of the rear short arms, and 1 set of the front short arms. Does anyone have any pics or quasi-instructions on what's needed to install them.
Car is in pieces right now for a re-build. Everything is taken apart. Tonight Everything gets cleaned. Woohoo!
#5668
dr_hfuhuhurr,
What are the part numbers on those short arms?
Phil Matthews #99
Phil Matthews #99
#5670
T1M
Any word on T1M ?
