Old 09-24-2003, 08:24 AM   #4756
rc-zombies's Avatar
Originally posted by Scrad
That's the new diode for the GT7 I believe.
Nope... the new diode is soldered onto the positive and negative wires..
I think that is a magnetic filter.. same kind found on some computer cables. Hara used one on his Pro4 at the JMRCA race.
Old 09-24-2003, 09:36 AM   #4757
stik,
Just curious how you are wired to your motor. Did you solder corally style plugs to your motor?
jbackslash is offline   Reply With Quote
Old 09-24-2003, 09:41 AM   #4758
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
When you guys installed your low ratio pullies, did you end up going down on the pinion from your original gearing before the new pullies. Because I burned up a motor last night and I could never get the car geared right. It was stock with rubber tires, btw.
Another question my mod foam last night was very fast, but when I would sauce my tires the car would traction roll for the first half of the race. Otherwise the car handled great. I did notice that my ride height was very high inconjuction with new tall foams. This would most likely be the problem correct?
I did change my pinions based on the 1.77 gearing. The formula is pinion/spur x internal ratio. Say you ran a 124/31, with the 2.125's this would be a 8.5, but on the 1.77 internal would be a 7.08. This is a huge difference. To get the same 8.5 like on the 2.125 you would have to run a 124/26 combo ~8.44. So there you can see the difference.
Also, high ride height will traction roll....are you running anti-roll bars?
Hope this helps.
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 09-24-2003, 10:14 AM   #4759
Scrad's Avatar
Trader Rating: 15 (100%+)
I ended up going down to a 22 from a 30 that I used to run. It did seem better, but I think I had my GT7 programed wrong because I had no punch at all.
I don't run roll bars, they never seemed to work for me on other cars, so didn't buy any with my Xray's. I lowered my ride height, but didn't get a chance to try it out. I probably had about 8mm and didn't notice it.
Thanks for the help. I just need to clear things up and make sure what I thought was right.
Scrad is offline   Reply With Quote
Old 09-24-2003, 11:30 AM   #4760
Tip for the GT7, I run programs 4-6 with 6 being the most predominant. This has the lowest drive frequency and seems to be the best for mod motors.
8mm is kinda high for ride height, I generally run 5-6mm. I have had good results with my antiroll bars. I run both front and rear and very rarely roll the car. Seems very planted on all surfaces that I run. Carpet I run 45, while outdoor asphalt I run the front at 0 or flat.
Old 09-24-2003, 12:58 PM   #4761
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
i use the uptravel method as well.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 09-24-2003, 01:32 PM   #4762
What do you guys think wou ld be the best thing to buy for a evo2? its all stock and has pivot balls? How are those new pullys, are they freer?
teamAE is offline   Reply With Quote
Old 09-24-2003, 01:36 PM   #4763
Accord's Avatar
Send a message via AIM to Accord
The 1.77 pullies are a MUST HAVE.
Accord is offline   Reply With Quote
Old 09-24-2003, 01:41 PM   #4764
Ok I will be picking some of those up. What the finial drive with those?
Old 09-24-2003, 02:44 PM   #4765
Scrad's Avatar
When you guys spin your low ratio tranny does it spin for awhile.
My stock tranny and low ratio spin about the same amount of time. I think my low ratio tranny is bound up somewhere, but I've taken it apart a few times and it never seems to spin longer than the stock tranny.
Would it spin longer or can you only notice the benefits on the track. I can't say I really noticed a difference in how hard it accelerates. However I put the pullies on in the summer, so I never got to test it back to back.
Old 09-24-2003, 05:57 PM   #4766
Belt Problems
Hi! Im running the 1.77 system. My problem is when I put in a smaller pinion gear, the belts especially the rear one touches the motor. Not sure that this should be avoided or not. I'm running 128/27 with final ratio = 8.39, I need to go down to around 10 or even a bit more. Please help! I don't want to give up my 1.77 system. Thanks!
octavone2003 is offline   Reply With Quote
Old 09-24-2003, 06:20 PM   #4767
You need to use a bigger spur to achieve the same rollout with the new pullies
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 09-24-2003, 07:04 PM   #4768
Originally posted by Hatebreed
What is that black thing on the cable? Is it a schottky diode?
hatebreed: that's a "clip-on" ferrite magnet to reduce electrical noise. I experience occasional glitch and that thing seem to help. You can find them in eletronic or computer supplies but that one the pics is from Eagle racing which is smaller than the ones I can find from eletronic stores.
stik is offline   Reply With Quote
Old 09-24-2003, 07:04 PM   #4769
Default Spur gear
I notice that! Yet I think the biggest spur gear that I can have from the market is 128T, do you know if there is anything bigger than that? Thanks!
Old 09-24-2003, 07:05 PM   #4770
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Can you get bigger then 128?
I am running 125 25 and mine are fine
mike_Webb is offline   Reply With Quote
FS - NEW !!!! XRAY NT18T and XRAY NT18 plus HUDY micro truck starter box w/ battery Omarko Australia For Sale/Trade 2 06-25-2008 07:47 PM
Xray T2, Brushed Motor Combo, Setup Tools, Xray Springs, Bodies etc... GroffBall R/C Items: For Sale/Trade 13 09-23-2007 07:53 PM
WTB: NIB Xray T1FK05 & Xray Teflon coated aluminum Shock Body Adam.A Australia Wanted to Buy 4 01-02-2007 02:30 PM
WTB: Xray T1FK05 & Xray Teflon coated aluminum Shock Body Adam.A R/C Items: Wanted to Buy 1 12-30-2006 02:26 PM
XRAY sedan spring kit / XRAY multi-diff / PRS 114t spur / RR 64p pinions / Stratus evostyle R/C Items: For Sale/Trade 6 12-19-2006 08:33 PM
