LOSI XXX-S, Tips and Tricks, Open Mod, etc >
Like Tree5Likes
Old 02-23-2015, 12:19 PM
  #871
GhostTown's Avatar
I messed with the low roll center blocks my first week and an half after reading so much about them on this site. Paid all the money and then more off ebay for the MF front and rear blocks. That was the only way my droop screws would even touch the arms. The car never felt right, so I decided to go back to the stock set up from the manual. This helped a lot, but raising the arms back up to high roll center lifted them away from the droop screws. Seems like the only droop I can achieve is about 6.
I'm on a very tight track of around 65/70 x 40. High bite carpet.
There is a set of acer ceramic bearings on ebay for $69. I'm tempted..... but that's a good chunk for something like that.
GhostTown is offline
Old 02-23-2015, 01:10 PM
  #872
mthomas's Avatar
Trader Rating: 16 (100%+)
Buy Avid, they are only $1 each. Their website has listings for all cars with bearing sizes or you can get them off the manual. Shipping is quick, order the ones with the yellow covers.
mthomas is offline
Old 02-23-2015, 01:43 PM
  #873
GhostTown's Avatar
Awesome. I'll look into that. Thanks a ton!
Old 02-23-2015, 01:45 PM
  #874
Johnny Wishbone's Avatar
Why not get longer droop screws, they're just 4/40 grub screws you can get at any hobby shop.
Johnny Wishbone is offline
Old 02-23-2015, 01:51 PM
  #875
theproffesor's Avatar
Trader Rating: 66 (100%+)
I get the avid bearings with the yellow shield on one side and metal on the other. Put the metal shielded side to the inside of the hubs and diff holders. But avid bearings are great. Mine last 4-5 race days before the hub bearings get gritty. Pull the teflon (yellow) shielded side blast with some motor cleaner from metal shielded side, or put some motor cleaner in a small container with a few bearings, shake for about 30 seconds and good as new. Never had a problem with the larger diff carrier bearings.
theproffesor is offline
Old 02-23-2015, 02:16 PM
  #876
GhostTown's Avatar
I just soaked my stock bearings in motor cleaner over night last Friday. Re-oiled with a quality oil. Made a huge difference going by the ol "spin with the fingers" test. Haven't run the car yet.
These avid bearings, the cheaper $1.00 type... they're that much better than stock?
Old 02-23-2015, 09:17 PM
  #877
EDWARD2003's Avatar
http://page2.auctions.yahoo.co.jp/jp/auction/b169358695
Look what I found...
EDWARD2003 is offline
Old 02-24-2015, 05:21 AM
  #878
GhostTown's Avatar
Originally Posted by EDWARD2003
Nice. I'd be all over that if the car were in the US. Great price.
Took 1st last night. Car is handling great. I've come to believe that battery power is my largest draw back at this point. Three of my 1800 packs suck... bad. However, I was still 3 full tenths on over all average faster than last week. 4 of the 9 cars were running Lipo's.
We race on Wednesday nights, too. I won't change the car for that run, but Friday I'm going to go practice and see what stiffening my springs and oil does. Seems like every set up I see posted is much stiffer than what the manual suggests. I haven't tried that yet. I also bought a third car and a large box (14 pounds all together) of parts that should be here tomorrow. It's a g+ car. I might mess with that Friday, too.
Old 02-24-2015, 05:34 AM
  #879
mthomas's Avatar
Comparable or a tic better and much cheaper.
mthomas is offline
Old 02-24-2015, 03:49 PM
  #880
fathead's Avatar
Originally Posted by mike5009
When will the spur adapter be ready for purchase?
I should be machining a batch end of next week.
fathead is offline
Old 02-24-2015, 05:21 PM
  #881
bigfatslob's Avatar
Smile
I can't wait
bigfatslob is offline
Old 02-24-2015, 06:41 PM
  #882
If you are running NiMH batteries and your competition is not, you are at a serious disadvantage. LiPo packs will make your car significantly faster. Big difference between 7.2 volts versus 7.4.
microed is offline
Old 02-24-2015, 07:04 PM
  #883
GhostTown's Avatar
The class spec requires 1800 nicads. I'm running 1800 nicads. Rules seem to be rather loosely applied when the guys from the next town over show up. I'm running 1800 nicads, per the rules.
Old 02-25-2015, 11:20 AM
  #884
mike5009's Avatar
Thank you
mike5009 is offline
Old 02-28-2015, 12:00 PM
  #885
tmail55's Avatar
Trader Rating: 61 (100%+)
Tested in front of house, worked great, was planning to race test today RAIN!!!!! <<<
Sanding disk p180
B4 slipper pad
B4 spur 84t
Wanted a spur option other than what Losi has to offer. Did NOT have the spur adapter.
Having done the file card spooler to the front diff, got to thinking!! Don't remember who on here shared the "file card" spooler tip, THANKS!!!
Looked thru the parts box and came out with a XXX4 spur gear mount. A bit of Uni-Biting a AE B4 84t spur (top gear in picture) to adjust the center hole of the spur to fit the XXX4 mount.
Using the AE B4 slipper pad to make "spooler pads" out of the P180 grit sanding disk. The sanding disk is sticky on one side to keep it on a sander pad. The sticky side will be used to hold these to the slipper disk, sand side to the spur.
Stick the slipper pad to sanding disk and cut around disk, mark the center hole (used a pen) and cut that out, do two.
The B4 spur (bottom spur in picture) has a flange to hold the slipper in place, carefully removed these with a X-Acto knife.
Any spur should work IF the body is smooth, the gear for a TC4 didn't work!!! Tried that first.
tmail55 is offline
