Old 01-28-2015, 04:55 PM   #826
fathead's Avatar
Could make the blocks out of carbon/delrin, does it need custom of the one piece bits too (shown on the right) or just use stock ones?
Slavich Design
fathead is offline   Reply With Quote
Old 01-28-2015, 05:00 PM   #827
fathead's Avatar
Originally Posted by skater-deez1 View Post
Along with a battery strap these are what I'll be sending to Damon, everyone ok with these shock towers?
Maybe one of the standard front & rear arm mounts if you have any spare so I can look at making low RC mod ones, if not can organise with nf_ekt
Also I will give you guys who send me parts to copy a discount on said parts, only seems fair!
Slavich Design
Old 01-28-2015, 05:09 PM   #828
EDWARD2003's Avatar
http://page5.auctions.yahoo.co.jp/jp...328#enlargeimg
I don't know if this is any use to you guys.
EDWARD2003 is offline   Reply With Quote
Old 01-28-2015, 05:10 PM   #829
nf_ekt's Avatar
Trader Rating: 113 (100%+)
No, not at all.. that was (what appears to be) someones attempt to lose a bit of weight... so that can be ignored!
I will send my MF blocks if needed. I won't be running the car until I get your adapter anyways. No rush so again let me know if you need them. I think I have the kit standard ones too. I have some NIP low front RC blocks that Losi made too.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 01-28-2015, 05:33 PM   #830
Marrs's Avatar
Looks good to me!
Hot Bodies D8TE - Tekno Conversion, Viper VTX8, Tekin T8 2250, Protek 130T
JQ The E Car - Tekno Conversion, Tekin RX8, Tekin T8 1900, Savox 1271SG
Losi SCTE RTR - TLR Chassis, Tekin RX8, Tekin Pro4HD 4300, Savox 1258TG
Losi XXX-S VTA - Graphite Chassis, Novak Edge, Novak 21.5, JR Servo
Marrs is offline   Reply With Quote
Old 01-28-2015, 06:34 PM   #831
bigfatslob's Avatar
Excellent ! Don't forget to send him a bottom belt cover as a template for CF one too.
Vintage is the way we roll : XXXS & TT01
bigfatslob is offline   Reply With Quote
Old 01-29-2015, 05:29 AM   #832
skater-deez1's Avatar
Trader Rating: 60 (100%+)
Thumbs up
Will do, it was actually at the top of the photo but is so much longer than the towers that it kinda got cropped out.
Going nowhere fast since 1973!
skater-deez1 is offline   Reply With Quote
Old 01-31-2015, 03:18 PM   #833
GhostTown's Avatar
I bought one of the black belts off of ebay in hopes of getting my xxx-s going again. It seems the belt is just a bit too long. I've read about using a different tensioner but I'm not sure what would be the correct one.
Could someone point me in the right direction?
GhostTown is offline   Reply With Quote
Old 01-31-2015, 09:32 PM   #834
nf_ekt's Avatar
The longer tension arm would help your cause. Not sure if you can mill the chassis enough to get the right tension (the slot where the set screw goes in to hold the tension arm in place).
Up the Irons \m/
Old 02-01-2015, 09:47 AM   #835
jhwnissan's Avatar
You just need to make sure you have the right tensioner. Otherwise, as said, you can figure out a way to mod the chassis to achieve better tension. Did you buy that one from me?
Josh Howard on RCNEWB.COM
Drawing rc car body madness in a Bunker....
Rare Losi R/C Belt Maker Extraordinaire
Need belts or parts? I can help.
SWs, RWs, XX-4s, XXX-S
jhwnissan is offline   Reply With Quote
Old 02-01-2015, 07:52 PM   #836
What is the correct belt tension and how do you know if your belt tension is correct? What is the best way to set/measure it?
microed is offline   Reply With Quote
Old 02-01-2015, 08:32 PM   #837
johnr2262's Avatar
run it as loose as you can without slipping. if it slips on hard brake its ok to slip a little on a high grip surface.
Losi xxx4 ,xxxs super stock Late Model,Blitz Big Dog,xxxs VTA,Custom Works Outlaw,Hot Bodies D8t and D8 ,Ass. T4.1
johnr2262 is offline   Reply With Quote
Old 02-01-2015, 09:04 PM   #838
nf_ekt's Avatar
Yep, unlike any other other car, the XXXS will "click" under hard braking... as long as it doesn't slip under acceleration, all is good. Loose as possible is the way to go.
Up the Irons \m/
Old 02-02-2015, 07:28 AM   #839
are you going to try to make all of these pieces or just the gear adapter
quickta is offline   Reply With Quote
Old 02-02-2015, 08:19 AM   #840
GhostTown's Avatar
I may have. I've been in email contact with the seller, so if you've heard from someone, it's likely me.
I plan to run this car in a silver can motor spec class with 1800 nicads, so the power will be very low.
The car is box stock. To get slack out of the belt, the tension arm buries WELL beyond the factory screw slot to the point where lengthening the slot would cut clear into the pinion view window (if that's what it's called). I have read in this thread and others about running it as loose as possible, especially in stock racing. That said, if the tension arm were locked down to it's tightest spot there is still enough slack to where there is an arch in the belt between the rear diff pulley and the spur pulley.
I'll get some pics up this evening and let you guys judge it as best as possible.
I should add that I have not attempted to run the car yet. I'm presently without a radio to test it. As soon as that is remedied I'll likely know better.
I was just wondering, since I've people talk about different tension arms, if there is one out there that is longer, and where can I find it.
