Old 01-10-2015, 01:09 AM   #796
Trader Rating: 34 (100%+)
Excellent. Thanks Fathead.
nismoflip is offline   Reply With Quote
Old 01-11-2015, 08:59 AM   #797
bigfatslob's Avatar
Originally Posted by fathead View Post
Only a couple pages ago, adapters will allow you to run small standard spurs for 21.5 to get the super high ratios the car was never designed for.
Looks like at this stage I will be offering a straight delrin adapter with stock pulley tooth count, and a 2 piece, alloy with interchangeable delrin pulleys allowing for smaller tooth count pulley to fit aftermarket belts better
Totally perfect, can't wait !
Vintage is the way we roll : XXXS & TT01
bigfatslob is offline   Reply With Quote
Old 01-27-2015, 12:21 AM   #798
Marrs's Avatar
Default Carbon Tower Possibility
Carbon towers is right up my alley actually!
Would you be interested in making some of these?
Don't know what make the rear is but the front is a Dynamite.
LOSI XXX-S, Tips and Tricks, Open Mod, etc-20150109_221810.jpg   LOSI XXX-S, Tips and Tricks, Open Mod, etc-20150109_221840.jpg
Hot Bodies D8TE - Tekno Conversion, Viper VTX8, Tekin T8 2250, Protek 130T
JQ The E Car - Tekno Conversion, Tekin RX8, Tekin T8 1900, Savox 1271SG
Losi SCTE RTR - TLR Chassis, Tekin RX8, Tekin Pro4HD 4300, Savox 1258TG
Losi XXX-S VTA - Graphite Chassis, Novak Edge, Novak 21.5, JR Servo
Marrs is offline   Reply With Quote
Old 01-27-2015, 01:03 AM   #799
fathead's Avatar
I can make basically whatever is needed for shock towers, should have a couple coming in the post to me soon to copy, then it's easy to add/subtract holes where necessary
Slavich Design
fathead is offline   Reply With Quote
Old 01-27-2015, 01:08 AM   #800
Marrs's Avatar
I hear ya! Really excited for the spur adapter as well. definitely put me on the list when you finish!
Old 01-27-2015, 07:08 AM   #801
also interested in the spur gear adapter when they are ready
quickta is offline   Reply With Quote
Old 01-27-2015, 07:49 AM   #802
Cancun Tom's Avatar
Send a message via Skype™ to Cancun Tom
Default XXXS adapters
Could someone explain in detail all about these adapters and what roll outs your trying to achieve? Thanks.
Check out all our travel adventures on my Caribbean Webpage http://www.cancunTom.com
Cancun Tom is offline   Reply With Quote
Old 01-27-2015, 07:55 AM   #803
skater-deez1's Avatar
Trader Rating: 60 (100%+)
Exclamation
Originally Posted by Cancun Tom View Post
Could someone explain in detail all about these adapters and what roll outs your tring to achieve? Thans
The basic idea is the adapter allows use of regular spur gears(instead of the molded Losi spurs) which is a must to achieve the 3.2-3.8 final drives required to run vta,usgt,and 17.5. Without the adaptor it's pretty hard to get in the ballpark.
Going nowhere fast since 1973!
skater-deez1 is online now   Reply With Quote
Old 01-27-2015, 03:13 PM   #804
Default Spur adapter!
I received the first spur adapter from fathead and installed it in my back up xxxs for testing. Initially it fit a bit tight in the chassis but I corrected this with just a small modification which I informed fathead of and the correction will make it to the production adapters. Here is a sneak peek.....keep in mind the craftsmanship on these is absolutely incredible!
Old 01-27-2015, 03:22 PM   #805
Marrs's Avatar
Looks awesome!!!!! Can't wait!!!!!
Old 01-27-2015, 03:35 PM   #806
fathead's Avatar
Glad if fits (mostly) man.
Looking at it in the car maybe I could do a slightly smaller diameter tensioning idler instead of the main pulley to accommodate the shorter belts, just depends on what people want to do really, option of slighty more expensive 2 piece adapter with pulley(gearing) changeable, or stock pulley teeth count 1 piece with smaller idle.
Slavich Design
Old 01-27-2015, 03:35 PM   #807
Johnny Wishbone's Avatar
I took a stripped gear and with my drill press and a exacto knife I made my own adapter. Its pretty easy, although a metal one would probably nicer.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-27-2015, 03:39 PM   #808
Thumbs up
Actually it fits fine as this chassis has not been milled out as far as my other for the new belt size. If people are running the belts from other sources which are said to be direct replacements it shouldn't be much of an issue. The only suggestion for perfect fit would be to move the bearing on the front pulley side in 1mm which should make it fit as perfect as the red Matt Francis Losi adapter! Kudos again Damon, great job on these!!!
Old 01-27-2015, 04:54 PM   #809
mike5009's Avatar
Send a message via AIM to mike5009
Great job! Can't wait to get one. Want to turn mine into a VTA CAR
mike5009 is offline   Reply With Quote
Old 01-28-2015, 07:17 AM   #810
bigfatslob's Avatar
Josh's belt AND those 12 dollar belts from Bulgaria on ebay are both the same size ( a bit small ) The Bulgarian belts are actually manufactured in Germany are reinforced and look , feel and perform like a clone of Josh's belt. The only problem is the two month delivery time from Bulgaria. Variable tooth count on the adapter is important in order the use the two best belts currently made. Also a higher tooth count on the spur gear adapter may allow the use of available XXX4 belts that run a little too big.
