Old 10-30-2014, 08:16 PM   #721
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Originally Posted by fathead View Post
You give me too much credit good sir!
I'm just a guy who likes to make some stuff in his spare time!
I get the most reward out of doing the little jobs (like this) that pretty much wouldn't get done otherwise.
If you make this happen, it is truly a new lease on life for this platform. The Xxxs has a winning history, as of the last few years it has been a beast at bigger VTA races. Without a supply of adapters, though, it has failed to be a go-to car for many. When a used roller can be found for around 50 bux, but a MF adapter (if you can find one) goes for 30-40.... well you see what I am saying. So we are definitely all-smiles at the thought of someone taking this project on.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 10-30-2014, 08:26 PM   #722
fathead's Avatar
To be honest this is a very easy project, it's getting done 100%, and soon.
Slavich Design
fathead is offline   Reply With Quote
Old 10-31-2014, 06:55 AM   #723
loosewheel's Avatar
Smile
I would interested in one also!
Jody
Greetings from the Great White North.
Going fast and breaking plastic since 1998.
RELIC RACING
loosewheel is offline   Reply With Quote
Old 10-31-2014, 07:17 AM   #724
skater-deez1's Avatar
Trader Rating: 59 (100%+)
Exclamation
Trick or treat night with my youngest last night,will get the pics with measurements up tonight!
Going nowhere fast since 1973!
skater-deez1 is offline   Reply With Quote
Old 10-31-2014, 01:10 PM   #725
Lightbulb
Ok preliminary measurements are as follows: The base that rides against the spur is 28mm in diameter. There is a 1mm lip on the bottom side that surrounds the bearing insert(on the backside but no bearing goes in here) to hold the spur straight. The openings for the bearings are 9mm and in the center 3mm down from the pulley side is a lip to hold the frontside bearing in place,this extends the entire length of the opening as the bearing on the backside of the spur does not go inside the adapter but rather rides inside the spur gear. From pulley side to the rear lip it measures a thickness of 8mm. The pulley itself is somewhat hard to measure but seems to be approx. 6mm wide. I'm sure my explanations are far from perfect so please let me know what else is needed.
LOSI XXX-S, Tips and Tricks, Open Mod, etc-dscf1829.jpg   LOSI XXX-S, Tips and Tricks, Open Mod, etc-dscf1830.jpg   LOSI XXX-S, Tips and Tricks, Open Mod, etc-dscf1831.jpg
Old 10-31-2014, 01:11 PM   #726
Also the mounting holes from center to center are 16mm apart.
Old 11-01-2014, 04:21 PM   #727
fathead's Avatar
Cool I will get onto this in the next few days, just frantically trying to get new arms made for my pro10 at the moment
Old 11-01-2014, 04:43 PM   #728
Thumbs up
Awesome,like I said any further info needed just give me a shout!!!
Old 11-16-2014, 09:43 AM   #729
ok guys,just purchased my xxxs,now to get it ready for vta.will the gear adaptor for the xxx4 work for the spur?if not there is some out there just probley take like 3 weeks to recieve it.guy says he has the red spur in it and ran a 27 tooth pinion and temps were to bad is this a setup i can live with for vta?
smash8ight is online now   Reply With Quote
Old 11-16-2014, 11:16 AM   #730
Exclamation
Nah you're gonna need the spur gear adapter for sure. Hopefully someone starts making them again as they give these cars a new lease on life. Unfortunately they are few and far between at this time.
Old 11-17-2014, 05:31 AM   #731
jhwnissan's Avatar
I think I have an idea. Skater-Deez1... I DM'd you. If I can make a good mold and find a decent enough polymer, I could cast a few gear adaptors. Thoughts?
Josh Howard on RCNEWB.COM
Drawing rc car body madness in a Bunker....
Rare Losi R/C Belt Maker Extraordinaire
Need belts or parts? I can help.
SWs, RWs, XX-4s, XXX-S
jhwnissan is offline   Reply With Quote
Old 11-17-2014, 09:06 AM   #732
loosewheel's Avatar
Thumbs up
I'm sure you could sell quite a few. It would definitely be a welcome addition. I'm interested.
Jody
RELIC RACING
Old 11-17-2014, 09:47 AM   #733
fathead's Avatar
I should have the first adapter cnc'd up next week guys, just got busy on the pro10 and haven't had a chance
Old 11-17-2014, 12:47 PM   #734
Thumbs up
I'll help anyone start making them as long as I can get a second one.....useful little piece!
Old 11-17-2014, 12:51 PM   #735
fathead's Avatar
I will be making as many as people need
Slavich Design
