Old 08-31-2014, 03:03 PM   #676
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
As I've bought 3 used RTR's this info isn't available
Step A-3 for the "G"
"If you decide to build your XXX-S with the front Spool, refer to the addendum included in the bag with the front Spool Pads."
Any one have this that they can post?
Plus what are the pads made of?
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 08-31-2014, 04:35 PM   #677
skater-deez1's Avatar
Trader Rating: 60 (100%+)
Lightbulb
I have a spool,not sure if it's the factory set up but the "spool pads" look like sandpaper diff rings......could be who knows.
Going nowhere fast since 1973!
skater-deez1 is offline   Reply With Quote
Old 09-08-2014, 10:05 AM   #678
loosewheel's Avatar
Cool
Anyone know of a metric equivalent for the white tensioner pulley bearing (3/16 X 3/8)?
Jody
Greetings from the Great White North.
Going fast and breaking plastic since 1998.
RELIC RACING
loosewheel is offline   Reply With Quote
Old 09-30-2014, 03:41 PM   #679
Super Moderator
tmail55's Avatar
Just got two new belts from Josh on here, when I tried to install one I found this!!!
XXX-S gears (48p) with a 86 or 88 gear you need to make the adjustment mod but with the 90 you do not.
Reason the 86 and 88 have 23 teeth at the spur drive gear and the 90 has 20! Real odd that Losi did that.
XXX4 has the same tooth count (20) on the slipper drive pulley (A-3269).
Old 09-30-2014, 03:52 PM   #680
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Reason the 86 and 88 have 23 teeth at the belt spur and the 90 has 20! Real odd that Losi did that.
XXX4 has the same tooth count (20) on the slipper belt spur.
Just wondering, which tracks in Fl are you running at? I'm thinking of putting a XXX-S back out there soon... might need a good starting set up for asphalt.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 09-30-2014, 04:04 PM   #681
Super Moderator
tmail55's Avatar
Race in Ruskin at Mann's RC
https://www.facebook.com/MannsTrainsRcs
and
Quaker Steak and Lube in Clearwater 2nd Sat
https://www.facebook.com/pages/ME-Ra...72049672834129
Old 10-23-2014, 02:33 PM   #682
imjonah's Avatar
Default XXX-S VTA ?
Is it even possible to gear a XXX-S for a 25.5 brushless motor.
I have used a 45 tooth 64 pitch pinion with a 108 spur on a 13.5 brushless
It seems to me that I would need a 60+ tooth pinion to match Novaks RDR recommendation for a 25.5 Motor.
Has anyone successfully geared a XXX-S and a 25.5 Brushless motor?
Thanks in advance.
imjonah is offline   Reply With Quote
Old 10-23-2014, 03:34 PM   #683
Thumbs up
Thanks in advance.
Yes but you need the spur gear adapter,after you score one you are all set for any motor.
Old 10-25-2014, 10:00 AM   #684
loosewheel's Avatar
Questions??
Where does one find a spur gear adapter?
Jody
RELIC RACING
Old 10-25-2014, 12:28 PM   #685
Exclamation
Good question,every once in awhile ebay will have one. They are hard to come by but well worth the hassle. With the adapter you can use any spur gear on the market which helps a lot when you wanna run 17.5,21.5 or 25.5 motors.
Old 10-25-2014, 04:36 PM   #686
nf_ekt's Avatar
I don't know much about 3D printing, but I would think that for low -stress classes like 25.5, it would be pretty easy to make some adapters out of some type of plastic. I have a NIP Trinity MF adapter, i would certainly let someone borrow it if they could use it in order to help produce some made out of plastic or delrin..... but again idk what is or is not possible, I just know that 3D printing has made it possible to produce a lot of things.
Up the Irons \m/
Old 10-25-2014, 08:00 PM   #687
^^ That's a really good idea!!^^
Old 10-25-2014, 11:54 PM   #688
fathead's Avatar
Does someone have a few picks of said adapters? If they are simple enough I might be interested in cnc'ing a few myself, either delrin or aluminium
fathead is offline   Reply With Quote
Old 10-26-2014, 09:08 AM   #689
Trader Rating: 24 (100%+)
Nevermind. Sorry Tmail. IRS use to have a great spool assembly for the xxx-s but it looks like they've closed shop. What a shame.
This list shows some of the goodies we used to have available for our cars. http://ccdata.no/mod/rc/xxx-s-hopup-list/
And since a lot of you folks are racing the X in stock type classes, maybe this other xxxs thread could help. XXX-S Tips and Talk for Stock Classes
Evoracer is offline   Reply With Quote
Old 10-26-2014, 05:36 PM   #690
Thumbs up
I'll have to take mine out but will post pics tomorrow!
