Old 08-19-2014, 05:34 AM   #661
jhwnissan's Avatar
Originally Posted by tmail55 View Post
Your on my list for a belt, got one from Superior Hobby the day before I found out about you!!!!!
My LHS has AE, Traxxas and RedCat parts, so I'm limited to supporting them to a point. They have NO Losi parts at all!!!!
I tried to put some info on Losi's forum about getting belts from you and they won't allow my posts!!!
That's okay. Even if someone buys from another company, I totally understand. I know the belts I have are good and work well. People will use the others and hopefully end up buying mine. The biggest crux right now is with arms and towers. I've got the parts to start making some cheap molds for resin parts, but my time is limited during the summer. It's a new process for me so it will take some time. I hope, in time, to be able to offer up a plate chassis car for those still interested in it. I love r/c. If I didn't, I wouldn't do it for work AND a hobby.
Josh Howard on RCNEWB.COM
Drawing rc car body madness in a Bunker....
Rare Losi R/C Belt Maker Extraordinaire
Need belts or parts? I can help.
SWs, RWs, XX-4s, XXX-S
jhwnissan is offline   Reply With Quote
Old 08-19-2014, 01:42 PM   #662
skater-deez1's Avatar
Trader Rating: 60 (100%+)
Thumbs up
You had me at plate chassis!
Going nowhere fast since 1973!
skater-deez1 is offline   Reply With Quote
Old 08-20-2014, 10:50 AM   #663
jhwnissan's Avatar
I'm doing drifting now and EVERYONE uses a plate. Not only that, but cars are similar enough to be able to interchange parts. Needless to say, it's inspiring me.
Old 08-20-2014, 02:42 PM   #664
Talking
Sweet!!!!
Old 08-23-2014, 01:08 PM   #665
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
Haven't read anywhere about this, maybe I'm the first to notice and have a fix.
There is a lot of flex at the steering post (44 figure 19 in RTR manual, 19a in G manual) put a carbon piece across the top of the two steering posts under the two washers (46) before installing the two screws. Don't know if there is any flex with the G chassis, just have the RTR.
Will post a picture soon.
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is online now   Reply With Quote
Old 08-25-2014, 11:05 AM   #666
loosewheel's Avatar
Where did you get the carbon piece?
Jody
Greetings from the Great White North.
Going fast and breaking plastic since 1998.
RELIC RACING
loosewheel is offline   Reply With Quote
Old 08-25-2014, 03:50 PM   #667
Super Moderator
tmail55's Avatar
Steering posts without carbon bit. Looking down at the posts, grab hold of the front wheels, twist them out to get massive toe out then twist them in the get massive toe in and watch the post flex side to side.
Steering post with carbon bit
Carbon bit was made from a part from ????? maybe someone knows what RC, it was in a parts box. Not pretty but works.
Old 08-25-2014, 04:15 PM   #668
loosewheel's Avatar
It wouldn't necessarily have to be carbon fiber, would it? Aluminum would work and be almost as light.
Jody
RELIC RACING
Old 08-25-2014, 04:54 PM   #669
Super Moderator
tmail55's Avatar
made it out of carbon cause I had it AND I wanted to say I had some carbon bit on my XXXS!
Have these on both my XXX-S.
Old 08-26-2014, 03:16 AM   #670
Thumbs up
Sounds reasonable....also sounds like another reason for me to add some more red aluminum to my XXXs!
Old 08-26-2014, 12:54 PM   #671
loosewheel's Avatar
Do you have a dimension between the holes? It's kind of hard to measure unless you take it apart.
Jody
RELIC RACING
Old 08-26-2014, 04:57 PM   #672
Super Moderator
tmail55's Avatar
I used one like this one to measure for the holes;
OR
slide something thin through the "steering tunnel" with the steering post screws out.
OR
measure the distance between the center of the screws (from the bottom) that bolt the steering posts to the chassis
Old 08-26-2014, 05:42 PM   #673
loosewheel's Avatar
Smile
My calipers are digital and it's still a pain.
Jody
RELIC RACING
Old 08-27-2014, 03:06 AM   #674
Super Moderator
tmail55's Avatar
flip the xxxs over and measure the distance between the center of the screws that bolt the steering posts to the chassis.
Old 08-29-2014, 07:00 PM   #675
loosewheel's Avatar
Thumbs up
I tried this mod, it tightened up the steering a little on my XXXX-S. I couldn't tell any difference on my XXXX-Graphite. I like a little flex in my cars.
Jody
RELIC RACING
