Old 07-02-2014, 12:59 PM   #646
skater-deez1's Avatar
Trader Rating: 60 (100%+)
Thumbs up
I prefer jhwnissan's belts over all the Losi belts.....they're way tougher. I have a ton of runs on them and they still look new,no signs of wear!!!
Going nowhere fast since 1973!
skater-deez1 is offline   Reply With Quote
Old 07-02-2014, 01:04 PM   #647
jhwnissan's Avatar
Thanks man. The Losi belts can spin a little better, but they also get destroyed WAY faster. Once broken in, it's close enough that it doesn't matter at all.
Josh Howard on RCNEWB.COM
Drawing rc car body madness in a Bunker....
Rare Losi R/C Belt Maker Extraordinaire
Need belts or parts? I can help.
SWs, RWs, XX-4s, XXX-S
jhwnissan is offline   Reply With Quote
Old 07-02-2014, 03:20 PM   #648
loosewheel's Avatar
Ditto on Josh' s belts!
Jody
Greetings from sunny Northern California
Going fast and breaking plastic since 1998.
RELIC RACING
loosewheel is offline   Reply With Quote
Old 07-02-2014, 08:37 PM   #649
tfrahm's Avatar
Send a message via AIM to tfrahm
Originally Posted by jhwnissan View Post
When they fall apart, they're garbage. Losi's belts had a shelf life and most all are expired by now.
Say - I sent you a message about your belts for the XXX-S - when you get a chance, I would appreciate a reply. I REALLY need to get some belts...
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 07-02-2014, 08:59 PM   #650
tfrahm's Avatar
Oops! Sorry - I just realized you DID reply to my message... For some strange reason, the messages are not showing up as PM's - it shows as a "visitor message", and I hadn't seen it... Thanks for responding, and I have sent you an email reply...
Old 08-15-2014, 03:06 PM   #651
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
Racing a XXX-S now, moved from off road, with almost NO springs available, what are my options? Brands and color/sizes (part numbers IF that's not to much to ask).
THANKS!!!!!! :-)
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 08-15-2014, 04:20 PM   #652
mike5009's Avatar
Send a message via AIM to mike5009
THANKS!!!!!! :-)
Associated springs work. That's what I run on mine. You running carpet or asphalt?
mike5009 is offline   Reply With Quote
Old 08-15-2014, 08:04 PM   #653
Super Moderator
tmail55's Avatar
asphalt
One track is parking lot, the other is a sealed parking lot that they closed off for a track
Have >> Losi 5125 Blue 14.6 what AE is equal to this?
THANKS!!!
Old 08-16-2014, 04:30 AM   #654
Talking
Some Losi springs can be found on ebay,sometimes you luck out and find somebody selling a bunch of them. The associated springs work fine unless you have threaded shock bodies in which case they will rub on the threads and then you will have a hard time moving the adjustment ring. The losi springs are a little bit bigger roundwise(bore) than the ae.
Old 08-16-2014, 04:32 AM   #655
Lightbulb
The silver ae springs are 14.5 so that would be the closest.
Old 08-16-2014, 08:30 AM   #656
As for belts find a bando belts dealer i bought mine through a place in indianapolis get an sts s3m750 belt i got mine 4mm wide but you can get 3mm if you want you have to grind a little on the slot but no big deal and they are like $4 a peice! And its best to use the hd tensioner and pulley but leave the pulley in the standard length hole on the arm the stock pulley and arm give too much flex and it will derail when using reverse
Dirtcar75 is offline   Reply With Quote
Old 08-16-2014, 12:19 PM   #657
Super Moderator
tmail55's Avatar
THANKS this gives me a start point.
Been watching ebay for other bits, springs are next on the list.
Old 08-18-2014, 05:47 AM   #658
jhwnissan's Avatar
Almost any spring should be fine. A lot of guys around here used xray and tamiya springs because they were in stock at the local places. AE is also a good spring. If you ever need belts, I always have them. Just shoot me a message or check me out on ebay @ joshhowarddesign.
Old 08-18-2014, 06:27 PM   #659
Super Moderator
tmail55's Avatar
Your on my list for a belt, got one from Superior Hobby the day before I found out about you!!!!!
My LHS has AE, Traxxas and RedCat parts, so I'm limited to supporting them to a point. They have NO Losi parts at all!!!!
I tried to put some info on Losi's forum about getting belts from you and they won't allow my posts!!!
Old 08-19-2014, 05:25 AM   #660
Exclamation
That's how it works sometimes,Josh was interested in this project and had his belts out until people realized there was as much ca$h to be made. Now you can get belts from many places. I'm not knocking these other places but nobody had an interest in reproducing these until he already had sold quite a few. Yeah his belts require a little modification where the others may not but I know he did this because he loves rc.....not sure if I could say the same about all the others.
