Old 11-04-2013, 06:02 AM   #496
Questions??
Hello all Losi fans I am new here. found a stock XXX-S with some graphite parts. I am rebuilding it. Looking for a Graphite chassis. Is there anywhere I can get one or are they out of production? Thanks
bro2 is offline   Reply With Quote
Old 11-04-2013, 06:11 AM   #497
jhwnissan's Avatar
There are chassis out there on eBay but I'm sure people here have one or two laying around. Just ask and I'm positive people here have what you need.
Josh Howard on RCNEWB.COM
Drawing rc car body madness in a Bunker....
Rare Losi R/C Belt Maker Extraordinaire
Need belts or parts? I can help.
SWs, RWs, XX-4s, XXX-S
jhwnissan is offline   Reply With Quote
Old 11-04-2013, 07:49 AM   #498
jhwnissan's Avatar
Things looking great so far this week on the belts. Looks like it'll be late next week when I can get them in. Just waiting for some final test results.
Old 11-04-2013, 08:45 AM   #499
skid plate's Avatar
I sent you a PM. Hope it helps buddy.
skid plate
I Pushed Humpty Dumpty
losi xxxs
twin hammer
just a lucky bastad
skid plate is offline   Reply With Quote
Old 11-04-2013, 08:56 AM   #500
jhwnissan's Avatar
1. edm rob-4
2. skater-deez1-4
3. vabroom - 4
4. cdlowe30907- 2 or 4
5. farley1 - 3
6. rctrackman - 4
7. undying - 2
8. rubbaneck - 2
9. 429racer - 2
10. skid plate - 2
11. boostedti - 2
12. js600-2
13. sutman9872-2
14. Teamgimpy72- ?
15. Colin O. - 2
16. Bohh - 2
17. Cancun Tom - 4
18. Matt K - 2
19. bro2 - 2
20.
Old 11-08-2013, 08:31 AM   #501
jhwnissan's Avatar
Just waiting on results.... everyone stay tuned. Can we agree that people need front suspension arms? Also, are there any mods you guys do to your stock arms?
Old 11-08-2013, 08:53 AM   #502
Js600's Avatar
Trader Rating: 21 (100%+)
Just got the brushless in last night and the belt is doing well after 2 packs. Now I just need to find a socket to take the wheels off ha
Js600 is offline   Reply With Quote
Old 11-08-2013, 09:10 AM   #503
skid plate's Avatar
The addition of front arms would be fantastic.
I find a couple here and there but a good supplier would be nice.
Depending on what you want to do racing wise would be a consideration for shock arm changes. Some of us race in dirt and need more travel, (different shocks sometimes), others run on pavement or carpet and need different rod ends or spring rate changes.
Just my 2 cents.
Thanks again for all the effort.
skid plate
losi xxxs
twin hammer
just a lucky bastad
Old 11-08-2013, 09:12 AM   #504
skid plate's Avatar
I just use an 8/32 nut driver which I have milled down the outer wall of to fit into the wheel recess area.
Works great.
skid plate
losi xxxs
twin hammer
just a lucky bastad
Old 11-08-2013, 11:23 AM   #505
jhwnissan's Avatar
Just my 2 cents.
So, places for different shock mounting? More holes?
Old 11-08-2013, 06:31 PM   #506
skid plate's Avatar
Maybe 1 more mount, I don't know that more than that would be used.
Would worry too that it would be weaker with too many mount positions.
With the different top mounts available it works well now with just one.
skid plate
losi xxxs
twin hammer
just a lucky bastad
Old 11-08-2013, 06:32 PM   #507
Js600's Avatar
well after some very rough testing today I'm happy to report the belt held up perfectly with about 5 packs of 3s. Unfortunately my tires are another story. Now if I could just find a socket to remove them lol
Old 11-08-2013, 07:12 PM   #508
skater-deez1's Avatar
Trader Rating: 60 (100%+)
Thumbs up
Actually used my dremel and a small drill bit to slide up the tensioner screw slot today which gave me more than enough adjustability to run as much or as little tension that I want. I will try to get a few more runs in this weekend but so far so good. I know some people will be hesitant to do the chassis mod but it really is very easy and took about 10 seconds with the above method.I simply found a drill bit that was about the same size as the factory slot,then ran it up against the top of the slot and it burrowed the plastic out perfectly and looks like it came from Losi that way!
skater-deez1 is offline   Reply With Quote
Old 11-08-2013, 07:17 PM   #509
Thumbs up
Hey js what wheels are you using? I've had problems with that before but usually only with certain wheels and offsets. I have some sorex slicks on hb wheels and have tons of room to get in with a non-modified socket.I saw where guys were pushing expensive tools on the problem,if it were me I'd look at different wheels.....unless you run vta in which case I'd try to find smaller nuts! DISCLAIMER: My use of "smaller nuts" while hilarious was actually referring to the wheel nuts on his car!
Old 11-09-2013, 06:20 AM   #510
Js600's Avatar
Lol
