Old 10-22-2013, 12:52 PM   #451
skater-deez1's Avatar
Trader Rating: 60 (100%+)
Oh and the 42 tooth pulley has a ridge around the pulley,the 41 has no ridge. Makes them easy to tell apart in the dark!LOL
skater-deez1 is offline   Reply With Quote
Old 10-22-2013, 12:54 PM   #452
Have you tried the HD tensioner yet?? If I remember right, that tensioner was longer and the black delrin guide pulley was smaller in diameter.
Have you already checked to see if another belt is available ?? I only ask because belt tension is somewhat critical depending on what kind of power is being used. For VTA we ran it pretty loose. 21.5 shouldn't be an issue either and I doubt to many folks will run the x with much more power these days.
rctrackman is offline   Reply With Quote
Old 10-22-2013, 01:10 PM   #453
The hd tensioner actually has a larger pulley. The stock white pulley is smaller than the black hd pulley.
Old 10-23-2013, 05:59 AM   #454
jhwnissan's Avatar
Well, I got it working. With a small amount of expansion in the tensioner adjustment slot, I was able to get the belt fitted and going. I did not have to modify the tensioner in this case... I only had to dremel the slot larger for the tensioner adjustment screw. Here are the pictures. The car runs extremely well but the belt is still slightly tighter than I would like. It could be made more efficient by cutting every other tooth off the belt but that might compromise strength. Let me know what you guys think. Torture testing begins this weekend to ensure you guys get a good product.
Josh Howard on RCNEWB.COM
Drawing rc car body madness in a Bunker....
Rare Losi R/C Belt Maker Extraordinaire
Need belts or parts? I can help.
SWs, RWs, XX-4s, XXX-S
jhwnissan is offline   Reply With Quote
Old 10-23-2013, 06:17 AM   #455
jhwnissan's Avatar
Btw, The pulleys on this car were unmarked. They don't have black stripes or anything printed on them.
Old 10-23-2013, 07:31 AM   #456
Trader Rating: 70 (100%+)
does anyone have a spare spur gear adapter (so I can use regular spurs) that they can sell me?
TIA
Markus is offline   Reply With Quote
Old 10-23-2013, 08:57 AM   #457
OR YOU GUYS CAN GET THE NEW LOSI TC KIT !!! COMING SOON !!!
bertrandsv87 is offline   Reply With Quote
Old 10-23-2013, 08:59 AM   #458
jhwnissan's Avatar
1. I'll believe it when I see it.
2. Losi screwed everyone over that had older cars when Horizon took over.
3. Buying belts and parts to stay competitive is cheaper than dropping a ton on a clean slate.
4. All caps... really?
Old 10-23-2013, 02:07 PM   #459
Thumbs up
LOL! His caps lock is broken,and couldn't agree more JH!!!
Old 10-23-2013, 02:10 PM   #460
I just wanted to inform folks here, that's all !!! Don't hate the messenger...lol...
Old 10-23-2013, 02:58 PM   #461
Thumbs up
Thanks for the heads up on the new losi,but I would imagine the big thinkers at tlr will be looking to go to that ultra new 3 belt design. You know like the 22-4 which is a re-tooled xx4.....BRILLIANT!!!!
Old 10-23-2013, 04:32 PM   #462
Or maybe 4 wheel steering !!!!
Old 10-23-2013, 09:36 PM   #463
Big Midget's Avatar
Trader Rating: 98 (100%+)
Or maybe shaft drive?
Dee & Mee Hobbies
Fastlane Raceway-wwwfastlanehobbies.com
Topeka On-Road Racing-Jake's R/C Pro-Am Topeka,Ks
www.ZigPhoto.com,RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 10-24-2013, 03:37 AM   #464
jhwnissan's Avatar
What, you mean like the Vaterra line they already sell? LOL Losi probably isn't going to do onroad anytime soon because Horizon is making fat bank off that Vaterra line currently.
Old 10-24-2013, 06:15 PM   #465
I haven't been following this thread for a little bit, but *wooohooo* for new belts. Parts I could use are front control arms. I wouldn't mind swaybar kits too, but I'm not as fussy about that. I seem to have plenty of everything else. lol
Grauwulf is offline   Reply With Quote
