Old 10-15-2013, 06:30 PM   #421
jhwnissan's Avatar
1. edm rob-4
2. skater-deez1-4 or more...price dependent
3. vabroom - 4 + tensioner
4. cdlowe30907- 2 at least
5.
6.
7.
8.
9.
10.
Can people still get arms pretty easy? Any other parts that are tough to come by?
Josh Howard on RCNEWB.COM
Drawing rc car body madness in a Bunker....
Rare Losi R/C Belt Maker Extraordinaire
Need belts or parts? I can help.
SWs, RWs, XX-4s, XXX-S
jhwnissan is offline   Reply With Quote
Old 10-16-2013, 09:20 AM   #422
jhwnissan's Avatar
1. edm rob-4
4. cdlowe30907- 2 or 4
5. farley1 - 2
6.
7.
8.
9.
10.
Old 10-16-2013, 11:55 AM   #423
jhwnissan's Avatar
Update! Belts are on their way that are closer to stock tensioner size. However, I may have to still make a custom tensioner because they are around 6mm different as far as overall length goes. I'll take pictures when they arrive and I get one on. Had to minimum order 10... so if they work easily, I'll be able to put 8 in people's hands almost immediately. We're oh so close. I could get exact size HD 259 tooth belts made, but it would cost me around 2k in tooling and I don't want to pass that much cost onto you guys. I'll keep you guys updated!
Old 10-16-2013, 01:56 PM   #424
The X cars are waiting. Count me in for 4 if all the details get worked out.
rctrackman is offline   Reply With Quote
Old 10-16-2013, 03:25 PM   #425
jhwnissan's Avatar
1. edm rob-4
5. farley1 - 2
6. rctrackman - 4
7.
8.
9.
10.
Btw... it sounds like if these belts I have on the way fit with the stock tensioner, we'll have enough for everyone in as soon as 2 weeks. Cost is looking to be 25 for belt shipped in the US. How does that price sound to you guys? I might be able to go a little lower but not a whole lot. International will just be determined on where people are at.
Old 10-21-2013, 06:07 AM   #426
jhwnissan's Avatar
1. edm rob-4
5. farley1 - 3
6. rctrackman - 4
7. undying - 2
8.
9.
10.
I think I'll throw a brushless setup in the car I bought just to confirm they can take it. Never had problems with the ones I did on the Street Weapon but I'd rather be safe than sorry. Stay tuned guys.
Old 10-21-2013, 10:43 AM   #427
jhwnissan's Avatar
Wife said the belts arrived this morning. Prepare for pictures tonight!
Old 10-21-2013, 12:22 PM   #428
skater-deez1's Avatar
Trader Rating: 60 (100%+)
Thumbs up
Great news man,can't wait!
skater-deez1 is offline   Reply With Quote
Old 10-21-2013, 12:33 PM   #429
Rubbaneck's Avatar
Hours of looking for XXX-S belts and I find this awesome thread. Just stumbled on it too.
I run Rally with a big group here in Colorado and I just snapped my last belt yesterday Thought my car was going to be a paper weight.
I'll take 2 after you check them out Josh. And I sent you a PM not knowing about this thread, kept looking and reading this wonderful news!
Jay
"i usta win trophies"
Rubbaneck is offline   Reply With Quote
Old 10-21-2013, 01:04 PM   #430
jhwnissan's Avatar
Glad you found it Rubbaneck.
1. edm rob-4
5. farley1 - 3
6. rctrackman - 4
7. undying - 2
8. rubbaneck - 2
9.
10.
Old 10-21-2013, 05:36 PM   #431
jhwnissan's Avatar
Well guys... we're THIS close. Due to the kevlar being in the belt, it doesn't have any stretch to it. As such, it could use another tooth or two to use the factory tensioner. I think I may be making a custom tensioner.
What do you guys think? Would sure beat no belt, right? Same number of teeth as the stock belt but because it lacks stretch, it either needs more teeth or a different tensioner. Making a tensioner bracket that is revised is cheap. Thoughts?
Old 10-21-2013, 05:45 PM   #432
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
First what tensioner are you using and with which idler pulley? The tensioner that comes with the black belt kit is longer than the stock one and also uses a larger dia idler pulley than the stock one uses. So you do have options to use another tensioner or another pulley depending on which one you are using in your car now to maybe get this to work.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 10-21-2013, 05:54 PM   #433
jhwnissan's Avatar
It is just the stock tensioner. Was considering trying the longer one but I don't have one. Maybe I'll get one ordered. We'll see. I take it you guys would rather keep a stock tensioner even if it's the extended belt one?
Old 10-21-2013, 05:58 PM   #434
Kevin K's Avatar
You can also drill a new hole in your stock tensioner to move the idler pulley close to the spur gear. The tensioner that comes with the Black belt kit has 2 sets of holes for this very reason so you can move the pulley closer if using the stock shorter belt. There might be enough room to drill and tap a new hole on the stock tensioner instead of making a whole new one.
Old 10-21-2013, 06:06 PM   #435
jhwnissan's Avatar
I may have to try that. This one only has one hole. I'm afraid if I put the pulley closer to the center, it'll hit the gear. We'll see.
