Old 08-03-2013, 07:58 PM   #391
skater-deez1's Avatar
Trader Rating: 59 (100%+)
Lightbulb
The belts i tested were too thick and rubbed the inside of the gearcases,i have about nine belts nib i keep to assure i can keep my fleet of xxxs(4 of them)going.The xxx4 belt works great if you can find the longer tensioner arm and they are easier to find.I'd be willing to part with a roller with a new belt and the longer tensioner but don't really wanna start selling off belts yet.
skater-deez1 is online now   Reply With Quote
Old 08-05-2013, 04:47 PM   #392
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Originally Posted by jkelnhofer View Post
Any updates on the belts? I would gladly pay whatever to whomever to get a working belt or two. I am still researching my options and will provide any updates I can.
Jason
I have some belts for this car. Pm me for details
I am selling off my XXX-S collection (roller, trick bits, ect).
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 08-08-2013, 10:52 AM   #393
If anyone out there speaks/reads Japanese please take a look at the Kawada website. The Sigma chassis used a similar drivetrain to the xxxs. It looks like they still make the Sigma. I wonder how close in size the belt is and if it's still available. It appears their site is no longer available in English.
rctrackman is offline   Reply With Quote
Old 09-02-2013, 12:11 PM   #394
Default 3 cars plus box full of parts
Just seeing if anyone is interested in 3 xxxs and box of parts still in package.
tqboy is offline   Reply With Quote
Old 09-19-2013, 06:05 PM   #395
Default belts
Any body find a belt that you can use going to put a usvta to race I have 3 cars and 2 belts looking for some more. Harold
edm rob is offline   Reply With Quote
Old 09-19-2013, 07:17 PM   #396
nf_ekt's Avatar
I have some springs for the XXX-S for sale, last of my stuff.
4-pink, 2-silver, 2-Black, 2-Purple. Pretty much the range you need for carpet and asphalt. $15.00 bux shipped, pm me.
Up the Irons \m/
Old 09-19-2013, 07:41 PM   #397
Cancun Tom's Avatar
Send a message via Skype™ to Cancun Tom
Default Losi XXXS
TQ BOY,
Check your PM's
Check out all our travel adventures on my Caribbean Webpage http://www.cancunTom.com
Cancun Tom is offline   Reply With Quote
Old 09-20-2013, 11:03 AM   #398
Default Belt for XXX-S G+
Hi I'm running a xxx-s graphite and its my last blue belt, I will like if any one found where to buy this ones, or if someone are making aftermarket belts for this great kit.
Cheers,
Alex
alexrgz is offline   Reply With Quote
Old 09-23-2013, 03:48 PM   #399
Default XXX-S with XXX-4 Yellow Belt and original tensioner
FYI for those looking for belt replacement options for the XXX-S. I just installed a yellow XXX-4 belt. To make it work you file or drill the widest part of the first opening past the normal pivot point on the tension arm just enough that it will fit over the spur gear bushing and be the new pivot point.
Then you have to very carefully determine exactly where the new hole for the tension locking screw has to go and drill through the chassis there. I did this with the spur gear removed but the spindle of the gear still in place for the tension arm to rotate on. I could then easily move the arm into position without tension, lock it in place with a clamp, and drill a guide hole through the lock screw hole on the arm and through the chassis.
Here's a pic
https :// www dot dropbox dot com/s/3jj0d63hir6t0f6/Losi%20XXX-4%20to%20XXX-S%20belt%20conversion.jpg
so you can see where the screw ended up. One battery so far and it seems to be working well.
TallTopher is offline   Reply With Quote
Old 09-23-2013, 05:29 PM   #400
vabroom's Avatar
^ link not working.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 09-23-2013, 05:29 PM   #401
Cancun Tom's Avatar
Your picture link dosen't work. Thanks for the tip.
Old 09-24-2013, 06:33 AM   #402
Sorry about the picture link, the forum won't let me post an actual link.
If you copy this into a browser it should work:
dropbox.com/s/3jj0d63hir6t0f6/Losi XXX-4 to XXX-S belt conversion.jpg
Old 09-24-2013, 08:38 AM   #403
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
it does - he put spaces and " dot " in there to keep it from being harvested by bots. Just replace the first part with:
https://www.dropbox.com and then the /s . . . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 09-24-2013, 08:39 AM   #404
Boomer's Avatar
Topher - you just need some more posts.
Old 10-06-2013, 09:20 AM   #405
Trader Rating: 118 (100%+)
Anybody interested in buying any parts or rollers just PM with what you want and your zip.
Let me know
cdlowe30907 is offline   Reply With Quote
