TC4 chassis help needed
I've been having probs with the car pulling hard to the right, I started looking into it and found that if I push down on the right rear shock the front left tire raises up. Now If I push on the left front the right rear raises. whats the prob here? The othe 2 corners are fine.. thanks in advance.
phil
phil
Sounds like you might have a shock or hinge pin binding (bent), you could try swapping sides on you shocks and see if the problem goes to the other corners.
