Need help with Diff >
Need help with Diff
Need help with Diff
Old 10-16-2009, 09:37 PM
bschimmel's Avatar
Trader Rating: 35 (100%+)
Default Need help with Diff
I have a TC3 and I cant seem to get the feel for adjusting the diff. Does anyone have any tips a a web resource to help guide me.
Thank you
Barry
bschimmel is offline
Old 10-16-2009, 11:19 PM
hotdognobun's Avatar
Trader Rating: 32 (100%+)
Thank you
Barry
go to youtube and type redrc and watch Jilles Groskamp - Part 2.
hotdognobun is offline
Old 10-17-2009, 07:50 AM
wiscnitro's Avatar
Trader Rating: 22 (100%+)
Not a verry good Explnation in short the way I do it is when you got your diff put together start to tighten the diff screw with your 5/64 and if your using a shaft tool not a "L" allen use your thumb. Index and Middle fingers to turn the wrench untill you feal the screw stop with the 3 fingers you can feal when the resistance is there. If you have to "try" to turn the screw you going too far. Feal resistance and STOP give the diff a few turns and check it again that will align the parts and muve the grease around so check to see if it loosened up at all. Tighten again then back off screw 1/2 turn and your done
wiscnitro is offline
